FixYa.com
Tags:
Sony BRAVIA XBR KDL-V32XBR1 32 in. HDTV LCD Television
I can't Tune my V32XBR1 in Australia (by 2 users)
posted by AustBren on Apr 03, 2008
I have returned fron Chile to Australia (I lived in Chile for 18 months and purchased a Sony Bravia KDL-V32XBR1 LCD HDTV. Since returning to Australia, I have not been able to tune the TV to the Australian digital signals. Is there any software upgrade or can I replace the HDTV integrated tuner??
Comment by AustBren, posted on Apr 03, 2008
Hi Ed,
Thanks for your reply. No I don't have cable - I have it connected to the free to air antenna via a 75ohm coax cable. I think I have two problems:
1: it is a NTSC TV and we use PAL here which I can get around it by using my DVD recorder tuner and setting the DVD units output to NTSC
2: I think I have found the equivalent TV sold in Australia and it seems to have a different TV tuner specification/frequency
My best option may be to see if I can replace the tuner with one from the Aust TV - any comment?
Thanks
Brendan
Thanks Ed
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by kinfishking, posted on May 13, 2008
I have a similar LCD, a KDL-40-X2000 which was purchased in the UK about 12 months ago. We have since moved to Australia and have had problems with the free to air HD channels.
We have all of the other free to air digital channels, but the Television will not tune into the HD channels.
Is it a regional setting or something like that?
I have another Sony LCD, a KDL-32-2000 which has exactly the same problem,. No HD.
I feel like I am missing out, is there any solution for me?
Best Solution
Helpful (85)
cezirkle
Rank:Master Master
Rating: 85%, 28 votes
Greetings...
Are you connecting to a digital signal from a cable box using an HDMI cable?
Ed
Comment by cezirkle, posted on Apr 03, 2008
Hi Brendan...
This is a couple of bucks, but looks to take whatever signal you might have in the area and convert to what you need...
Having run a help desk I tend to start with the easy questions, like, is it plugged in...
So off the air this kind of converter should take whatever the signal and covert to Sony... just in case the DVD player does not do the job...
http://www.converters.tv/products/converters/digital_video_system_converters/2.html
Hope this rates a small bump on the rating scale...
Have a great day...
Rating Locked! (?) AustBren has rated this solution as Helpful
Can you Help with these Flat Panel Televisions problems?
Sony BRAVIA XBR KDL-V32XBR1 32 in. HDTV LCD...
Green color has disappeared;...
Hi, with no warning the green... Answer This...
Screen goes blank
I have a KDL-V32XBR2 I turn it... Answer This...
Missing some channels that have...
Patriot Media was taken over by... Answer This...
fuzzy pictyre
many thick horizontal lines,... Answer This...
Sony Bravia LCD 52 inch TV
The HD DVR will not work. The... Answer This...
Repair Service
Find Flat Panel TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
