Question about InFocus ScreenPlay 4805 Multimedia Projector
Infocus 4805 Projector - Color Problem
I am having a problem with my projector because my color settings are completely off. I have worked with all the settings and cant correct it. Do you know what my problem is? When the grass should be green it is brown. Please assist me on this. Is my bulb going on the projector?
  • 4,234 Answers
It is possible that the LCD panels are burned. Is the green the only color that is off? Typically the bulb won't change the colors that drastically. Verify that the input is set correctly, having a unit expecting component inputs when you provide RGB will change the colors too. Please update this with your findings.
Dan
Posted on Apr 03, 2008
Just replaced burnt out bulb in Infocus 4805 projector. Great picture with new bulb but only black and white. Is this a bulb issue or something else in the projector?
This is most likely the color wheel. When the bulb blows, it can damage the color wheel. The color wheel is a wheel composed of thin layers of colored glass that spins in front of the projected image. It is possible to repair it with super glue, but the best way is to try to find a new one to buy.
Dec 29, 2010 | InFocus ScreenPlay 4805 Multimedia...
I have an infocus 4805 screenplay projector and i was using it when there was a pop and then i lost all color in my projector now its only black and white the bulb filter is clean what do i do.
Your projector is DLP technology. It employs a "color wheel" to provide colors other than blank/white. That "pop" you heard unfortunately may have been a malfunction of the color wheel mechanism, probably the motor. (It runs at very high RPM)
Sounds like you may have to find a shop to service your projector.
Aug 15, 2010 | InFocus ScreenPlay 4805 Multimedia...
My Infocus 4805 is just showing the INFOCUS logo and not showing the picture from the TV. all connections are correct but no signal....help
Powering On
  • If your InFocus 4805 projector is having a hard time powering on or doesn't power on at all, it could be one of two things. Due to the extreme temperature of the lamp that causes the temperature of the projector to rise, every InFocus 4805 projector has a cooling system. Check your projector's cooling solution, as it may need to be replaced. Also check the projector's fan---if the fan doesn't spin, the unit will not turn on. If the problem is the fan, you'll have to get it replaced. You can do this at the same place you bought your projector.
  • The Lamp
  • If your InFocus 4805 Projector powers on but does not project any light, the lamp will need to be replaced. All projector lamps must be replaced at some point---how often usually depends on how much use the device gets. Simply order a replacement lamp, unscrew the old one and screw the new one in. The projector will then work like new.
  • Color Wheel
  • If your InFocus 4805 projector powers on and is displaying images but the colors on the images appear warped or are not in the proper places, your "color wheel" will need to be replaced. The color wheel is a small device that essentially acts like a prism. Light is projected through it and it displays the appropriate colors on screen the way they appear in the original video source. Order a replacement color wheel that fits your model and use your instruction manual as a guide as you swap the old one out and put the new one in.
  • Aug 08, 2010 | InFocus ScreenPlay 4805 Multimedia...
    No more color
    the colorwheel is shot and needs to be replaced. try www.projectordoctor.com
    Mar 08, 2010 | InFocus ScreenPlay 4805 Multimedia...
    Where can I buy infocus scrrenplay 4805 color
    find the closest infocus authorized service center to you from their website. ask for part number 525-0146-00
    Oct 10, 2009 | InFocus ScreenPlay 4805 Multimedia...
    Red color absent from projector picture
    try to use another vga cable connector ther might be a cut on the red color signal try to move the connector form left to right until it gives you the red color if it does change your vga connector hope this help you on your problem thanks
    Feb 04, 2009 | InFocus ScreenPlay 4805 Multimedia...
    Color wheel in my InFocus ScreenPlay 4805 projector
    The 4805 Color wheel part number is 525-0146-00
    You can buy it from AV SOLUTIONS in NY
    As far as if it's worth it... That's up to you.
    Nov 07, 2008 | InFocus ScreenPlay 4805 Multimedia...
    Color wheel
    Bid on a used Infocus 4805 on Ebay...So far thet is the cheapest and best fix for a color wheel
    Jul 22, 2008 | InFocus ScreenPlay 4805 Multimedia...
    InFocus ScreenPlay 4805 Multimedia Projector Logo
    177 people viewed this question
    Top InFocus Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
