Question about AudioBahn DUB Mag Audio DUB2502 Car Audio Amplifier
Dub2502 amp installatition
I'm trying to install a used dub2502 amp in my son's 96 s10. I have no manual and the download versions I can't get off the computer (audiobahn). Please tell me how I can check the amp before install to make sure it works and if it works how to install it with aDuel model xd7500 stereo and scosche se10kt or se12kt speakers.
Thank you
Divorced Dad trying to do right
  • 185 Answers
Well to check if the amp is working hook up the ground to the battey and on the positive hook that up to the battery and jump the positive wire to the remote wire slot hook up it should spark the amp should turn on or run the power srtight on the remote slot
Posted on Apr 06, 2008
I have a dub2502 amp with the red protection light on and will not go off. The amp is a 1100 watt peak amp @ 4 ohms and my sub is an Audiobahn 1100 watt peak, 4 ohm. wired perfectly. so how do I fix the...
The unit will need to be repaired by a technician. Most likely you have a bad transistor that is causing the protect mode to turn on. The only way to get the protect mode to turn off is to remove the bad part.
May 04, 2010 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Do not have the disk that came with the printer. how can I add this printer to my laptop? My son currently is using the printer
You need to download the drivers for the printer and your windows version and install that program Heres a link to the software click on the driver and download tab - choose which windows version you have from the dropdown and you will be presented with a choice of windows versions - then you should have a list of software, Drivers and manuals available
Apr 09, 2010 | Canon PIXMA MX310 All-In-One Printer
The indicator light on the amp is staying red in protection mode how do i get it out of protection mode?
Check your manual, sometimes you have to take it back in, depending on the protection. Sometimes you have to change up the fuse. Is there enough power going to the amp, or to much?
Oct 15, 2009 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
An update corrupted my hp all in one driver. I uninstalled it the other day, and then because I had lost the CD, I went to the website to get the download to re-install. It got to 96% and then listed a...
I wish I could tell you that your experience with HP drivers was a fluke but it is not HP updates can often cause serious hardware problems. Try for the driver version you are looking for> There is a fee for the use of the site but they have a vast selection of drivers for almost anything. GL and hope all works out for you.
Aug 01, 2009 | HP Photosmart C7280 Laser Printer
Kicker amp goes into protection mode as soon as i turn it on
Have you tried powering on without speakers connected? Have you tried powering on with no input? If either senerio causes the amp to NOT go into protection mode, then there is most likely a short in wiring. Use a multi meter to isolate.
Jun 11, 2009 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Installation of dub2502 amp with duel xd7500 and scosche 10kt/se12kt subs
Well that is a lot to go over, but I will try. You can get the user's manual for the stereo that includes the install on this page
With the amplifier, you will want to hook one speaker into each channel unless the subs have dual voice coils. This means that it will have 2 terminals instead of one. If they do then let me know and I will lend a hand with that. Polarity counts so make sure to go positive to positive. On the problem of checking the amp to see if it works, unless you have it installed, it would be a big pain depending on what kind of test equipment you have. A few tips on running the amp wires back. Run the power and RCA's on different sides of the car. Make sure you have a good, clean, metal to metal, solid ground. Always go through the fire wall with the power wire. There is usually a boot somewhere you can go through instead of running through the door jam. Let me know what kind of car and I might be able to find you a pass through. Then check and double check the connections at the amp. Let me know if you have any more questions. I hope it goes well.
-Andrew Hawkins
Apr 03, 2008 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
DUB2502 amp
you probably have the speakers set to where it ecxeeds the ohm load limits. its only 4 ohm stable when bridged and two ohm stable when ran using two channels. so either run the speakers at 8 ohms each parallel or just hook one speaker to eack channel. if you do not know what i am talking about then just email me at and give me the speaker specifications.
Oct 07, 2007 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Car Audio & Video Logo
281 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Nicholas Csorba Jr.
Colin Stickland
Colin Stickland
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
