Placed all working folders for a roxio videowave project on desktop. Photos, playlists, etc. If I move these to "My Documents Folder", the roxio slide show does not work. the program can not find the files.
    Sergeant:
  • 349 Answers
I have not used the Roxio software but i am sure if you open the program then got to the function that allows you to open files ,
it will give you an option to search the drive to find where you have saved (or moved) these files to.then select where you have placed or saved them.
good luck & please rate my efforts
Terry
Posted on Apr 04, 2008
How do I remove a duplicate "My Documents" folder in Windows 7
Rename the folder you want to remove, then delete.
Sep 20, 2016 | Computers & Internet
Tip
Changing Location of Images Folder
On your hard drive, the My Pictures folder, subfolder in My Documents, has a special status. It is this branch location that offers by default a lot of software when you want to read or record an image.
The My Documents folder is on the same hard disk as Windows (usually C:). However, if you have two hard disks (or two partitions), you may prefer that your images are placed on the second disc.
Open Registry Editor: Click Start ' Click Run ' Type regedit ' Press Enter Navigate to the following key: HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrent VersionExplorerUser Shell Folders
You should find several expandable string values such as My Pictures, Favorites which contain the locations of different system folders.
Note that for the My Documents folder, the value is called "Personal" and not "My Documents". To change the location of a system folder, double-click the value representing it, change its value data to your new location and click OK.
Remember to finally transfer all the files from their old location (My Documents My Pictures) to the new (D: Photos)
on Dec 19, 2010 | Computers & Internet
When I try to download my photos from my camera it makes whichever program (windows, documents, picasa) 'lock up' and I get the message "not responding". If I use the olympus software it...
Pros avoid these problems by using a cardreader to download to a folder they create on their desktop. Once the pics are there, they can use any program to edit, store, sort, etc. typrice_241.jpg
Aug 21, 2011 | Cameras
Unable to download folders (photos, personal documents, etc) from 5 y/o Pentium PC to IBM TravelStar 2.0 USB External Hard Drive with following message appearing... "Cannot create and replace (folder)...
Can you "read" any files from the external disk-drive?
Can you "delete" any files/folders from the external disk-drive?
Can you click 'File' and 'New' and 'Folder' to create a new folder on the drive?
Dec 11, 2010 | IBM TravelStar 40GN 40 GB Hard Drive
Can't create a playlist on rca pearl mp3 player; it wants to play all songs by genre, etc. additionally, it won't even ''import'' certain songs.
Step 1. Put the playlist in a regular Windows folder on your desktop.
Step 2. Open a window for Window Explorer and navigate to your Rca Pearl which should show up as a portable USB device.
Step 3. Open the Explorer window for the device and navigate to the "music" folder.
Step 4. Drag and drop your playlist folder that you created into this folder.
When you navigate through the pearls songlist the name that you gave the folder will show up AND all the songs in that folder will play in order...... DONE!!!
Apr 03, 2010 | RCA Pearl TH1102 MP3 Player
Hello. After I
it will be in ur Videos folder....
look for in Desktop/My Documents/My videos/
Dec 21, 2009 | MGI Software VideoWave 4 for PC
How do i transfer stuff from blackberry curve into the memory card
Open your media manager. Push menu button and select "explore".
Navigate through your device memory until you find the file you want to transfer. Highlight the file, push the menu button and select "move".
Navigate back up the file tree by selecting "up" until you see the memory card folder. Select the memory card folder, and choose the option to "put file here".
Keep in mind, you can not load programs from your memory card. You can only put files there (music, documents, ebooks, etc).
-Neil
Jun 25, 2009 | RIM BlackBerry Pearl 8100
Downloading using vista
I've found a couple of solutions, some might not be exactly what your looking for. EDIT: Soultion #2 should be your answer...
Solution #1 - Change the Documents Folder Template
  1. Click the 'Start' pearl (button)
  2. Under your name and icon, you should see the 'Documents' option.
  3. Right click 'Documents' and then select properties.
  4. The window should pop up and read 'Documents Properties'
  5. Click the 'Customize' Tab
******* Soultion #2
  1. Go into your documents folder.
  2. Off to the left side you should see the 'folders' section
  3. Under 'Desktop' you should see the folder with the windows account username. Go into that folder.
  4. Under the the folder you should see all of the default Vista folders, EX: Contacts, Deskop, Documents, etc.
  5. You can right click each folder and select properties, then under the 'Location' tab you can select the location of all of the files, and such where you want them to be.
Hopefully this helps you out, my directions could have been a bit rough if you have any problems please reply to the post!
Mar 20, 2009 | Microsoft Windows Vista Home Premium with...
Photos will not upload from camera to computer
Go to Desktop/MyComputer/Pana(or it may say USB Drive, or DCIM, and click on this external drive Icon.
You are now looking at the camera contents as if it were just another file folder on your PC, and behaves the same way.
You will find your pics in a sub-folder under a master folder, common for all camera file structures, named DCIM. You can drag and drop individual pic (jpg) files or whole pic subfolders from the camera to a place on your PC, usuallly Documents/Pictures.
You can do all other folder/file operations on this Camera Folder/Pic files you can do with those that exist on the PC like;cut, past, delete, rename, etc etc.
When you take you next first pic from your camera, after moving or deleting a pic subfoler under the Camera's DCIM master folder, the camera automatically creates another subfolder. Each subfolder holds 999 pics. The camera will atuomatically create a second, third, etc subfolder for pics 1000 to 1999, 2000 to...etc.
Nov 12, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Certificate File is missing in roxio
The following steps will completely remove any Roxio and Sonic software from your computer.
  1. Disable your startup applications using MSCONFIG. This will disable any unnecessary background or system tray applications from loading.
    • Go to Start -
Jun 25, 2008 | Roxio Easy Media Creator 7
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
