Question about AudioBahn DUB Mag Audio DUB2502 Car Audio Amplifier
Installation of dub2502 amp with duel xd7500 and scosche 10kt/se12kt subs
Please help the divorced dad trying to do right by my 18 yr old son install a used dub2502 amp, duel xd7500 stereo and scosch subs. I have no litature for any of the components. How do I check the amp to see if it works to begin with and there are some loose wires on the stereo and the speakers who knows ?
thanks for your speedy response
jacbnim
    Novelist:
  • 100 Answers
Well that is a lot to go over, but I will try. You can get the user's manual for the stereo that includes the install on this page http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=ccbf995338ded66a8cd29b82806ad573&q=Dual+XD7500
With the amplifier, you will want to hook one speaker into each channel unless the subs have dual voice coils. This means that it will have 2 terminals instead of one. If they do then let me know and I will lend a hand with that. Polarity counts so make sure to go positive to positive. On the problem of checking the amp to see if it works, unless you have it installed, it would be a big pain depending on what kind of test equipment you have. A few tips on running the amp wires back. Run the power and RCA's on different sides of the car. Make sure you have a good, clean, metal to metal, solid ground. Always go through the fire wall with the power wire. There is usually a boot somewhere you can go through instead of running through the door jam. Let me know what kind of car and I might be able to find you a pass through. Then check and double check the connections at the amp. Let me know if you have any more questions. I hope it goes well.
-Andrew Hawkins
Posted on Apr 03, 2008
I just installed my 10 inch square pyle sub and its hooked up to the dub amplifier..the amplifier is in safe mode and the subs woint hit..what do i do to fix this?
ok if the amp was in safe mode before the sub was hooked up then the amp needs to be fix , make shor the suds are hooked up right an the wires arent touching , the amp is in pro mode so there for u have to find out more on why the amp is not working or let me know what is goin on with it ,
Jul 19, 2011 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Wiring the scosche fai-3a to a pioneer two channel amp
the 2 left and right dont matter, it only matters when ur hooking up a 4 channel amp.
all u do is connect one of the channels to it but it would be best o buy a stereo ull have alot of engine nose and vibration on ur speakers and a thump every time u turn on ur car but itll sound ok for now ti
Jul 07, 2009 | Scosche Industries Scosche Slc4 Speaker...
Scosche FIA-3A Tie into rear spekers of a 300C to power a sub amp
Hello herg1076,
Here's a link to www.modifiedlife.com which will have a page showing the color codes for your vehicle wiring. The 2008 Chrysler 300 rear speakers are shown as follows: Left positive is Dark Green/Tan, Left negative is Dark Green/Gray, Right positive is Dark Green/Brown, and Right negative is Yellow/Green. Other models and other years will be different, so be sure that you browse to the correct color codes for your specific vehicle.
Hope this helps.
Apr 22, 2009 | Scosche Industries Scosche Slc4 Speaker...
Sub hits backwards, hi low level converter?
I ran into a similar problem installing a sustem in a Mazda RX8. He had BOSE speakers which operate at a different range. We had to purchase the Rockford 3sixty.
Apr 20, 2009 | Scosche Industries Scosche Slc4 Speaker...
Amp stuck in protection mode, help!!
for 1 the amp is no where close to strong enough for the subs and 2 if the amp is mounted on the box it is vibrating the electronics loose. you always want the amps rms power to be be about 25% more than the speakers rms rating, from the sound of it you are either undriving the amp (clipping) or running the amp at 1 ohm load which is making it burn up. if the amp gets hot (which class d amps should never ever do) then try running just 1 sub. if the problem goes away then you know the amp is not enough for the subs. try a hifonics amp you will be amazed at the quality and power difference. I sell all major brands cheaper than almost anywhere. let me know the exact model of the subs and i can recommend a better amp for you.
Jan 06, 2009 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Popped fuses
make sure that the amp is properly grounded, paint somtimes makes it hard for the wire to be grounded, scrape off the paint with a screwdriver or whatever. also make sure that none of the wire are crossed exept if that was done on purpose
Jul 08, 2008 | Scosche Industries Scosche Build Your Own...
Dub2502 amp installatition
well to check if the amp is working hook up the ground to the battey and on the positive hook that up to the battery and jump the positive wire to the remote wire slot hook up it should spark the amp should turn on or run the power srtight on the remote slot
Apr 03, 2008 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Amp stuck in protection mode.
check to make sure your ground wire is attached to a clean metal surface no more then 18" away from amp. check all wires to ensure none are touching other terminal. all else fails remove one sub and see how it play, if its works great switch subs. could be a defective amp. if it is the amp and you payed for it with a credit card or bank card you can do a charge back from the bank to get your money back if the store wont replace it. thell the bank "you want to do a charge back cause it wasnt as discribed).
Nov 10, 2007 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Car Audio & Video Logo
114 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Josh Whitehead
Josh Whitehead
Colin Stickland
Colin Stickland
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
