8GB G.Skill F2-8500CL5D-4GBPK in Gigabyte GA-P35-DS3L rev. 2.0
Motherboard: Gigabyte GA-P35-DS3L rev. 2.0
BIOS: F8b
CPU: Intel Core2 Quad Q6600 (2.4GHz 8MB Cache 1066 MHz FSB)
Memory: G.Skill F2-8500CL5D-4GBPK (2x)
I’m trying to install two sets of the above memory for a totalof 8GB of ram in the above motherboard. When I install only one set (4gb)everything works fine.
I’ve followed the procedure outlined here (http://www.gskill.us/166.pdf page 9),but when I’m installing all four sticks for a total of 8GB, the motherboardwon’t even post. This is very frustrating.
Canyou offer any help or suggestions?
  • PapaStahl Apr 03, 2008
    Thanks. I have four identical sticks of 2gb each.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 107 Answers
If they are not a matched pair it will not work. If you have two sets of matched pairs. Each pair will have to go into the right pairing slot. Example one set you go in slots 0 and 2 and the other in slots 1 and 3. If you have stickers on the memory sticks look for a group of numbers and letters one group will match it's mate.
Posted on Apr 03, 2008
Can the motherboard asus p5vd2-mx admit a q6600?
The Q6600 will physically fit (LGA775) that Motherboard but it will probably not work. Attached is a list of supported processors and it looks like this motherboard does not support Kentfield based processors.
http://www.cpu-upgrade.com/mb-ASUS/P5VD2-MX.html
Intel Core2 Quad Processor Q6600 8M Cache 2 40 GHz 1066 MHz FSB...
Jan 17, 2017 | ASUS Computers & Internet
WHAT IS THE APPROPRIATE CPU FOR GIGABYTE GA-965P-DS3
This is a socket LPA 775 motherboard, it will accept almost all core 2 / quad core intel cpu's, here is the full list from gigabyte.
(you may need to unpate the bios for some CPU's)
http://ee.giga-byte.com/products/mb/cpulist/ga-965p-ds3_20.html
Sep 01, 2010 | Gigabyte 965P-DS3 (GA965PDS3) Motherboard
Ga n650sli ds4l and intel core2 quad blackout when i restart
You need to reset your computer bios back from its original settings. While turning on your computer keep pressing the del key on your keyboard until you get to the BIOS utility screen. Select the BIOS default option and then save settings and exit.
Dec 18, 2009 | Gigabyte GA-N650SLI-DS4L Core 2 Quad...
Gigabyte ga-p35-ds3l (2.0) will not flash bios from usb. don't have floppy. can save current bios to usb, and will read new bios however I get no prompt to replace current bios. what should I do?
first never flash your bois in windows it is not good for the mb, restart floppy is the best way, so get a stiffy drive and do it the pc, hope u downlaoded the never bois, at the post screen check to c if there is a flash option f8 or sumthing then from ther u will be directed
Oct 07, 2009 | Gigabyte GA-P35-DS3L Motherboard
I have a GA-EP35-DS3L/S3L Motherboard and i want to update the BIOS driver.
Hi go here and insert the motherboard you have, there is a slight difference between the GA-EP35_DS3L and the S3L. Download your link and follow the instructions that come with it.
Click Here
Hope this helps
Sep 25, 2009 | Intel D850MV Motherboard
I have a GA-P35-ds3l mobo that hangs at boot for
Had a similar problem. Eventually my SATA drive failed. Had to rplace & re-install. Now boots fine. Suggest you try another boot drive to see if you have a similar problem.
Sep 10, 2009 | Gigabyte GA-P35-DS3L Motherboard
Motherboard driver for ga-81845gv
hi euroexpress.. pls to use this link http://download.cnet.com/ and search for your motherboard driver... just type your motherboard type and number... thank you
Jul 13, 2009 | Gigabyte GA-P35-DS3L Motherboard
I have gigabyte series g31 m-es2L i want use memory pc 5300.... it's support with this mainboard ???? tx pls reply to : it_mid@yahoo.com
First, clarification: the closest Gigabyte model is GA-G31M-ES2L... there is no "g31 m-es2L"
For this kind of question the easiest way to find the answer is from the manufacturer: Gigabyte
A quick search of their products results in:
http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ClassValue=Motherboard&ProductID=2889&ProductName=GA-G31M-ES2L
which states that up to 800mhz DDR2 (PC6400) is supported
( 667mhz (PC5300) is also supported. )
Generally with motherboards, if a higher speed of memory is supported, the lower speeds are also supported.
PS: mhz times 8 yields the PCxxxx number, PCxxxx divided by 8 yields the mhz number
Feb 09, 2009 | Gigabyte Matx Intel G31 775 DDR2-800...
P35 Neo2 Motherboard Jumpers
a quad Q6600 is manufactured @ .273 overclocked from the factory. at no time should this cpu ever be overclocked anymore unlessd you are using a watercooling system that keeps the cpu @ 69 degrees for stability. anything else will burn it out. lala linda
May 31, 2008 | Intel Motherboard
Computers & Internet Logo
959 people viewed this question
David Payne
David Payne
