Question about Zenith H27F36DT 27" TV
Auto program is locked
I have a concierge series tv and when I go to auto program it it shows that it is locked.
I have the master program remote but it will not let me adjust the auto program from the locked setting.
  • tackyt May 11, 2008
    concierge by zenith tv 27 in the auto program channels is locked i cant add channels manually either. wht can i do to unlock this feature i am paying for cable i cant even see. help please, chrislynnj@yahoo.com
  • Anonymous Apr 08, 2009
    Has anyone found a resolution?
top50
  • 134 Answers
SOURCE: Auto Adjust
There are a couple of things that you can try...
1. Setup on Monitor..: check on monitor menu, if the feature auto adj are enable,.try to Reset setting and resetting your display.
2. On windows(xp) desktop click Start > All programs > Startup... See for apps has executed for starting window. if you see "Adobe Gamma Loader" installed, maybe you haven't to saved your gamma/bright setting (it also happen when the first time installing adobe reader/photoshop, etc) you can resetting by "right" click on desktop > properties > click on Setting tab > click advance > Color management. after done, click apply then ok.
if The picture on monitor is upside, do resetting on monitor menu, > select V POSITION. (Vertical)
Hope this be of some help/idea. Pls post back should you need additional information.
Posted on Nov 13, 2007
  • 383 Answers
SOURCE: Monitor flickering and adjustment buttons locked
If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down ... This may also cause a flickering affect.
Distorted or skewed image on monitor. Issue: Distorted or skewed image on monitor.
Cause: This issue can occur from any of the below possibilities.
  1. Windows issue.
  2. Loose or defective cable.
  3. Refresh rate issue
  4. Interference.
  5. Bad monitor.
Solution: Windows Issue If your monitor has a proper display until it gets into Windows 3.x, Windows 95, Windows 98, Windows NT, Windows 2000, Windows ME, or Windows XP please see document CH000121 for software or setting related issues.
Loose or defective cable You may receive a distorted image when the cable is loose or defective. Disconnect the video cable going from the back of the computer and verify that no pins are bent, burnt or broken. Once verified re-connect the monitor cable.
Refresh rate issue If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down or across the monitor slowly or fast. This may also cause a flickering affect. Additional information about how to change the refresh rate can be found on document CH000558.
Interference A distorted image can be caused by magnetic or other types of interference. Verify no speakers, fans or other magnetic devices are close to the monitor.
Bad Monitor If the above possibilities have been checked it is likely that the monitor is bad. To verify this it is recommended that the monitor be temporarily disconnected and then connected to another computer. This can be a friends computer, a work computer, and/or a computer at a service center. You can also help verify a defective monitor by connecting another monitor to your computer. Note: Connecting your possibly defective monitor to another computer will in no way harm the other computer.
Good Luck/Please dont for get to Rate.Thank You.
Posted on Jan 17, 2008
SOURCE: Samsung 731N Auto Adjustment
Hold down the menu key for 5 seconds!
Posted on Mar 29, 2008
SOURCE: auto adjustment?
Press and hold the Menu button until the menu disappears - and you're OSD will magically unlock.
Posted on Jul 31, 2008
  • 20 Answers
SOURCE: my tv wont let me auto program the channels
if you can get to menu to unlock the channels type in 0000 or 1234 or 9999 or 0001 orif this doesnt work you could take back off tv and remove the little battery that looks like a coin out. becareful, this is high voltage in there.........
Posted on Jan 02, 2009
Can I do a Factory default reset on a Zenith Concierge Series H2530Y7 Model Television without the remote control?
ZENITH SC652 Concierge Commercial TV Remote Control buy a master remote then,
  • Press the "Power" button on the Installer's remote control to turn on the TV.
  • 2 Press and hold down the "Menu" button on the remote for about six seconds until the menu disappears.
  • 3 Press the "9," "8," "7," "6" and "CC" buttons in succession. This resets the TV to factory default settings
  • Read more : http://www.ehow.com/how_7393497_reset-zenith-concierge-television.html
    Apr 24, 2015 | Zenith Televison & Video
    Tip
    Polaroid LCD TV Parental lock/unlock
    Program Lock
    Input the default password of 1235, the submenu
    of Parent will display if the password is correct.
    (a) When changing the password, the changed
    password will be updated after four digits are input.
    The word "ok" appears after you input the same
    number twice, if the two passwords are different the
    word "Failure" will appear.
    (b) When All Clear is selected, all programs are unlocked.
    (c) After you exit from the Program Lock menu and switch to a locked channel, the picture and
    sound will be locked unless you input the correct password. The channel will remain unlocked
    until the TV is turned off. After the TV is turned on again, the password must be re-entered to
    view the locked channels again.
    (d) If your program is locked, input the correct password to enter the Auto Search submenu.
    Operating Auto Search will cancel the locked status.
    (e) The default password is always effective.
    (f) Entering the default password allows you to go to the Program Lock menu, then change the
    password while the default password is still effective. This branch menu cannot be entered if a
    wrong password is keyed in, In this case, press MENU to return to the previous menu.
    (g) There will be slight delays while using the Lock All and Clear All functions.
    ● Child Lock
    In Child Lock On mode, the buttons on the TV do not work. A prompt "Panel buttons are being
    locked" will be displayed. However, the remote control buttons will still function. When the TV is
    on and the Child Lock is on, a prompt "Locked, power off after 6s" will appear. Use the remote
    control to control the TV. Otherwise, the TV will automatically enter into Standby mode.
    Having trouble with setting your Parental Controls (V-Chip)?
    The factory preset password is 0000. This password must be used first before setting your own personal password. It is recommended that you keep your personal password in a safe place and away from children. In the event you loose your personal password the master password is 8202. The master password overrides all passwords. The master password can't be changed and should be kept in a safe place away from children.
    on Aug 17, 2010 | Televison & Video
    On menu there is a lock for a choice and is not going to auto scan
    At master TV remote Hard Reset button available. Use master remote to reset your TV or from option menu try to restore setting.
    Oct 04, 2014 | Element Televison & Video
    Zenith Concierge H25C34Y is locked in auto program how do i unlock?
    Main system control memory IC fault. Replace it. Contact any service technician. Gopakumar Gopalan Google
    Aug 07, 2014 | Televison & Video
    We have a zenith concierge tv that was donated to a group home. WE have tried programming it so that the cable tv stations can be used but it has a lock on the auto program and I can't figure out how to...
    You have to purchase the master remote from Zenith or a hotel supply company. This is the only way to gain access to programming the concierge. The remote is currently $24.99.
    Jan 22, 2009 | Televison & Video
    I cannot reset the channels on my TV. It is the Concierge TV from a hotel. Will I need to buy a Zenith Remote from the store to do the channel programming. It says it is locked
    You have a hotel/motel model that cannot be programmed or any of the settings changed without a special Master remote. Sorry, doubt that you can buy one from the store, they are not sold to the public. Contact the hotel where you bought the set and try to get the model number for the remote from them. This is a different number than the model number of your tv.
    Dec 13, 2008 | Zenith C27A24T 27" TV
    My tv wont let me auto program the channels
    Concierge by Zenith Input Problems.
    I had the same tv at my motel and wanted to hook up my Wii. Turning to Channel 999 worked.
    Jan 17, 2008 | Zenith C27A24T 27" TV
    Concierge series 25" wont stay on channel 3
    You have to have the original remote. Then go into the menu under channel set-up. punch in channel 3 press add. The punch in channl 52. then press delete. Or turn on the cable box and go to auto tunnin g and let it do its thing. Im sorry , but if you dont have the original remote with a menu button your going to have to live with your problem. Good Luck
    Jul 30, 2006 | Zenith C27A24T 27" TV
    Zenith H27F36DT 27" TV Logo
    97 people viewed this question
    Top Zenith Televison & Video Experts
    matt martin
    matt martin
    Computer Repairing
    Computer Repairing
    Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
