Question about Apple iPod MP3 Player
Disk mode on ipod willnot go off
Tried to turn the hold button on and off and hold the menu and select button did not help. Disk mode still on
  • Apple Master
  • 13,433 Answers
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
If you need more assistance let me know. Good luck.
Posted on Apr 04, 2008
When i turn on my ipod the screen is white how do ifix this
Here are some possible solutions to your problem.
Reset the iPod
  1. Turn the Hold switch on, then back to off.
  2. Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
  3. You may need to repeat the reset several times.
If this does not work, put the iPod into forced disk mode.
Forced Disk Mode
  1. Put your iPod into the charger.
  2. Turn the Hold switch on, then back to off.
  3. Press and hold the Menu and Select buttons until the Apple logo appears.
  4. Immediately switch your fingers to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
Putting the iPod into forced disk mode usually resolves this issue. If it does work, plug your iPod into the computer and connect it to iTunes and reset it. If this still does not work, use the restore feature in iTunes with your iPod. Hope this helps!
Mar 31, 2011 | Apple iPod nano
Tip
How to Put iPod into Disk Mode
Putting iPods with a Click Wheel into disk mode
Before placing the iPod into disk mode, you should verify that it is charged.
Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
on Apr 15, 2010 | Computers & Internet
I switched my nano on and it has come on wth 'Disk mode' and it has never done this before
To turn iPod Disk mode off:
  1. Toggle the hold switch on and off
  2. Press and Hold the Select and the Menu button for more than ten seconds
  3. The normal selection screen should appear, your iPod is out of Disk mode.
Mar 02, 2011 | Apple iPod nano
My ipod nano screen is white and when I try to reset by pressing the menu and select buttons it just goes dark. What do I do??
Welcome to Fixya
Looks like the software just hanged-up on you. Try to reset the Ipod by following the procedures below.
1st option:
If the reset doesn't help, then put the iPod into forced disk mode.
2nd option (Disk Mode):
Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode. If at this point you still have the white screen, restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory settings).
Note: Do not disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes.
Thanks for choosing Fixya!
Nov 11, 2010 | Apple iPod nano
Ipod won't mount, and show in itunes. Ipod 30GB Video will not load songs, pics, or movies. I have a macbook pro, itunes is updated. Ipod will not restore also. I also tried clearing the drive, ipod...
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
  5. Then attempt to restore.
Apr 12, 2010 | Apple iPod MA446LL/A MP3 Player
My ipod displays red x icon and i cant get it into disk mode
Hi
The iPod should be charged before placing it into disk mode. To place the iPod into disk mode toggle the Hold switch on and off. (First set it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons for at least 10 seconds until the Apple logo appears then release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause button until the Disk Mode screen appears. Now connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect". If you are facingg any difficulty in putting the iPod mode into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 10, 2009 | Apple iPod classic 6th Generation Digital...
I Have a 3rd gen ipod and its stuck on the lanuage
Try reseting it. If that does not resolve the issue, put it into disc mode and restore again. If these steps do not help please let me know.
Learning how to reset or restart your iPod:
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Putting iPods with a Click Wheel into disk mode Before placing the iPod into disk mode, you should verify that it is charged. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
May 05, 2009 | Apple iPod nano 3rd Generation
My ipod isn't recharging or even turning on.
try putting the ipod into disc mode before connecting it to your computer to restore. Just in case you are unsure on how to put an ipod into disc mode, I have posted step by step instructions below. This is the only other option to restore the ipod and not need it repaired or replaced.
I hope it works for you :)
Apr 25, 2009 | Apple iPod nano 3rd Generation
Ipod shows the help screen with a website
Try thisout and restore th ipod
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
Feb 08, 2009 | Apple iPod MA446LL/A MP3 Player
Frozen Screen I have a frozen screen which says "Disk Mode", then there is a large "tick" in the centre of the screen, and another message saying "OK to disconnect". Nothing I try unfreezes this - I have...
I do not know which ipod you have, but here are instructions on how to get a nano in and out of DISK MODE:
To turn iPod Disk mode on:
  2. Press and Hold the Select and the Menu button for six+ seconds
  3. Release both buttons when the Apple logo appears
  4. Press and Hold the Select and Play button until the Disk Mode text appears.
If it does not work, you may need to reset your ipod. The following link has extensive instructions on that procedure for many types of ipods.
Good luck my friend!
Dec 28, 2008 | Apple iPod nano
Apple iPod MP3 Player Logo
15 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
