Question about Haier HTF27R11 27" TV
Haier TV/DVD Combo will not eject DVD
DVD will not unload.
4 Suggested Answers
rommelalilin
  • 2178 Answers
SOURCE: A dvd is stuck in the Haier tv/dvd combo
Disconnect power and then re-apply. If the disc doesn't come out, then the drive either has a bad drive belt or the eject motor is bad - it'll need to be taken apart to fix.
Posted on Nov 08, 2010
KingDWS
  • 1606 Answers
SOURCE: I have a Haier HLC19K1 19" tv/ DVD combo that
If you have tried more than one commercial DVD and are getting the same results then the problem is the player has failed. Actually what happens is the heads go out of alignment and it doesn't have the accuracy to read the tracks any more. This is a typical failure of dvd players in desktop and laptop computers and standalone players. While the heads can be aligned it isn;t worth doing. It was when a dvd or cd player was $1500 but not now.
Unfortunately the only cost effective fixes are replacing the dvd drive or replacing the entire unit. The replacement dvd would cost more than a new replacement tv/dvd combo. So you can buy a new tv or buy an external player ($40ish).
Posted on Feb 02, 2011
gregs_rockin
  • 274 Answers
SOURCE: dvd on tv/dvd combo doesn't work on fairly new haier tv
Dvd players don,t use (Heads) They have a (Lazer) Eye, The tray was probally Knocked out of (Alighnment) End needs to be Adjusted.Or with Haier from my expierance with there stuff,Its like a (Disspossiblle) Liter or (Flashlight) Once they Quit working fire it, The drive motors in there (DVD) Players don,t last to long.,I have seen some only a month old where the drive motor burnt out on them.
Posted on Oct 05, 2012
How touse the DVD on my TV?
My tv problem is vertical section
Haier tv model no 21f19ss
Jun 03, 2013 | Haier HTF24R21 24" TV
Dvd on tv/dvd combo doesn't work on fairly new haier tv
Oct 02, 2012 | Haier HLC15R 15 in. LCD TV TV/DVD Combo
Dvd is stuck in tv/dvd combo
here you can mess the unit up completely if your not carefull,,some of the many different types of system unit have a small hole on the door itself,carefully power on then push a straightened paperclip into this hole,,if you can find one that is,,your only other options would be to use a very flat knife and try to time pressure on the door in conjunction with the power on button the door itself is ,or can be operated by internal cog mechanisms which can break easily--good luck--Davey
Jun 18, 2012 | Haier HLC19R 19 in. LCD TV/DVD Combo
Feb 02, 2011 | Haier HLC19K1 19 in. LCD TV
Nov 08, 2010 | Haier HLC15R 15 in. LCD TV TV/DVD Combo
DVD Stuck in TV/DVD Combo
This may not sound technical, but I stuck the end of a paper clip into the opening until I could feel the dvd.....jiggled it a bit, and out it popped while pushing the eject button!!!
Jun 19, 2008 | Toshiba 14DLV75 14 in. TV/DVD Combo
Help
Ok this is a sure fire way of getting that DVD out. Open up the unit, find the load and unload gear, rotate the gear and that should eject the carriage slide. That's it.
Sep 21, 2007 | Polaroid FDM-0700A 7 in. TV/DVD Combo
Akai cftd15298
What you can do with the set turned off is to open the back of the set and find the DVD load and unload motor, manually turn the load and unload gear on the motor and this should eject the DVD.
Aug 05, 2007 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
DVD will not eject the tray
Open up the unit find the load and unload motor on the DVD carriage and turn it manually and this should eject the tray. You may even have to unscrew the carriage to get to the bottom of it to access the load and unload motor.
Jun 21, 2007 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
Haier TV/DVD Combo will not accept the DVD.
The player has failed, they are not repaired just replaced.
Mar 25, 2017 | Haier DVD100 DVD Player
Haier HTF27R11 27" TV Logo
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
