Here is a link to the original question/problem:
http://www.fixya.com/support/t482342-magnavox_50ml8105d_17_dlp_50
Any analysis would be greatly appreciated.
SOURCE: Magnavox 50ML8105D/17
On e-bay there is one. just type in the m# of the tv and you will find one for about $50.00 (magnavox ballast) in the search window will work also. I need the power supply for this set, so if you happen to find one can you email me at [email protected] thank you and hope I could help.
SOURCE: where do i find the
Take off the speaker screen on the bottom of the set, next to the left speaker (if facing the front of the tv ) there is a plate with two screws, remove this plate and the lamp module is behind it, remove it and replace with a new one
SOURCE: my 50" magnavox 50ml8105d/17 making a knocking
It sounds like you have a bad color wheel. If you are handy with electronics, it is a pretty simple fix. If not, I would suggest you take your set to a qualified service center.
SOURCE: my magnavox dlp tv model 50ML8105D\17 will not turn on
First check the lamp, if not then maybe one of the fans is running poorly. Make sure it is plugged in.
