I have 2 monitors a syncmaster 920N and 216bw.Both were working fine until I had a system restore now only one works.What do I have to do?
    Brigadier General:
  • 6,966 Answers
You need to verify that the appropriate driver(s) has been loaded for your video/graphics card. If in your Device Manager, the Display Adapter has no yellow or red mark and indicates correctly whatever type of video card that you have. Thereafter, you need to go to your Display Properties and enable twin or dual view.
Should this not work out for you, pls post back with the brand and model of your video card. If it is a built-in version, post the make and model of your PC.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 03, 2008
    Sergeant:
  • 313 Answers
Configuring your displays
Connect your second monitor, and then restart your computer so that it detects the new monitor. Once you have restarted your computer, you'll need to adjust your display settings by following these steps:
1.
Click the Start menu, and then click Control Panel.
2.
Click Appearance and Themes, and then click Display.
Once you connect your second monitor, you need to adjust your display settings.
3.
In the Display Properties dialog box, click the Settings tab.
4.
Click the monitor icon labeled 2, and then select the Extend my Windows desktop onto this monitor checkbox.
Extend your Windows desktop to your second monitor.
Troubleshooting: If you do not see two monitor icons, your computer might not support multiple displays. First, make sure that you have Windows XP installed. Then, visit Microsoft Update, click Custom Install, and install any available hardware updates. You may also need to visit your computer manufacturer's Web site to install an updated display driver. If you still do not see two monitor icons, you may need to install an additional display adapter, as described earlier in this article.
5.
If necessary, drag the monitor icons so that they are arranged in the same way as the monitors on your desk. Click the Identify button to indicate which monitor is 1 and which monitor is 2.
Drag the monitor icons to match the physical arrangement of your monitors.
6.
Click Apply. Windows XP will activate your new monitor.
7.
Click OK.
A dual monitor setup enables you to view the same image side by side.
Once your monitor is set up, you can use your mouse to grab the title bar of a window and drag it to your new display. If a window does not move when you drag it, double-click the title bar first, and then drag it. Having two monitors will forever change the way you work with your computer. Be creative and experiment with the sizing of application windows and what information you can keep in constant view while doing multiple tasks.
  • 242 Answers
Go to Desktop, right-click, select 'Properties'
Select tab 'Settings'. You should see two boxes with a 1 and a 2 in it. If one of them is greyed out, select it and make sure the checkbox with: "Extend my windows desktop onto this monitor".
Please report back
    Sergeant:
  • 202 Answers
Hello tglb13
Did you have your desktop spanned across two monitors? - both monitors running simultaneously?
Likely you'll just need to go back in to your video configuration and add the missing monitor ("monitor 2").
Your system has likely simply "forgotten" the configuration.
To confirm that this is a video configuration issue, swap the monitor connections on your video card (at the back of your computer).
If the problem is configuration, the previously "missing" monitor will now be working and the other will not.
In other words, the "working" monitor is likely "monitor 1" in your video configuration and the "missing" monitor is likely "monitor 2".
Please, let us know if this response was helpful for you or, of course, if you have any further questions.
Thank you
BJ
I have a SyncMaster 920N Samsung Monitor and today it stops working. The power light is slightly constantly blinking,but the monitor is not turning on,when I m pressing power button. I tried changed power...
A fast blinking power light is an indication that the power supply is in a shorted condition. Parts called capacitors that filter the output power on the power supply board can fail and the power supply will short out causing the fast blinking power light. If you can solder then you can repair the monitor. Here is a link to a repair guide that has pictures and videos showing how to dis-assemble the unit and what to look for and replace to do the repair.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
I hope this helps, if so please rate my solution.
BuddyMc
Jan 06, 2011 | Samsung SyncMaster 920N 19" LCD Monitor
When I press the power button on my Samsung Syncmaster 216BW it goes to source test but does not turn off the monitor
That is main board problem may be the EEPROM is defective could cause of cannot save or store current settings. You need to replace your main board to fix this problem.
Sep 09, 2010 | Samsung SyncMaster 216BW Monitor
SyncMaster 216BW Monitor: it works for 1 hour suddenly the image goes and af...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Samsung monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 16, 2010 | Samsung SyncMaster 216BW Monitor
Power on/off not respond, what can i do ? my screen Samsung SyncMaster 920N
This may due to power supply is not connected properly or power supply itself gone bad. check and repair/replace the power supply may solve your problem.
Revert back for assistance.
Jan 20, 2010 | Samsung SyncMaster 920N 19" LCD Monitor
Hi I have a samsung syncMaster 920N The screen has suddenly gone blank - the power light is showing. I have a second identical monitor and have swapped cables but no difference Is it a repairable fault?...
This happened to me a few months back. I removed all cables and left it for 2 days. Switched back on on it worked fine. That is until yesterday when half the screen went black. I found that my driver was out of date. I have undated the driver but have decided to leave it off and unplugged for another day.
You could try this. You say you have another monitor, i would suggest using it for a few days and the try the old one again.
Dec 05, 2009 | Samsung SyncMaster 920N 19" LCD Flat Panel...
We dont have drivers of sumsung syncmaster 920n
LCD usually doesnt require a driver, it is plug and play
Jul 14, 2009 | Samsung SyncMaster 920N 19" LCD Monitor
Samsung LCD 19" monitor problem
Does the monitor plug into a card or the motherboard socket?
Mar 25, 2009 | Samsung SyncMaster 920N 19" LCD Flat Panel...
SyncMaster 920n Power Cable (?) Issues
I think my monitor power connector broke too
Sep 29, 2007 | Samsung SyncMaster 920N 19" LCD Monitor
Computers & Internet Logo
163 people viewed this question
David Payne
David Payne
