Question about Compaq Presario SR1030NX (DW256A#ABA) PC Desktop
Presario SR1030NX Hard Drive Removal
This computer (Presario SR1030NX) seems to not want the hard drive removed. I can't get at the right side of the hard drive cage because every panel is welded or riveted together, including the hard drive cage itself -- it is not removable.
I removed the front cover, and the hard drive ought to come out, but it's stuck on the right side, somehow. I can't see that side of the hard drive/case except through the tiny holes in the case. So I don't know what is causing it to hang up. I don't want to force it unless I'm sure I know how it should come out.
Does anyone know what I'm talking about??? And what is the solution?
Thanks.
  • JW906 Apr 03, 2008
    I finally figured out what the problem was. The pdf Part Replacement Guide offered by Hollyecho shows that the drive should be easily pulled out through the front... but mine wouldn't. The problem was that there are two tabs on the "hidden" side of the drive bay, which are just cutouts in the metal of the drive bay... these tabs were bent in, pressed into the drive, at a notch in the drive body apparently. This is what was preventing the drive from coming out. It appeared that this was done intentionally - to further secure the drive perhaps - but why it was done on the "closed" side of the unit is beyond me!
    I was able to reach around while looking through the holes in the chassis (under bright light) and permanently bend the tabs away from the drive slot (I used a very tiny screwdriver to do this).
    I hope this helps someone else with this problem.
    JW906
    Problem Solver:
  • 6 Answers
Reg cure stinks try eusing FREE
Posted on Apr 12, 2009
    Sergeant:
  • 313 Answers
Here is the part replacement guide for Pesario SR1030NX:
http://h10032.www1.hp.com/ctg/Manual/c00225000.pdf
It it's instruction is in words and graphic form - it would be the best to solve your solution.
Posted on Apr 03, 2008
If your computer is running kind of sluggish, you can fix it with an easy clean up of your registry. Here's a link to a free scan that works well:
www.your-free-info.com/RegCure
I've used this one and it sped up my computer by quite a bit. Hopefully this helps.
Posted on May 11, 2008
Posted on May 08, 2008
Posted on Apr 27, 2008
How do i set a seagate barracuda 7200 hd to slave
you don't need to setup as a Slave drive like IDE drives. You simply install the new SATA drive on an open port and follow the steps in this thread to format the hard drive. This will allow the hard drive to be used as a storage drive or whatever you plan to use it for.
Guide: If you installed a new disk but the system can't see it
May 11, 2014 | Compaq Presario SR1030NX (DW256A#ABA) PC...
Smart hard drive failure
First get a suitable type of drive which will have be SATA and make sure you have completed a backup of pics, music, favourites and documents also a valid copy of Windows or recovery DVD
1. Position the computer with the front toward you.
2.Remove the two Phillips screws that secure the hard drive cover to the computer.
3. Lift the left side of the hard drive cover swing it to right, and remove the cover.
4. Remove the three Phillips screws that secure the hard drive to the computer.
5. Use the plastic tab to slide the hard drive until it disconnects from the connector, then lift the hard drive up and out of the computer
6. Remove the 4 screws on the cage that holds the drive in place note which way the drive sits in the cage.
7. Is reversal of taking drive out
Oct 05, 2013 | HP Compaq Presario CQ40-330TU
How to remove hardrive from computer
On a desktop computer
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove the power lead from the power in put on the computer
remove the side panels on on our computer you will see 4 screws 2 either side unscrew these
then remove the electrical lead and the sata lead remembering where these are located slide the hard drive out then put your new sata hard drive in placing the leads back to there original position then tighten the screws (do not overtighten)
i was unable to locate your spicific computer i hope this will guide you
http://www.youtube.com/watch?v=qzFB-URV6EM
Replacing a hard drive in a Compaq Presario SR5010NX PC
http://www.ehow.com/video_4978913_install-internal-hard-drive.html
YouTube video install a second ide hard drive
http://www.fonerbooks.com/laptop_1.htm
laptop hard drive
http://www.ehow.com/how_5451891_remove-hard-drive-ibm-notebook.html
Hope this helps.
Nov 25, 2012 | Compaq Presario 5240 (353200-003) PC...
Presario2580us pwers up and fan run but (1) battery wont charge (2) harddrive wont work are these two issues related? if so will removal of battery allow harddrive to run. if so how do i remove...
These two problems could be related in the way that a power surge could have fried the hard drive and the battery. However that is not very likely. Even if that were the case you still have the same problem. A battery that won't charge, and a Hard drive that won't work.
Here is an included link to the service manual for your 2500 series Compaq presario.
http://h10032.www1.hp.com/ctg/Manual/c01122313.pdf
in the manual just check on the removal section, then the sub-section for the battery, and hard drive removal.
I was able to find your battery on-line for $40.
I found several Hard drives online that would fit your laptop. The range was between 40-75$, depending on how much space on your HDD you desire. What you had in your laptop to star with was only 40 gigabytes, or GB. an 80 GB drive would cost you only about 40, while a 250GB would run closer to $75.
Your battery is a flip of a latch, and you should be able to slide your battery out of the Left side of the computer if I am reading the diagrams correctly. Replacement would be the same, but in reverse. Gently slide battery in until flush with outside of computer, then latch shut.
Your Hard Drive is simply using a small Philips screw driver to unscrew two screws from the4 underside of the case. These screws will be about 2 1/2" apart towards the front edge of the computer's bottom. Basically the HDD sits underneath the touch-pad. The old Hard drive that you pull out of your laptop will have a bracket surrounding it, and a Hard drive connector. both the Hard drive bracket, and connector will need to transfer to the new drive in the same way that it was removed from the old drive. Be careful to face the drive up or down the proper direction in the bracket, or the drive probably won't fit. You could even take pictures of the removal, so you have reference for the re-installation.
If this were me, and I had the drive and battery I could do it in 30mt. at most. An unskilled User who took the time to do his/her home-work could do this in under an hour for sure.
Just one last note the proper order for this job would be to unplug the machine, remove the battery, hit the power button for a few seconds(to reduce the risk of electrical surge while working on the sensitive electronics), then switch the hard drive, insert battery, plug in.
I would recommend charging the battery to full the first time before even turning on the laptop, for @ least four hours. Remember the new hard drive will be blank, so you will need to install an Operating system on it. I recommend windows XP home. there should be a sticker with a key code on it on the under-side of your computer. I would hope you would have a XP disc or know someone that can get one for you.
Best of luck my friend.
~Lee-Nuxor~
Aug 31, 2011 | Compaq Presario 2580US Notebook
I need to remove the dvd-write/cd-wrter combo dive but it has some blue clips hold the drive. Seem I have to break the clips. Will I have problem if they are broken. Thanks for anyone'e help.
DONT BREAK....
it's clip on...to hold the drive in the slot....but you may find some screws on the side of the DVD / cd drive which is held to the case of the PC... just remove the screws and remove all the cables and just pull it out....
Apr 28, 2011 | Compaq Presario SR1030NX (DW256A#ABA) PC...
How to i replace my hard drive on a presario 5304?
If you replace your hard drive with a new one, you will have to reinstall your operating system onto that drive before you will be able to use your computer normally.
All the HOW-TO INSTRUCTIONS for your computer are found at the following link:
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_task=useCategory&lc=en&dlc=en&cc=us&dest_page=product&product=93186
First unplug all the cables from the back of your computer and be sure to take note of where they go so you can replace them when you finish.
Take off the side panel from your computer by removing the 2 screws holding it on the back panel of the computer and pulling the side panel firmly backwards. Be sure to lift up up on the big plastic catch if there is one.
Complete details on HARD DRIVE REMOVAL are available at the Compaq Support website at the following link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph03429&tmp_task=useCategory&lc=en&dlc=en&cc=us&dest_page=product&product=93186
Remove / replace your hard drive and cables as per the above instructions.
Once you get your new hard drive installed, boot your computer and go to your BIOS screen.
Repeatedly press F1 or F2 or F8 or F10 during startup before anything shows up on monitor.
Change your BOOT ORDER so that your CD / DVD Drive is the FIRST BOOT DEVICE.
Save changes and exit.
Now you can insert the OPERATING SYSTEM INSTALL DISK and reboot your computer to install your Operating System.
Good luck and please comment back and rate if this was helpful.
Feb 04, 2011 | Compaq Presario 5304 (120969-004) PC...
When i turn my computer on i get a message that says, disk boot failure, insert system disk and press enter
Your boot file on your hard drive may have been corrupted. You need to start the computer with your operating system disc in the drive, and hopefully it will be able to repair your operating system. good Luck!
Jul 17, 2010 | Compaq Presario SR1030NX (DW256A#ABA) PC...
Remove hd compaq presario 1621
I think it is the same as HP. When you undo the cover just pull it right out by the small plastic. No screws holding the drive.
Apr 21, 2010 | Compaq Presario Notebook
Compaq Presario SR1030NX fails to start
Sounds like the power supply or motherboard is biting the dust. U may consider power off, open case and clean out the dirt, check U'r connections and if the power supply smells, replace it.
Else replace the pc. When the power supply dies, it usually stresses the motherboard out and it dies later, sooner.
Jun 02, 2008 | Compaq Presario SR1030NX (DW256A#ABA) PC...
Compaq Presario SR1030NX (DW256A#ABA) PC Desktop Logo
457 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
