Question about E-Machines eMachines Desktop PC
Emachine t3958 Hi, I turned off my t3958 by pushing the power button and now it want come back on. I ohm the switch, not sure what it should be but it 0 out. I pulled out the mother board and inspected it, nothing looks or smells burnt. With the mother board out I plugged the power supply in to a outlet and one fan started running but only for a second then stopped. I then waited a few minutes plugged it back in and it did the same thing and if I unplug and then plug right back in again it does nothing. I have a multi meter but no way to check watts. I am thinking bad power supply but then I read on emachine when the power supply go bad so does the motherboard. There is a green light that comes on the mother board when I plug it in. I took picture of the wires as I unplugged the but a couple didn't do well so where can I find a wiring schematic. Thanks Mike
  • 2 more comments
  • Anonymous Apr 04, 2008
    Have the very same problem. Others say the power supply takes out the MB too when it pukes.
  • wmcburney Apr 22, 2008
    Same problem without the clicking sounds. Systems acts completely dead. Disconnected the hard drive and dvd drive. Both the i/o calbes and power supplies. Still no power up. Replaced power supply. Still the same. Just the single green led on the mother board. No fans from anywhere. No poer supply fans, coller fan or rear case fan.
    ANy help would be appreciated.. thanks..
  • Anonymous Jul 18, 2008
    i have an emachines T3958 replaced the power supply looked burnt and so on however u too ohm the switch had some help and know im not positive of the exact poistions of the red whit blue white and black and with wires. wondering if any one can help me with that thanks
  • Terry Ash Oct 08, 2008
    I have the same problem. Switched on PC yesterday--nothing today.
    When you test for drives, do you remove both cables or just the ones with the colored wires or just the flat grey one? Its been a few years since I've been inside a PC box, so I would appreciate it if someone would jog my memory. (Please Lord don't let it be my hard drive! :-( ) Thank you all for the help. I do appreciate it. Terry (female) in Alaska.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 107 Answers
First check to see if a drive died. Unplug all the drive Floppy, hard and dvd or burns. I have come across many time that a drive will die and keep motherboard from booting. Being that you say you get a green light on the motherboard shows that the power suppy is providing some power. But for some reason the internal self test is faulting the power suppy. I have not come cross any bad power supplies killing a motherboard. But I have come across power supplies killing drives. The power switch is a normal open switch so the only time you be able test continuity on it is if you hold the switch in, or the closed position.
Posted on Apr 03, 2008
Power button t3958
are you looking for the main power supply switch or to shut the computer down because the main switch is on the back of the computer towards the top of the case next to the power cord
Jan 21, 2014 | eMachines T6420 PC Desktop
Green light on MB but will not power up at all nothing, even if I hold the button on. Emachine T3958 about 5 years old.
first thing I would try is a new power supply. if that doesn't do it for you, it's most likely your motherboard is bad.
Feb 13, 2010 | E-Machines eMachines Desktop PC
I have a emachine t3958 it will not turn on
Your power supply has gone out. This could have been caused by a surege, dust or bad power outlet.
You can purchase a replacement off eBay for under $25.00.
Jan 30, 2010 | E-Machines T3958 (827103050974) PC Desktop
My emachine 4210 powers up but it cuts it sefl off
Check the power cable connections and make sure they are tight. If they are ok then i would say you have a bad power supply.
Jan 25, 2010 | E-Machines T3958 (827103050974) PC Desktop
I have an emachines t3958 w/ intel d845epi/d845gvsr, it will not turn on. i have replaced the power supply, and i believe everything is plugged in correctly. help!
Do any fans or lights come on?
Here's things I'd check:
-Replace Power supply (You already did this)
-Try a different AC outlet, remove any surge protector
-Remove the Power Button Cable from the MB and short those pins
with a screw driver just for a second.. (to eliminate a bad power button)
-Verify that the Power button is connected to the correct place.
-Verify the voltage selector on the Power supply is set to 115V (if that's what you have)
-Verify the Power supply's additional switch is set to on (if it has one on the back)
-Verify the CPU is seated correctly and securely.
-Verify there is no metal screws or anything like that sitting on the motherboard.
-Verify that the extra 4 Pin 12V connector is connected (if present on
this MB)
If none of this works, the motherboard might be dead.
Jan 10, 2010 | E-Machines Computers & Internet
Emachines T3958 will not turn on
Check the fuse on the inside of it and see if it is not blown, if not blown change it any way it may not look like it is blown but it is hard to tell, and see if that work.
Jul 10, 2009 | E-Machines eMachines Refurbished EMA...
Power button is broken
open it up and turn it on that way.
May 24, 2009 | E-Machines T3958 (827103050974) PC Desktop
Emachine front panel power switch
Here's the Support Link for your desktop. Look under User Guides, Hardware Reference. Also look on the motherboard for markings such as PW or PS and an indicator to where the wire goes.
Nov 23, 2008 | E-Machines T3958 (827103050974) PC Desktop
I have a emachine model t3958
try to reseat the power cable of the computer and power it on again
Jun 24, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
1,104 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
