Question about HP iPAQ RX3715 Pocket PC
Hi friends, when i turn-on my Ipaq Rx-3715 and enter in the aling procces, this become cyclical and don´t permiss to acces to programs, please somebody know how to fix this problem, thanks
  • madmixcsp Apr 13, 2008
    I have the same problem .
    Anyone has a solution ?
    I have already chage the LCD screen (with touche screenà and the problem still occurs.
    Thanks for your help
  • ramonsao May 22, 2008
    I do have the same problem, the align screen utility will help for a while, but later, the screen will go out of order. any help?
  • 164 Answers
If I understand correctly your problem, the touch screen of your PDA is not working.
Well, this is a common IPAQ failure. When happens, the only options to repair it are:
1. Soft reset of the PDA. If still does not work, then go to next step.
2. Replace the top digitizer glass.
It requires a very skillful person to do it. If you have not experience with fixing electronic devices, then I do suggest you to send it to repair.
Besides that is necessary to open it, you will require a soldering iron, and desolder the digitizer part and remove it from the LCD screen, which if is not done properly with the right tools, it's easy to damage the LCD screen assembly.
Also, if it's not opened right, is possible to damage permanently the mainboard if is bent or warped.
Also, even though there are a lot of cheap digitizer replacement parts on-line (mainly from China), they have a compatibility issue that prevents to use them in the RX3715 (or RX3115) PDAs.
I have nothing against Chinese manufactured parts, but after buy around 10 digitizers in the last couple of years for different Ipaq PDAs, I found out that only 3 worked fine, so I know what I am talking about.
Best regards,
Posted on Jul 24, 2009
Dell Photo 964 All in One Printer
first u see cartridge is ok or u can install a new cartridge then aling from both the side first u give print of aling page and then scan the aling page i think this well solve the problem
Aug 19, 2009 | Dell Photo 964 All-In-One InkJet Printer
Download driver for hp ipaq rx 3715
You can download the drivers for your hp ipaq by clicking on this link.
Under the window it will open the extreme bottom there is a download link.
Jan 29, 2009 | HP iPAQ RX3715 Pocket PC
Hp ipaq 3715
Hopefully you can do a warranty repair, I'm pretty sure the main board is damaged since a hard reset should have taken you back to the factory defaults.
Dec 10, 2008 | HP iPAQ RX3715 Pocket PC
HP iPaq 3715
is this windows compliant and if it is in the control panel check to make sure that your sound that you use is default set some times this can lead to a no sound usuage
May 28, 2008 | HP iPAQ RX3715 Pocket PC
I have a hp Ipaq h2200 pocket pc
Hello :-) I have a Ipaq 4350 and the same thing happened to me. one day I hard reseted it and when it came to the point when it asked me to align the screen it froze and wouldn't move at all. I found out that it was screen that got damaged somehow. And I think your screen is damaged too. I'd recommend calling HP.
Apr 10, 2008 | HP iPAQ H2210 Pocket PC
IPAQ Rx 3715 Internet settings~ conectivity problem
I have a few thoughts.
Occasionally, for no apparent reason, the ipaq will "forget" your password. Try re-entering it.
The other option is to try a program called Kasuei Hitchhiker. It is a more powerful and easier to understand interface than the normal ipaq one. you can download it here.
Hope it goes well! I'll try again if this does not work!
Aug 29, 2007 | HP iPAQ RX3715 Pocket PC
Ipaq totally dead after leaving it in my car for two weeks, temperature down to -6C
Its possible (but not likely) that when you took it into a warm room condensation built up inside it. Try removing the battery, memory cards and letting it sit in a warm, dry environment for a few days and try again. If nothing changes I suspect that a component has failed, but -6F is still within the operational range of commercial electronics. If your device is still in warranty then I would call HP up and ask for a warranty replacement. Let us know if you have any other questions and please don't forget to rate this posting.
Feb 12, 2007 | HP iPAQ RX3715 Pocket PC
HP iPAQ RX3715 Pocket PC Logo
127 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
