Question about Intel D845GVSR Motherboard
Chane RAM in Intel D845GVSR Motherboard
Dear sir,
I want to change RAM from DDR SDRAM to 512MB DDR2 in my Intel D845GVSR Motherboard. So, please tell me that, if it possible for change. Or any other option is their.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 107 Answers
DDR2 will not work on this board. The most you can get is DDR333 Double sided 1024. Your board has two DDR slots, you can go up to 2 gigs of memory from the info on intels web support.
Posted on Apr 03, 2008
Ddr ram sdram
If you mean you want to replace DDR RAM with DDR2 or DDR3 RAM, that is impossible. MBs are designed for one type and the sockets themselves are keyed differently and use different voltages.
Nov 08, 2013 | Intel D915GAV Motherboard
Can i use DDR2 RAM instead of DDR1
YES, if your motherboard accepts DDR Sdram, and DDR2 Sdram ram memory. If your motherboard has both types of ram memory slots.
BUT, you can ONLY use DDR Sdram, OR, DDR2 Sdram.
You Cannot use both types of ram memory in the motherboard, at the same time.
(BIOS will only recognize one type at a time)
NO, if your motherboard does not have ram slots for both DDR Sdram, and DDR2 Sdram ram memory.
Double Data Rate Sdram ram memory modules, have 184 gold plated contact pins on the bottom.
92 on Each side,
(You can click on the above photo to enlarge)
DDR2 Sdram ram memory modules have 240 contact pins.
120 on Each side.
Sep 04, 2010 | HP Computers & Internet
Does intel d845gvs1 motherboard supports DDR2 ram?
From an Intel page of this boards nearest "relatives" in the d845 series...
It shows the following for memory speed options:
333, 266 and 200 MHz DDR SDRAM
And if I remember correctly, that era of motherboards came out when ddr2 didn't exist in the market. Beyond that, the above stated memory speeds show that this board didn't even support the PC-3200(400MHz) ram, which was the final step in DDR1 memory.
The short answer to your question is: No, that motherboard of yours does not support ddr2 ram.
I hope that gets you the information you need.
Mar 12, 2010 | Intel Motherboard
I have a intel 845gvsr board, want to replace a Ram. What type of RAM is suitable for this board?
Your Intel D845GVSR has,
1. Two ram slots.
2.Maximum Amount of ram is 1GB for EACH ram slot.
3.Maximum TOTAL Amount is 2GB, (1GB in each ram slot)
4.Uses DDR Sdram at 400MHz, (PC3200), OR
DDR Sdram at 533MHz, (PC4200)
This is an example of DDR Sdram at 400MHz, (PC3200),|c:1352|&Sort=0&Recs=10
(Not advertising for this website. There are many places to buy ram memory)
512MB + 512MB = 1024MB, or also stated as 1GB
1024MB = 1GB
Nov 13, 2009 | Intel D845GVSR Motherboard
Max RAM for Intel 102 GGC motherboard
Thanks to Intel website The board has two 240-pin DIMM sockets and supports the following memory features: * 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts * Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported. * 2 GB maximum total system memory * Minimum total system memory: 128 MB * Non-ECC DIMMs * Serial Presence Detect * DDR2 533 or DDR2 400 SDRAM DIMMs Note To be fully compliant with all applicable DDR SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance. If non-SPD memory is installed, the BIOS will attempt to correctly configure the memory settings, but performance and reliability may be impacted or the DIMMs may not function under the determined frequency.
Jun 16, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
check your previous memory if its dd1, ddr2 or dd3 and check also your motherboard's manual for this. be sure that you add the same specs of memory otherwise remove your previous memory.
thank you for using fixya
Feb 24, 2009 | Intel D101GGC Motherboard
Ram upgradetion
Yes U can use maximum 2GB RAM in ur motherboard...
Dec 03, 2008 | Intel D845GVSR Motherboard
Regarding upgrading RAM
You'll need 184-pin ddr sdram memory
Supported speeds are 333, 266, and 200 mhz
Max memory for your motherboard is 2 gb, so the best you can get for your motherboard is:
2 x 1GB 333mhz 184-pin DDR SDRAM
May 21, 2008 | Intel D845GVSR Motherboard
Graphics card upgrade
Not compatable at all.
DDR SDRAM memory uses 184 Pin Dimms
Double-Data-Rate Synchronous Dynamic Random Access Memory, better known as DDR SDRAM or DDR RAM for short, is a type of very fast computer memory. DDR RAM is based on the same architecture as SDRAM, but utilizes the clock signal differently to transfer twice the data in the same amount of time.
DDR2 SDRAM uses 240 Pin Dimms.
DDR2 SDRAM improves on DDR SDRAM by using differential signaling and lower voltages to support significant performance advantages over DDR SDRAM.
If your question has to do with buying a video card that is going to use DDR2 ram, that would be a faster graphics card. You can also get video cards with DDR3 ram which again is even faster.
Oddly enough in respect to system memory DDR2 is supposed to be faster than DDR yet the DDR memory cost more than the DDR2. Go figure.
Click the link for video cards.
Need help with anything, feel free & ask.
Have a great weekend!
Mar 21, 2008 | Foxconn P4M800P7MA-RS2 Motherboard
ECS M925 1.0 sdramm to ddr memory
The normal DDR Ram is supported..It doesn't support DDR2..
Nov 03, 2007 | PC Chips (M925G) Motherboard
Intel D845GVSR Motherboard Logo
268 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
