Question about Kenwood Sirius KCA-R70FM
I NEED ACCESSORY # KCA-iP300V
WHERE CAN I GET IT IT!
    New Friend:
  • 113 Answers
If you e-mail me at [email protected] i can get it for you -no problem
Posted on Apr 03, 2008
SOURCE:
Need a manual for a kenwood RC527
Do you mean a Kenwood KCA-RC527 remote? The documentation for this is available from Kenwood EU: http://www.kenwood.eu/products/car/accessories/misc/KCA-RC527/ . The direct link to the manual is http://images.kenwood.eu/files/prod/528/5/KCA-RC527_(EN).pdf . Unfortunately even though it is labeled EN, this copy is in French.
I can't seem to find another manual on the Kenwood site. (I even checked the U.K. specific site.)
I hope this helps.
Jul 25, 2011 | Kenwood Car Audio & Video
I plug my ipod to the stereo but my stereo screen still says discconected
you have to go to the kenwood site and download the firmware update go to this page http://www.kenwood.com/cs/ce/mm/firmware/2008/eng.html
after you download the file unzip it and burn it with either nero or roxio, as a data file insert the cd on your kvt-512, if it reads DISK ERROR, press the reset button on the front of the stereo, once the screen comes back up select the DVD function, the system update should start from there. let it finish once it does then you'll be able to plug in your ipod. oh and ofcourse for this you should know that you need the ipod adapter, depending on what you want to do with it for instance i have the KCA-iP300V which allows me to view videos from my ipod as well.
Jan 27, 2010 | Kenwood KVT-512 Car DVD Player
No sound on ddx 514 kenwwod..when hooked up ipod to usb??
This is a faily simple fix. First of all, this USB will not be able to playback audio from an iPod or iPhone without using the correct cable. The cable needed has both USB and an audio plug on it. Here is a link to the Kenwood cable you will need:
http://www.kenwoodusa.com/Car_Entertainment/Accessories/KCA-iP200
If you would like playback of iPod video, you will need this cable:
http://www.kenwoodusa.com/Car_Entertainment/Accessories/KCA-iP301V
A local authorized Kenwood stereo dealer should have these in stock. I hope this information was helpful.
Sep 08, 2009 | Kenwood DNX7100 Car Video Player
Kenwood KVT-512 iphone compatibility
Just ignore the airplane mode prompt and if your wiring is correct everything should work.
With my BMW I had to connect both the solid blue (pwr ant) wire and the blue with white stripe (p conn) to the solid blue wire from the factory harness.
It isn't obvious that either of these are needed as the KVT-512 has it's own power supply but the way most factory power amps are installed the power from the KVT-512 is not used and the car manufacturers power amp needs to be turned on.
If you are listening to the radio the pwr ant wire will turn on the power amp, this didn't seem obvious because the BMW doesn't have a power antenna. And when you are using the DVD player or the iPod connection you need the P Conn wire to turn on the car power amp as the ant pwr is disabled because you are no longer using the radio and Kenwood assumes you will not need the antenna so no power to this lead.
Solder all three wires together and you should have sound all the time.
Jul 01, 2009 | Kenwood KVT-512 Car DVD Player
How do i connect my itouch to kenwood kvt-512???
Hi there! You need a Kenwood KCA-iP300V iPOD VIDEO DIRECT CABLE.
Feb 09, 2009 | Kenwood KVT-512 Car DVD Player
Cannot connect ipod to KVT-522DVD. I am using the KCA-IP300v. I have updated the firmware to 1.4.0. But I still cannot get control of the ipod
Hello. Thanks for everyones help. I went around to a dealer to explain the problem and they spotted that the connection lead was not a genuine one. I had been missold this item as being a genuine item. I bought a geniune lead and everything works fine now.
Thanks once again.
Paul
Sep 26, 2008 | Kenwood Audio Players & Recorders
KENWOOD KVT-729DVD & KCA-BT100 BLUETOOTH + KCA-IP300V
Try this. This is the Kenwood support. Hope this helps. :)
By Phone
(310) 639-9000
or toll free 1-800-KENWOOD (536-9663)
Jan 13, 2008 | Kenwood KVT-617DVD Car DVD Player
Kenwood Sirius KCA-R70FM Logo
29 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
