Question about Intel Motherboard
Mercury motherboard PVM7Pro V:1.0
I have bought a mercury motherboard PVM7Pro V:1.0 and an Intel pinless processor 3.2 ghz and a 512mb memory but when i switch on,the processor fan just keeps on running but it does not show anything on the screen
  • malik538 Nov 19, 2008
    I have the same problem
    I do not have the Board CD
    What can I do now??
    Waiting for your reply
  • ex pavilion Apr 18, 2009
    I HAVE  A PENTIUM 4 PIN PROCESSOR AND RECENTLY BOUGHT MERCURY pvm 7 pro MOTHERBOARD.mY COMPUTER HANGS ABRUPTLY DURING THE STARTING PROCEDURE AND EVEN THE BOOT SCREEN DOES NOT APPEAR. I HAVE FORMATTED COMPPUTER A LOT BUT THE PROBLEM PERSISTS.IN FACT CHANGED THE HARD DISC INORDER TO CONFIRM IF THE PROBLEM IS WITH HARD DISC BUT HEY THE STATE IS SIMILAR?
                                         pLEASE ASSIST......
Posted on Dec 09, 2008
J'ai besoin des drivers audio de la carte mère MERCURY PVM7 V: 1.0
Posted on Nov 07, 2008
Which prosser supprt for the pvm7 3.1
Posted on Sep 28, 2012
Suppose board have 800 bus speed and ram have 400 bus speed , IT IS COMPATIBLE OR NOT ?
Posted on Nov 26, 2008
  • sil_muruga Nov 26, 2008
    check your ram
    check your cmos
    check ram wheather it has working or not
    check mother board
I want vga driver of my mercury mother board pvm7pro. v1.0
Posted on Nov 12, 2008
    Genius:
  • 1,913 Answers
Chek your processor and fan ssitted coreectly.
check your cmos.
check your ram fit again it.
check *********** bord not ground.
chekc earhing problem.
Posted on Apr 03, 2008
  • 23 Answers
Fiend your solution direct from intel. Here is your solution....
mercury motherboard PVM7Pro V:1.0 - d89218e.jpg
http://www.intel.com/motherboard/prob676ijt65/solution
57
Posted on May 04, 2009
Dark speck on processor
It may be the temperature problem. If the heatsink and the fan does not sit tight on processor the heat from the processor will not be dissipated properly and the heat rises up and the processor shuts off as soon as it starts working. So please see that the heat sink and the fan on the mother board sits tight. Also apply heatsink paste on the surface of the processor which comes in to contact with the heatsink. It comes filled in Syringe and retails around Rs.10-20 only. I think it will solve your shotdown problem.
May 10, 2013 | Intel Computers & Internet
Required Intel SL9CB Pentium, 3 GHz compatible motherboard
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_.2890.C2.A0nm.29
Pentium 4 HT, Model 531. sSpec number SL9CB.
OK. So far I know you need a motherboard that has an LGA 775 processor socket; needs to support Intel processors that are Single-Core, and with an 800MegaHertz Front Side Bus.
(800MHz FSB)
Ram Memory? Dunno. K
Do know the rule of thumb is, that the Ram Memory typically operates at Half of the processor's FSB.
Therefore can only assume the ram memory is DDR Sdram, and operates at 400MHz. (PC-3200)
You haven't stated the motherboard chipset that was used, OR what computer manufacturer, and model number; this mobo came out of.
(MOtherBOard)
Also didn't state if you are using a graphics card, and what kind it is.
(PCI, AGP, or PCI Express)
This isn't a 'guess-ti-mate'. Exact specifications are required in order to replace the motherboard.
Otherwise you may not be able to reuse the Ram Memory, or graphics card. (IF used)
Awaiting needed information. Post back in a Comment.
Regards,
joecoolvette
Oct 30, 2012 | Intel SL9CB Pentium, 3 GHz
What is pinless prosseser
Pinless processors are the new type put out by Intel. They do not have the pins on them that the older ones had. They basically work on a contact method with is actually much better than the pins in the past.
Oct 09, 2010 | Intel Core Duo T2600, 2.16 GHz Core Duo...
851 MHz Celeron Processor
*********** board will support a max of 1GB of RAM. Your processor is an Intel at 1.8 GHz. The preceding is only true if your PC is the Emachines T1840 as you chose in the category listing of your post. Again if that is true, you can achieve the max RAM by installing a 512MB stick in each of the two memory slots.
Good luck.
PS: Gdlkn84as528 is correct in assuming that a less than 1.3GHz Intel processor would be a P3 or equivalent processor. So which is it, it can't be both ways?
Sep 18, 2009 | E-Machines -T1840-CELERON-1.8GHz,40GB...
Hp Pavilion dv8216tx with 512mb video graphic memory
Then the service engineer needs to go back to school and learn to read. For if you look up the specs to your model. It clearly states:
Processor
Centrino Technology - Intel Core Duo Processor T2300 (1.66 GHz)
Chipset
Intel 945 PM Express Chipset
L2 Cache / FSB
2 MB L2 Cache / 667 MHz FSB
Memory
1 GB PC2-5300 (667 GHz) DDR2
HDD
160 GB Serial ATA, 150 MB/ Sec @5400 RPM
Optical Drive
Lightscribe 8X Double Layer (8.5 GB) DVD +RW/ +R Writer
Graphics
****NVIDIA GeForce Go 7400 Dedicated Video Graphics with 512 MB TurboCache****
Display
17.0" WideScreen (WXGA+) with Dual Lamp and Ultra BrightView Technology
OS
My suggestion^ Go to someone who knows about computers and who knows how to read too. Hope this is helpful.
Good Luck =)
May 29, 2009 | HP xw6600 Workstation with 650W 80 PLUS...
Raising up my ram capacity
Yes, your Intel motherboard will handle this.
Just be sure to replace the memory with new memory of the same speed.
And watch for ESD's
good luck
tony
May 20, 2009 | Intel Pentium 4 550J, 3.4 GHz...
How to recognizea pinless or pinned processor
A pinless (Pentium 4) processor has no pins.
Just a flat bottom with around an extra 297 connections to the motherboard.
You cannot fit one to a pinned socket.
Hope this helps
Jan 25, 2009 | Intel Core Duo T2600, 2.16 GHz Core Duo...
Will mercury mother board (pvm7pro 1.0) supports graphic card
first you must check that *********** board has capacity to use 8x graphic card, if you had a spare 2x or 4x graphic card try on it.
send me reply
Dec 01, 2008 | Computers & Internet
Buying a notebook
Please go for this my friend has bought its rockz man
Compaq Presario V6700TX series Operating system
s.gif Operating System
  • Genuine Windows Vista Home Premium (32-bit)
Processor
  • From: Intel Core 2 Duo Processor T5450 (1.67 GHz, 2MB L2 Cache, 667MHz FSB)
  • Up to: Intel Core 2 Duo Processor T7250 (2.00 GHz, 2 MB L2 Cache, 800MHz FSB)
s.gif Processor
  • Pentium Dual-Core Mobile Processor T2330 (1.6 GHz, 1MB L2 Cache, 533MHz FSB)
Display
15.4" WXGA high-definition widescreen with BrightView s.gif Display
15.4" WXGA high-definition widescreen display with BrightView Dimensions
14.05 (L) x 10.12 (W) x 1 (min H)/1.69 (max H) s.gif Dimensions
14.1 (L) x 10.11 (W) x 1.29 (min H)/1.58" (max H) Weight
5.99lbs
Weight varies by configuration s.gif Weight
6.4 lb.
Weight varies by configuration Communications
Available Intel PRO/Wireless 3945ABG network with optional Bluetooth s.gif Communications
802.11b/g wireless LAN Broadband wireless
N/A s.gif Broadband wireless
N/A Graphics
Intel Graphics Media Accelerator X3100 s.gif Graphics
Intel Graphics Media Accelerator X3100 PCI expansion
Expansion port 3 connector s.gif PCI expansion
N/A Memory
From 1.0GB to 2.0GB DDR2 SDRAM s.gif Memory
From 512MB to 2.0GB DDR2 SDRAM Hard disk drive(s)
Up to 160GB 5400 rpm Serial ATA hard drive
Price $789.99*
regards-balisonu79
Feb 15, 2008 | Computers & Internet
Intel Motherboard Logo
1,582 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
