Printer part I need to replace a damaged power cord on an HP6310 All-in-one Office Jet Printer/copier and I can't find a site or anywhere to get one. I tried HP site but they don't have a place to order a part.
  • 555 Answers
Try using HP's PartSurfer website to find the power cable. It has the complete inventory of all HP parts, searchable by part number or model number.
You can get the part number off of your old power cable, or search by " Officejet 6310 ". There are actually several sub-models of the Officejet 6310: Q8061B, Q8063A, Q8062A, Q8077C, Q8061AR, Q8061A, etc. Look on the barcode label on the back of your printer to find your specific sub-model number. (They probably all use the same power supply, but it's best to be as precise as possible when looking up the part.)
Posted on Apr 03, 2008
  • Matt Jurach
    Matt Jurach Apr 08, 2008
    *Please rate this solution if you find it helpful!*
I own officejet 4215v it is stuck in the fax mode and I can't get it to go to print.
Hello and Welcome to FixYa!
Sir this problem is due when by chance the Fax Mode is selected as default. To get to the print mode you need to change the mode to print. Try the following:
Click Start >> Print and Faxes (if you are using Win Xp) or Devices and Printers (if you are using Win 7) >> There will be the list of HP Office jet 4215 Fax and HP Office jet 4215 Printer. >> Right click on HP Office jet 4215 Printer ans Select as "Set as Default"
Now try to print again. If printer is still struck on the Fax Mode then possibility is that your printer is locked, In this case you need to Reset the printer: Follow the given steps to do this:-
  • Unplug the power supply from the rear of the product.
  • Unplug the power cord from the electrical outlet, power strip, or surge protector.
  • If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
  • Wait 15 seconds.
  • Reconnect the power cord to the power module.
  • Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
Now turn the printer On and now try to print again. I hope if first solution do not work then this will solve the problem. But if still it struck to Fax Mode then its may be a technical or hardware issue, You need to contact HP Support Center to solve your problem.
I hope this solution helps you and you have clear picture in your mind
Let me know if you have any confusion in your mind.
Sir, Your Rating as Five Stars for this solution and Words of appreciation as Feedback for me will be really esteemed
Thank You for taking my service
Concerned: Muhammad Uzair Team : FixYa
Nov 11, 2011 | HP Officejet 4215v All-in-One Printer
I need cable from hp 5610 all in one to dell pc, i bought 5610 office jet all in one . i have a dell 4550 pc . i need everything it takes to hook together
Head over to the HP Parts Store site located at
Enter the Part Number 8121-0868 which is for a USB cable compatible with your printer. It looks like it's priced at $19.
Assuming you have the power cord, this should be all you need to get it working.
Jun 04, 2011 | HP Officejet 5610 All-In-One InkJet...
Hi how to solve hp 5610 office jet error 0*d0620130 reset power
You need to reset the printer
Follow the steps :
1. Unplug the power cord from the back of the printer while the printer is on
2. Press # and 6 button at the same time.
3. While holding them plug in the power cord
4. You will see a message on the printer Semi Full Reset - Release the buttons
Note : While doing it you will lose all the numbers which you have saved in your printer
Jan 07, 2011 | HP Officejet 5610 All-In-One InkJet...
HP Office Jet 7210 Scanner won't work
Try this simple step,
Disconnect the power cord from back of printer ( while printer is on )
wait for 10 seconds and connect it back
let the printer Initialize and Try to scan.
IF this does not work, you probably just need to uninstall and reinstall the drivers.
Jul 06, 2010 | HP Officejet 7210 All-In-One InkJet...
Message `no scanner options' although I have just
Disconnect power cord from back of printer ( while printer is on )
while holding the power button connect the cord back.
try to scan
Jun 18, 2010 | HP J4680 Office Jet All-In-One Printer
Need a power cord where can i get one in the support section will have your ac adapter. The best price, right from the source.
Feb 09, 2010 | HP OfficeJet J4580 All-In-One Laser...
Power cord light comes on but printer wont. HELP!
copy and paste the below link in the address bar of the internet explorer and follow the steps and you'll will know what to do
Oct 11, 2009 | HP J4680 Office Jet All-In-One Printer
HP office jet 4315v No power. Yesterday I printed several times. Today there's no power to the printer. I have pressed the off-on button, the printer does not power up.
Might be the power cord, try using a different one. I that doesn't work then you might need to try and plug it in a different outlet.
If that fails, replace the printer.
Jul 10, 2009 | HP Officejet 4315v All-In-One InkJet...
HP office jet 6210 scanner failure error
have you tried to reset the printer?
(Take the power cord off hold # 3and then turn the printer on.)
That is an initial position problem
Parts are no longer available for this model from HP...
Jan 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Power cord is damaged and needs replaced
i am not in any way offiliated with the following website but it was the first one to come up in google,Printer,Part,09572119.aspx
bearing in mind the part is quite cheap there must be lots of places you can obtain a spare/replacement power supply...and if they are sold seperately the clerk that gave you the advice about not being able to replace just the power cord must have been having a bad day/year/lifetime
Jan 07, 2009 | HP Deskjet F340 All-In-One Printer
88 people viewed this question
