Question about Sony VAIO PCG-V505EX Notebook
Cpu 1.5Ghz but it show 600M
My laptop have CPU1.5Ghz but it properties as 600M.I don't know.please help me
  • Sony Master
  • 13,434 Answers
600mhz? its possible that the laptop has automatically put the cpu into power save state and lowerd the speed. it should return to 1.5 when connected to ac power and a demanding process is runing , games for a example.
if it doesnt change then your laptops powersaveing settings need to be changed, theres most likely a program on the laptop witch is made exactly for that.
Or
in the bios when the laptop is starting up and performing self tests (before windows starts to load)
heres how to get into bios
http://www.michaelstevenstech.com/bios_manufacturer.htm
if my solution fixed your problem please give me a fixya rateing, becouse im trying to reach the guru status and its up to the voters(you) If I get there or not. I have over 700 solutions here and most of them are unrated!
So thanks alot for rateing!
If you need more asistance, let me know. Good luck.
Posted on Apr 03, 2008
SOURCE:
I have XEON Core Duo processors with Dynatron heatsink fans attached. One of my CPUs is running about 8-10 degrees hotter than the other one and if I let it idle they both heat up until the alarm sounds...
Hello try to download the manual here:
http://www.supermicro.com/products/motherboard/xeon1333/5000x/x7dae.cfm
The fault could be a wrong setting in the bios chipset or cpu option.
Maybe one of the cpu has a wrong mhz setting ( overclocking )
This will make the system unstable.
75 degrees celcius is too hot even for a intel cpu.
Try to reset the bios to factory settings.
And look also for an bios upgrade.
WARNING!
Please do not download / upgrade the BIOS/Firmware UNLESS your system has a BIOS/firmware-related issue. Flashing the wrong BIOS/firmware can cause irreparable damage to the system.
Remember to add new cooling paste, not much, when removing the cooling element and fan.
Good luck
Jul 31, 2013 | SuperMicro X7DAE Motherboard
Change light bulb on smart choice cpu-1
Consult the owner manual or Google the model number with "manual' to try to locate the book.
Nov 05, 2012 | Carpet Pro Smart Choice Cpu1 Vacuum...
Desktop property does not show display option. I am trying to connect my laptop to tv with s-video.
if not show display option the mean you need the original grafic driver , if not solved try to re-install windows
if you see that is helpful please don't forget to vote me
best regards
Apr 23, 2011 | Dell Inspiron 6400 Notebook
What are the things needed to install fifa08
you meen system requirerments?
Platforms: Windows XP, 2000 and Vista.
CPU for XP/2000: Pentium 4 (1,3Ghz) or equivalent.
Memory requirements for XP/2000: 256Mb RAM
CPU for Vista: Pentium 4 (1,5Ghz) or equivalent.
Memory requirements for Vista: 512Mb RAM
Free Disk Space required: 3,92GB
Graphic card with 64MB ram as minimum (*)
DVD Drive 8x as minimum.
Direct-x 9 or higher installed.
those are minimum requirerments;
Jun 25, 2010 | EA Sports FIFA Soccer 2008 for Windows
When I turn my computer on there is a huge black box around my screen and the screen is really tiny. How do I get it back to fullscreen?
when you power up press F8 key then enter in enable vga mode.
Then go to controil panel and display property then settings.
Change screen resolution to 1024*768 then apply and ok.
You can also try last know good configuration.
Thanks for using fixya.
Please rate solution if it helps.
Jul 23, 2009 | Dell Inspiron 600M Notebook
Unable to connect my pc to TV
The reason why your TV is showing no input from your laptop is because of the display resolution of your graphics card, which is higher than what the TV can handle.
What you can try is, when your system is powered up, just go to your display settings, then reduce the systems display resolution to--preferably 800x600, then go to where you normally select the output, and select 'Output to external monitor"...this should send the signal input to the monitor.
Most Laptop graphics display resolution are generally very powerful as compared to what the TVs can handle.
I have actually dealt with a no input signal like this before, and this was what I did.
Hope this helps.
Jul 18, 2009 | Dell INSPIRON 600M HARD DRIVE CADDY 6X609...
Dell inspiron 600m is extraordinarily slow
it may be due to viruses So please try to Run a good rating antivirus and Antispyware I hope this could help you out. Cheers
Jan 22, 2009 | Dell Inspiron 600M Notebook
Dell Inspiron 600m notebook
Dell uses different part numbers on 600m which is the same as D600. Try these part #:'s
W1842
C5832
X2033
or
Y4801.
Jun 12, 2008 | Dell Inspiron 600M Notebook
Sony VAIO PCG-V505EX Notebook Logo
123 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
