Question about HP LaserJet 9500n Printer
HP Laserjet 9500 HDN
I have an Error message 59.6M. I've tried all consummable parts. Makes a bit of a clunk when starting up then displays message. I''ve tried different fuser unit. Tried diags from panel but doesnt show any fault.
Magenta motor is knackered, change it. the clunking noise when printer starts up is the fuser gears meshing together, nothing to worry about. you can change/swap the motor with another motor and see if the startup error message changes from 59.6M(magenta) to 59.C(cyan) or something similar.
Posted on Jul 07, 2008
6ya staff
SOURCE:
59.62 error
hp color laser jet 9500 error 59.62 how fix
Jan 28, 2012 | HP LaserJet 9500mfp Printer
Hp 9500 hdn - error message 57.70. Can I relace the fuser kit to repair the problem?
No!
The 57.7 error says that the fuser fan could be bad.
If you take the back cover off the printer and look to the right, you will see two fans, one above the other.
The bottom fan is the one you want. It is probably clogged with dirt or else the dirt got inside the fan and is preventing it from spinning. Replace it
Apr 04, 2011 | HP LaserJet 9500n Printer
Regularly getting error code 50.9 on a HP color laserjet 3550 printer
Hey Joe,
This is what the HP Website has to say about it:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
BUT! you can try performing a cold reset, and maybe this would help:
500, 3550, 3700, 4600, 4650, 5500, 5550, 8500, 8550, 9500) use the instructions below. 1. Turn the printer on.
2. When the memory starts counting on the control panel, press and hold the green SELECT button. Continue to hold green SELECT button until all three Control Panel LED's are illuminated and on solid.
3. Release the green SELECT button.
4. The control panel will display SELECT LANGUAGE.
5. Press the DOWN ARROW button until control panel displays COLD RESET.
6. Press green SELECT button. The printer will perform a cold reset and then continue its power-on sequence.
Feb 07, 2011 | HP Color LaserJet 3500 Printer
Hp color laser jet 9500 hdn i have this message error 49.4c02
Unplug the printer from the pc or the network to clear the error, the upgrade the firmware.
Jun 09, 2010 | HP LaserJet 9500n Printer
My hp laserjet 2300 keeps printing an error message. It began after I installed another all in one printer. the message is pcl xl error subsystem: kernael error: illegal operator...
Try updating the printers firmware.
You can download firmware here http://bit.ly/13kZ7i
If the problem remains, try replacing the driver with a PostScript-driver. That should help you out.
Jul 29, 2009 | HP LaserJet 2300 Printer
My HP Laserjet 2430dn makes a grinding noise after power on.
CHECK RS PRINTER PARTS FOR HP LASERJET 2400 2420 2430 PRINTER GEAR KIT
Feb 26, 2009 | HP Office Equipment & Supplies
Hp colour laserjet 9500 hdn with noise and fuser error 50.6 .
Look at fuser rollers and make sure the new one doesnt have spacing to far in between rollers. Also on front side of fuser there is a big connector that meshes with one inside machine. The fuser connector assy RG5-5925-000CN could be broken as well
Jan 21, 2009 | HP Color LaserJet 9500HDN Printer
Hp 9500hdn has error 8388D4 EIO devise 3 disk not funtional
Try the following steps to reinitialize the HDD:
1 Turn the printer off.
2 Turn the printer on.
3 Press and hold PAUSE/RESUME (LJ 9500) or START (LJ 9500mfp) on the control panel during the
memory count.
4 Hold PAUSE/RESUME (LJ 9500) or START (LJ 9500mfp) down until all three error lights illuminate
steadily.
5 Press (the 5 button on the MFP) until INITIALIZE DISKS appears on the display panel.
6 Press (the 6 button on the MFP).
7 The printer begins initializing the disk (this might take a moment). The control panel displays the
HP event logo and eventually displays READY.
Oct 02, 2007 | HP Color LaserJet 9500HDN Printer
HP LaserJet 9500n Printer Logo
579 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
