Question about Hitachi FDX Series 43FDX10B 43" Rear Projection Television
Blue convergance on Hitachi 43FDX10B
Hello Techman,
This is a 2nd go round with this problem for me. Last time it was under Svc Agreement and covered. The tech explained it as a common problem. I'm rather experienced in electronics repair (25 yrs. avionics, CAT scanners & MRI's). I just need to know what parts to replace and what sort of calibration may be necessary. Would it be easier and better to replace the entire blue convergance PCB, or the discreet components. Please guide me with part numbers and where to access them.
Thanks,
Mike Vos
  • youngweezy Jun 07, 2008
    I have blue shadows on screen. I have never repaired a T.V. Is this a simple fix? How much would this cost me?
    Genius:
  • 1,694 Answers
Replace both STK IC's.....use kit # X480293....any other parts
will fail prematurely..................After replacing convergence IC's
activate Magic Focus & you are usually done.................T.
Posted on Apr 21, 2008
Screen is bliry and has a few blue lines kind of like a outline
This is a common problem called convergence, I will attach a few photos of typical convergence problems.
In your set it is a fairly easy repair but does require being able to get at the two convergence chips.
Parts cost will be under twenty dollars (I can tell you best place to find them)
If you are able to solder let me know and I will assist you.
SD TECH
Nov 26, 2010 | Hitachi FDX Series 43FDX10B 43" Rear...
HItachi 43FDX20B Rear Projection TV Convergence Problem
Replace both STKs Use StK 329-180s if set is using110s,120,150s, I havent heard of anyone yet getting shocked from replacing ICs.
Feb 09, 2009 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi Projection TV will not turn on just blinking power light
There is a board on the right side of the tv called the convergence bd
There are little connectors that are on the left of the board
the last one is the power to the convergence Ic's
That is the one that is closest to you. they are little black conectors with wires in them
Carefully lift it up
Then plug the tv back in and see if it fires up
If it does do not run it long
just enogh to see the tubes light
then shut if off
If it goes on
your convergence ic's are Shorted
They have a kit for this tv it is available through local parts distributors
If you can't find it locally just Google HITACHI CONVERGENCE KIT
If you are not good with de-soldering and soldering do not attempt this repair. Remember to replace all the resistors in the kit
If you are not sure about doing this repair you should have your local tv guy do it for you
If it does not go on then I would suspect the regulator in the power supply But
Most of the time it's the ics
Feb 08, 2009 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi TV 43FDX10B has yellow line with blue curve line above it
It sounds like your convergence ic's are messing up
Jan 27, 2009 | Hitachi FDX Series 43FDX10B 43" Rear...
My picture just started having doubleimage like shadowing
T
Dec 03, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Blue convergence
Thats the classisc sign that you need to replace both convergence ICs. You will need two Convergence ICs STK392-120 and then six resistors they are RK42 3.3 ohm 1watt, RK46 1.5 ohm 1watt, RK50 2.7 ohm 1watt, RK54 1.5 ohm 1watt, RK58 3.9 ohm 1watt, RK62 1.8 ohm 1watt. You can get replacement ICs and resistors at the following link and they provide free instalation instructions with pictures so you can repair the set yourself. Heres the link.
http://servicemanuals.vstore.ca/
Jul 10, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
SEEING DOUBLE IMAGE
replace both convergence ICs they are STK392-110 you can get replacements at the following link with free instalation instructions with pictures.
Jul 01, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
43FDX10B working Great until Time Warner installed cable box
try connecting the box to a different input
also try connecting another device (like a VCR) in place of the box to see if the problem exists without the cable box
Jan 13, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi 50V500 tv blue shadows
If it's a ghosting problem that looks like this:
it's probably something you can correct yourself...
Nov 21, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Chirping noise and flashing front power light.
Theres a short somewhere in the set. Most likly the HOT is shorted or the vertical IC has caused this in the past. In one case I had shorted convergence IC cause this symptom.. This set is solid state and there are no user serviceable parts inside so please call a trained tech to assist you with this problem Good Luck
Aug 17, 2006 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi FDX Series 43FDX10B 43" Rear Projection Television Logo
109 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
