Question about Dryers
Hoover nextra mega load 7.5kg HNC175 condenser dryer has 1)stopped heating, the drum still goes round and cold air goes in. 2) The filter care light is on, i have taken out the condenser assembly and cleaned it but the light willnot go out
  • 3 more comments
  • Anonymous Apr 06, 2008
    Removed and cleaned the door filter removed condenser washed dried and replaced all drum rotates 'filter care' light remains lit no heat?
  • Anonymous Jul 10, 2008
    filter care light came on. Cleaned filter. light gone off but comes back on. No heat coming through and timer just clicking
  • Anonymous Oct 02, 2008
    Filter light is not on, everything seems to work but no heat.
  • Anonymous Oct 21, 2008
    i have the exact same problem please help!
  • JustinHel Nov 19, 2008
    Exactly the same issue here too.
On the rear there is a Heating element hidden under the silver cover, on the top of this unit, there is 2 thermostat's, one is a auto-reset set (On the left) around the 100'c mark and one is a single use thermal trip set at 130'c (on the right, also denoted by a blue spot), the idea is when the heater reaches 100'c is powers off until the air temp drops, once it drops the auto-reset kicks in and forses the heater to power back up, however, in the intrests of safety, if the auto reset fails to power down then the 130'c thermostat will permenently remove power from the heater and will illuminate the filter care light, the only way to restore the power to the heater is to either have an engineer replace the whole heater as Hoover/candy do not sell on the thermal cut out to anyone.
you can usually find the heater unit for £30-40, an engineer may charge upto £140 for the same part and fitting.
Posted on Jan 05, 2009
  • Cromadom Jan 05, 2009
    The most common reason for this fault is due opening the door while the unit is at full temp, this usually causes the thermal cut out to recieve a surge of heat and thus breaking the single shot cut-out, if you do own a tumble dryer and need to inspect your garments, I would advise to set your machine to cool cycle/fan only mode for a few moments to reduce the heat in the unit and not to 'shock' the heater element and/or thermal cut-outs
I have a hoover nextra dryer hnc 170. The drum will not turn, and both the lights for filter care are on. I assume the reason it is not turning is because of the filter care light. Is there anythin i...
the filter care light comes on when the machine is over heating so the "brain" thinks the lint trap is full , clean the entire venting system, including the outside vent cover and remove any debris , then unplug the machine for a few minutes and see if it resets
Jul 04, 2011 | Dryers
Hoover Nextra 6 1400 6+4kg - the tumble dryer
under top cover there are 2 thermal cut outs to reset.situated centre front
Sep 12, 2009 | Hoover Nextra HNWL 3136 Front Load Washer...
Hi the my filter light keeps flashing and iv got no heat!
My guess is that the heater element has gone out. There could also be a lint clog in the exhaust takes air out through the filter...across the heater element....and back through the tumbler to heat the clothes. This is usually what causes heat elements to go out is the excess lint that gets on them and causes them to overheat and burn out!
Dec 14, 2008 | Whirlpool LEQ8000JQ Electric Dryer
Hoover washer dryer hnwf7167
this will be your carbon brushes this will only cost £15 at the most pull your washer out now tip it back so u can get under it the carbon brushes are fitted on each side by 2 screws there are only 2 carbon brushes on your motor
Jun 10, 2008 | Hoover Nextra HNF 3167 Top Load Washer
Hoover Nextra HNWF 3137
this is a condenser washer dryer so water should evaporate to condenser then empty!
Oct 31, 2007 | Hoover Nextra 160 HNWF 3137 Front Load...
Hoover nextra 5+5 washer dryer HNWF 3135 heating broken
it is seperate heaters for wash and dry and unlikely to be connected with blocked filter tho you should check filter regularly. take top off. on manifold running across top you will see stats. one of these at least is resettable by presssing a small knob in middle and if it has gone you will hear a slight click. then check dryer manifole for build up of lint as pooir air flow can cause stat to pop. for wash heating, start by checking continuity of the wash heater located at the bottom of the tub
Nov 04, 2006 | Hoover Nextra HNWF 3135 Front Load...
Dryers Logo
2,784 people viewed this question
Top Dryers Experts
