Question about Apple iPod nano
Apple ipod 20gb
Hi my apple ipod 20gb just shows www.apple.com/support/ipod pls help . cannot connect to pc.
  • 2 more comments
  • the balla Jul 24, 2008
    it doesn't start, it alway says www.apple.com/support/ipod,
    it charges but it doesn' start
  • hopi Jul 26, 2008
    When I plug to ipod into the computer it doesn't show up on itunes
  • Anonymous Mar 12, 2014
    Just trying to see my Apple,I Tunes,account I don't I need to see what is paid and what is still out.Help
  • Anonymous Mar 29, 2014
    My ipod won't charge?
  • 405 Answers
Try a reset:
How to reset iPod To reset an iPod with a Click Wheel, including:iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation)iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds.
You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Hope this helps
check out my blog at:
http://www.pchelpforanyone.blogspot.com
Posted on Apr 03, 2008
  • Anonymous Apr 03, 2008
    Why did you rate this inappropriate? I was trying to help you, be more specific about your problem, did you try a reset already and it didn't work? Or are you to stupid to read my responce and try it?
SOURCE:
Ipod classic 160gb keep saying www.apple.com/support/ipod
no ****. point out the only thig any bumb [email protected] would do. you are a god. Well done
Nov 16, 2009 | Apple 20gb Ipod Mp3 Player With Click...
My grandson gave me a apple 20GB U2 IPOD I HAVE NOT GOT A CLUE HOW TOUSE IT
You will first need to download itunes from the apple website at www.apple.com/itunes once installed open itunes and then connect your ipod to the computer. Through itunes you will now be able to put your music on your computer and then transfer it to your ipod.
At the apple website you will also be able to download a manual for your ipod see http://support.apple.com/manuals/#ipod
Hope this helps.
Oct 27, 2009 | Apple Audio Players & Recorders
Ipod shows www.apple.com/support/ipod, makes strange noise
If your iPod is making strange noises, you have a broken hard-drive. They're quite easy to replace though and I'll be able to guide you, if you can source the part.
Sep 27, 2009 | Apple 20gb Ipod Mp3 Player With Click...
My ipod have no power and it said go to www.apple.com/support so i did.
hi guys i have ipod 20GB when i switch it on it said to www.apple.com/support so i did. hmmm when i was going to store it's fall on the ground while am looking to my ipod it's works and said SELECT a LANGUAGE wowowowooowowowowowowoo it's fine   try to drob it   about 40cm   make the screen under
Apr 08, 2009 | Apple 20gb Ipod Mp3 Player With Click...
Can't use my ipod 20gb
Can you charge it? If so fully charge it and then connect it to the computer and reset/rebot the ipod and see if that helps, if you can't charge it just do the same thing.
Dec 11, 2008 | Apple 20gb Ipod Mp3 Player With Click...
It says www.apple.com.support/ipod
my ipod says just showing the apple icon..it doesnt start
Sep 28, 2008 | Apple 20gb Ipod Mp3 Player With Click...
Ipod 20gb
Temperature is a huge factor in the battery life of an ipod. Excessive heat and cold can kill a battery almost instantly in some cases. A 20GB is a bit antique anyways and even if you fix the battery, the hard dive is sure to follow. Hard drives are only designed to last about five years and then then wear out. I would recommend an update but you can try fixing the battery.
Aug 26, 2008 | Apple iPod MA446LL/A MP3 Player
Apple 20GB IPOD 4th generation corrupted
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
If you need more assistance let me know. I'm here to help.
Mar 18, 2008 | Apple iPOD 20GB Toshiba Harddrive for Gen...
Apple iPod nano Logo
432 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
