Plese hel me
When i format my cmputer ,after finishing coping of file and when it inter to graphical installation it show message "set up is forced to stop installation"
    President:
  • 778 Answers
If this happens after the format has successfully completed? Then you should get a prompt to "Retry, Skip, or Cancel" if while copying files, in which case you can try the "Disk Swap" technique. Which is basically ejecting the disk drawer and inserting it again. In the situation I described above the technique I just mentioned works about 9 out of 10 times that I have encountered this situation. At the worst, the copying of files won't resume until you click "Retry", but usually just resumes on it's own. Though you didn't mention which Operating System you are trying to install, I assume it's Windows as that is the one I have had this issue with. You may also try a different Operating System installation CD/DVD, as the disk your using might have damaged area.
I noticed you mention that it stops at Graphics installation, is there more than one Graphics Card installed in this PC? If so you may want to remove the added card until you get through installing your O.S. if nothing else works.
Posted on Apr 05, 2008
How to fix format Error: not a PDF or corrupted
What else do you think it could be but a corrupt file? Two programs say the file is corrupt....the file is corrupt. Have them resend the file if you can, otherwise it's lost.
Jun 17, 2015 | Databecker PDF Producer for PC
Can i change a avi file with ac3 audio to mpeg audio
I suggest you can try kigo video converter free for mac. It can convert almost all popular video format, including mp4, avi, flv, 3gp ect.
May 30, 2013 | Media Cope
Import problem
the first thing I suggest you find out is if project 5.2 allows you to import the file from fuity loops 8 in the source format. keep in mind that as versions get upgraded backwards compatability inter-vendor compatability or format compatability in genera may be compromised along the way.
I would suggest to try to save your file from fruity loops 8 in another format that may be compatible with project 5.2 or simple save the same file in all formats avaliable and try one by one in project 5.2 and see if you get the file to play properly.
good luck!
Apr 21, 2010 | Cakewalk Project 5 Workstation (cakp51)
Pendrive not work
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
IF the above method is not work
Try to format in other operating system like windows vista or in windows 7 because in vista and 7 you can force format your pendrive
Jan 30, 2009 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
The games that worked before do not work now means after i formatted the computer ,when i instaled the software of graphic card it shows 128mb now and before formatting it was 256mb
reinstall the software
did you format using a different os
did you have the system opened for any reason that could have caused anything to come lose
Jan 12, 2009 | Nvidia G-Force FX5200 256M DDR 8X AGP...
Displaying write protected while loading and deleting files
Dec 11, 2008 | Transcend (589307) Media
ERROR MESSAGE
remove rests of older installations from registry:
search for "seiko" and remove everything you will find.
reboot + run setup
Nov 12, 2008 | Seiko Smart Label Printer 100 Thermal
E-studio 28 copier
You may hve to adjust the finsher to close with out any force. There has to be a inter-lock switch that has to be closed to show that the finisher is closed.
Jul 15, 2008 | Toshiba e-Studio 35 Copier
Sandisk sansa problem
It isnt a fat or fat 32 player..It is a mp3 and or a wma player. And you could be missing the proper device driver depending on your computers os..Pre 2000? file compression file format
Jun 29, 2008 | Mach Speed TRIO Onyx MP3 Player
This error message may largely be due to the corrupted Music Database file that the Sansa M240 creates to maintain an information pool on the music files downloaded to it. Normally, if you are unable to completely format the player in Windows Explorer, there are still 2 other (and actually, more recommended) options that you have: (1) Switching the M240 to MSC mode and formatting in "Disk Management". You can get to this window by right-clicking the "My Computer" icon and selecting "Manage". Make sure that you use the FAT file system to optimize the 1GB memory (2) Switching the M240 to MTP mode and formatting the player in Windows Media Player 10 or version 11. The mode of the M240 can be changed by accessing the menu and going to "Settings", then choosing "USB" In general, formatting the player in "Disk Management" is more effective than formatting it in Windows Explorer. Also, it would be a good idea to upgrade the player's firmware to the latest version via the SanDisk website: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 I hope this helps. The M240 is a great player.
Apr 20, 2007 | SanDisk Sansa m240 MP3 Player
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
