Laptop is HP zd8639ea 17" screen. A thin vertical line of very small flashing dots has appeared in the centre of the screen. How to get rid or is it replacement screen time?
  • Dave1011 Apr 03, 2008
    Many thanks for your prompt response. I have already connected the laptop to external monitor and the fault line does not appear. How do I test the video, or is that a daft question?
    Confirmed, the fault line is there from start of boot up.
  • Anonymous Mar 15, 2014
    a bar has appeared along the bottom of the screen about half an inch high, made up of thin coloured vertical lines
  • 202 Answers
Hello Dave 1011
There's a (very) slim chance it's a cable issue. More than likely, however, it is, as you suspect, the monitor.
If you're handy w/ tools and such, you can replace the monitor yourself. It'll cost at least $225US so, shop around for a good deal. (Aside from the motherboard, the monitor is the most expensive part of your laptop.)
You can run a test of your video to confirm the problem. However, when the issue is localized on the screen like that, that's a red flag that your problem is hardware.
For now, you can connect an external monitor to your laptop. In fact, that's the best way to pin down the problem to the monitor (or cables connecting to the monitor). Do this before shelling out the bucks for a new or refurbished monitor.
If the problem persists while using an external monitor, then, the problem is still likely to be a hardware issue - but it isn't your monitor. The issue is in your video circuitry. Now you're talking about a new motherboard.
I also recommend you find the product service manual for your laptop and follow the steps for disconnecting the monitor from the laptop. Then, reconnect it. See if there are any changes in the symptoms. If you need help w/ this, just let us know.
Please, let us know if this was helpful for your or, of course, if you have any further questions.
Thank you
Posted on Apr 03, 2008
  • 1 more comment
  • B Joan Rapier
    B Joan Rapier Apr 03, 2008
    A few quick questions:
    (01) Does the screen appear normal during POST? (While the computer is booting up?)
    (02) In other words, can you see text across the entire screen during boot up?
    (03) Does the problem only appear once you have booted into your operating system?
    Still, if you connect an external monitor and the problem does not show up on that external monitor, then we're back at the issue being your laptop monitor (or wiring to the monitor).
  • B Joan Rapier
    Hi Dave1011
    First off, there's no such thing as a "daft" question. :)
    2ndly, if the problem does not appear on the external monitor then you've pinned the problem down to the monitor. There's no need really to test the integrated video circuitry of your motherboard. If the video is OK on the external monitor, then you've confirmed that the motherboard's video circuitry is working just fine.
    Much of trouble-shooting computers is done by process of elimination. You've used this method already to diagnose your video issue.
    What I'd do is get 'hold of the laptop's service manual and disconnect then reconnect the monitor using the instructions you find there. I'd be very surprised if the problem wasn't in the monitor itself but, since you're going to have to disconnect it anyway in order to replace it, you may as well give this a shot. "Reseating" (unplugging then plugging back in) cables and other devices is often a remedy for hardware related issues.
  • B Joan Rapier
    B Joan Rapier Apr 16, 2008
    Hello Dave1011
    Hopefully you have been able to have your laptop monitor replaced or repaired by now.
    Since the information I provided you with enabled you to diagnose the problem you were experiencing (lines appearing on the display), would you, kindly, take just a moment to re-rate my solution and change it to a "FixYa"? I would be most grateful if you wouldn't mind. :)
    Thank you kindly!
    BJ @:)
Big vertical line section on laptop
This problem is not with the software. By resetting the laptop to factory defaults will not resolve the issue. Problem with LCD screen this vertical/horizontal lines. You need to consult technician.
May 14, 2012 | HP Computers & Internet
There is a vertical thin line going up the center of the screen. It's appears when I turn the monitor on and the only time it disappears is when the screen is white.
change your vga setting and monitor setting by right clicking on desktop try using your monitor different htz setting in advance tab and monitor setting
Jul 22, 2009 | HP L1702 17" LCD Monitor
Blue vertical line
The lines appearing on your LCD means it has a defect on the screen.
There are 3 types of pixel defect
1) dead pixel - pixel is always off
2) stuck pixel - pixel is always on
3) hot pixel - pixel is on but in red, green, blue or yellow, can also be a light black color
You can try to fix stuck or hot pixels but dead is dead.
1st method, flashing different colors rapidly: has a great tool. This is their free java applet or you can download it below.
2nd method, applying pressure to pixel:
Damp paper towel, Small stylus or dull pencil.
3rd method, tapping the pixel:
Pen with cover on or another small, blunt object.
If your laptop is still under warranty, get it replaced. If not you are looking at the most expensive part in a laptop to get replaced. (LCD screens on laptop is roughly equivalent to 40-60% of the total laptop cost
Please rate this if it this helps.
Jun 05, 2009 | Compaq Presario M2000 Notebook
I have a ipod nano 4th generation. today a thin
the "thin vertical line" on the right edge is a position bar indicating where you are in the current list.
Feb 20, 2009 | Apple iPod nano
Desktop computer monitor (flat screen) has a thin red vertical li
Detach the monitor from the cpu and turn it on. If the same vertical line appears then take it to the repair centre.
Dec 17, 2008 | IBM NetVista PC Desktop
Thin vertical line appears on projector
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
Nov 25, 2008 | Office Equipment & Supplies
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
HP L1706 monitor with thin white/blue horizontral line
It is the problem of monitor pcb in vertical section.check vertical ic for dry soldring. Resolder the ic if problem still on then change ic or check components related ith it. check continuity of vertical deflection coil.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | HP L1706 17" LCD Monitor
Vertical thin linings on lcd monitor
pull out your memory sticks and reboot with one of the two. if you nonly have one barrow one from some one else
Dec 30, 2007 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
127 people viewed this question
David Payne
David Payne
