Question about Dell HP-150SS (HP150SS) 150-Watt Power Supply
HP-150SS WHAT IS THE POSITIVE 5-VOLT OF A HP-150SS
    Sergeant:
  • 202 Answers
Hello diallo
Do you mean which wire is the +5VDC on?
There is an industry standard for coloring of computer power supply wires.
+5VDC is on the RED wires.
HERE is a link on Computer Power Supplies "ABCs" that will be very helpful to you, I think.
Please, let us know if this response was helpful for you or, of course, if you have any further questions.
Thank you
BJ
Posted on Apr 03, 2008
  • B Joan Rapier
    B Joan Rapier Apr 17, 2008
    Hello diallo
    How did it go? Did the information and links I provided you w/ answer your question regarding power supply color wires color coding?
    I DO hope that is the case. :) If it isn't, please, post back here and we'll continue to assist you.
    If it is the case, would you kindly take just a moment to close the problem by assigning a FIXYA rating for my "solution"? I would be very grateful for your generosity and show of appreciation.
    Thank you once again for using FixYa! Have a beautiful day.
    BJ @:)
I own a 2008 GMC Envoy Denali, 2WD. Yesterday the engine would barely idle and numerous lights on the dash came on including the check engine light. I had a friend check the diagnostic codes and it came up...
Five days prior to this, the battery had to be replaced. The engine was started without the pause for two minutes ?????? Where do you people come up with some of this stuff ? Pausing for two min. before starting has nothing to do with it . DTC P0651: 5-Volt Reference 2 Circuit
Some of the engine sensors on your vehicle work off of a steady 5 volt supply by the PCM - engine computer . One of these sensors is short internally bring down the PCM .
Circuit
Short to Ground
Open/High Resistance
Short to Voltage
Signal Performance
Accelerator Pedal Position (APP) Sensor 1 5-Volt Reference 2 Circuit
P0651
P2122
P0651
Accelerator Pedal Position (APP) Sensor 2 5-Volt Reference 1 Circuit
P0641
P2127
P0641
Air Conditioning (A/C) Refrigerant Pressure Sensor 5-Volt Reference 1 Circuit
P0641
P0532
P0641
Camshaft Position (CMP) Sensor 5-Volt Reference 1 Circuit
P0641
P0340
P0641
Engine Oil Pressure (EOP) Sensor 5-Volt Reference 1 Circuit
P0641
P0522
P0641
Fuel Tank Pressure (FTP) Sensor 5-Volt Reference 1 Circuit
P0641
P0452
P0641
Manifold Absolute Pressure (MAP) Sensor 5-Volt Reference 1 Circuit
P0641
P0107
P0641
The Crankshaft Position (CKP) Sensor 5-Volt Reference 2 Circuit
P0651
P0335
P0651
Throttle Position (TP) Sensor 1 and 2 5-Volt Reference 2 Circuit
P0651
P0122, P0222
P0651
That's why it wasn't running good ,an lights lit on the dash. Your best bet , take it to GMC dealer .
No where in GM service info does it say after replacing the battery that you need to wait two min. before starting .
Position the positive battery cable (1) to the battery.
Tighten the positive battery cable bolt.
Tighten
Tighten the bolt to 15 N·m (11 lb ft).
Connect the negative battery cable. Refer to Battery Negative Cable Disconnection and Connection .
Caution: Unless directed otherwise, the ignition and start switch must be in the OFF or LOCK position, and all electrical loads must be OFF before servicing any electrical component. Disconnect the negative battery cable to prevent an electrical spark should a tool or equipment come in contact with an exposed electrical terminal. Failure to follow these precautions may result in personal injury and/or damage to the vehicle or its components.
Aug 02, 2017 | GMC Cars & Trucks
How can i hook up a car stereo in the garage without using a car battery, and get the same juice as far as wattage and power???
Wire a 12 volt AC adapter to it. Connect the power to the positive wire, & the ground to the negative wire. If it's a low power unit a 1 amp adapter will work. If it's a high powered unit you might need a 12 volt 5-10 amp adapter designed for monitors, TVs, monitors, & some laptops. Beware some laptop AC adapters can be 16-36 volts. Make sure you use a 12 volt one, & know which wire is positive, or you'll burn it out.
Jul 08, 2015 | Cars & Trucks
Need a wiring diagram for the starter solenoid. I have a 5 volt drop from battery to solenoid actuator terminal.
One main power lead to starter positive terminal(large one). One small wire to the s terminal(This is the start/run wire that powers vehicle. If you have a 5 volt drop then either the connection are poor and need cleaning or the positive cable from battery to starter is corroded and needs replaced.
Jun 04, 2015 | Cars & Trucks
Which side is positive on a ts a1365 speaker?
Take a 9 volt battery, 0r Evan a 1,.5 volt battery will work, Hook up to the termanals on the speaker ,When the cone draws in ward you no you have it hook up right,
Dec 05, 2012 | Pioneer TS-A1365 Car Subwoofer
1996 jeep cherokee 4.0 litre petrol turns over but not start
the dist and injectors work on a 12 volt feed.....the 5 volt feed comes from the powertrain control module but it is possible that one of the sensors are grounding it out. until it acts up again it will be hard to locate. are you sure the 5 volt feed wasnt there. it may just be a bad crank sensor or dist pickup plate causing the no start
Dec 25, 2008 | 1996 Jeep Cherokee Country
Compaq power supply HP212 (old)
If connector have two big brown wires (pins 1 and 11) and a small brown wire (pin 2). then short circuit the small brown wire with a big brown wire (pins 1 and 2).
Also short circuit the small black wire (pin 16) with a big black wire (pin 17).
Ps. The Power Supply needs a minimal load ex: 1A.
Dec 04, 2007 | Dell HP-150SS (HP150SS) 150-Watt Power...
150 W ATX Power Supply HP-150SS
All you have to do is connect the green wire (normally thinner than the rest of the cables) to any black wire. This can be done easily with a short piece of wire. If the power supply doesn?t immediately turn on (within 2 seconds) remove the wire, you may have connected it to the wrong wires, although most power supplies won?t allow a short to damage the unit. Once on, the power supply isn?t loaded so the voltages won?t be as stable as if they were used in a full PC, however it?ll be sufficient for most uses. It?s not a good idea to leave a power supply on in this fashion for a long period of time too."
Aug 10, 2007 | Dell HP-150SS (HP150SS) 150-Watt Power...
Computers & Internet Logo
184 people viewed this question
Alun Cox
