Question about Garmin Forerunner 305 GPS Receiver
Will not power up out of cradle
Unit indicates charging battery while in cradle for aobut 3 to 5 seconds. Than indicates fully charged batery. Take the unit off the cradel and it goes dead.
Per all of the other solutions I've seen, I've downloaded all the updates, tried all of the resets.
Ordered a new battery for the unit. however, can't seem to find an easy way to take the unit apart to install the new battery.
2 questions:
Anyone know the easiest way to replace the battery at home?(No it is not the HRM)
Or
Should I send it in to Garmin for them to rebuild for the $100 cost?
Unit is out of warranty.
Thanks
  • Anonymous May 20, 2008
    same issue
  • wilgot Nov 24, 2008
    Hi, i do have the same problem with the Froerunner 305, is it a bug?
  • 6 Answers
To power the unit back on, press the "Mode" and "Reset" buttons at the same time. Let go of those two buttons, press the power button, and the unit will turn back on."
Posted on Apr 29, 2008
  • 3 Answers
I had exactly the same symptoms..
A bit after your post but here's my experience….
Opening it up:
The plastic base has a rubber facing on the outside (surrounding the side buttons), but as far as I can tell it is a plastic-plastic interface that glued to unite the top-bottom with cement. As has been said elsewhere, there are no catches to worry about…
Run a thin but blunt screwdriver or knife around between the “rubber” surround on the base and the top (black) plastic, applying slight lever pressure as you go (be careful and you won’t dent the plastic).
Turn the unit over so the top face is down and the contacts away from you. Apply a gentle pull on the strap nearest you while levering with your fingers at the bend in the base…this should (or did with mine) allow the base to separate from the top.
Now it turned out there had clearl;y been water ingress in my unit, between top and bottom above the contacts, one in particular at the end had corroded significantly…and on using contact cleaner carefully there was no gold left on the worst one and the mating contact on the circuit board simply fell away….. Bugger!!.. that’s basicly screwed any plans for my self-repair as can’t solder between the 2 with nothing to bite one….
However, it's not all about me!!!..
If your issue is the battery itself and you want to replace, here’s what I found…
Battery is marked as follows:
“Garmin part 361-00026-00
3.7V Li-ion 750mAh”
But (of course!) Garmin has not designed this for self-service (or by the looks of things for ease of service by anyone, given amount of glue used!), so that part # is not for sale…
Anyway, the actual dimensions of the are approx H 33.5mm x W35.0mm xD 5.5mm
..so the Ipod 4G battery, although rated the same, would actually be too big to fit (being 46*32*4.5mm)
I haven’t done an extensive check (not needing a new battery now!) but you may be able to source something very similar (possibly slightly higher capacity?) from something that suits (Canon?) cameras or a PDA device?
To change you have to lever out the old battery (its fairly securely glued to the base) then sever the leads from the existing battery and reconnect to your new one…would need a steady hand and preferably aWill not power up out of cradle - 4927918.jpg glass!
Putting it back together….It fits really snugly…Just clean off old glue carefully by scraping, replace with a glue that suits plastic-plastic and won’t destroy rubber and all should be sweet….
Paul
(PS sorry my pics are a bit crummy!)
Posted on Nov 25, 2008
  • imaginz Nov 25, 2008
    Oops, meant to put at the beginning...
    No liability accepted, but thought I would relay my experience and it may help someone!!
    My unit stopped charging (suddenly) – had been brilliant for 14 months, holding charge for 12-13 hours). Figured it was a battery connection issue. Unfortunately I have a key race in 2 weeks, love the device (when it’s working) and find it very important to pacing (ultras)…but Garmin support sucks bigtime (not even a response to emailed pleas), so figured I may need to buy another to get one in time anyway and had nothing to lose by attempting to have a go myself…
    Cheers
    P
The operating instructions say that after 16 hours the red power/charge indicator light would go out, indicating the batteries are fully charged. After 3 days the red light on my unit is still on. The...
If it is new, send it back, but make sure you carefully read the instructions first. If is says the indicator light is red on charging and green when fully charged and it doesn't do that then the batteries or the charger are defective.
In future make and model are useful. And you posted to electric drills, but I recategorised it.
Jul 02, 2017 | Audio Players & Recorders
Have had to replace the backup battery in the opener 3 times in the last year. What could be draining the battery?
Here is some general information that you probably already have. The opener should keep that battery charged. I would recommend getting a service technician out. Just when you really need that battery backup it will be out.
On top of your unit is a battery pack with three colored led lights. You can tell what is going on by looking at these. This information is in your manual or here it is. GREEN LED: All systems are normal. A solid LED light indicates the batteries are fully charged. A flashing LED indicates the batteries are being charged. NOTE: Batteries do not have to be fully charged to operate the motor unit. YELLOW LED: The motor unit has lost power and is operating off of the BBU. A solid LED with beep, sounding approximately every 2 seconds, indicates the motor unit is activating the door and is operating off of the BBU. A flashing LED with beep, sounding every 30 seconds, indicates batteries are low. Once the power is restored the BBU will recharge. This is indicated by a flashing GREEN LED. RED LED: An error has been detected and the BBU will automatically shut off. The BBU will attempt to restart by reconnecting to the batteries. If the error is still present it will shut itself off again. This process will repeat every 5 minutes or until the error has been resolved. This is used to prevent further draining of the batteries. If a red LED remains on when the power is restored, and is accompanied by a beep sounding every 30 seconds, please call for service.
Jun 28, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have HP PavilonDv4000.My batery show charge 96% total time remaning 5min.I have new battery first chrge the battery fully.Second,discharge the battery completely.And this battery can't be charge any...
Try another known good working battery and if it doesn't charge and hold the charge properly,
If that doesn't work, try another know good working ac adapter to see if it is actually charging the battery properly.
If that doesn't fix it then you know for sure at that point the motherboard is bad.
May 31, 2010 | HP Pavilion zd8000 Notebook
I have the MDR-RF970R but I bet the battery is the same. If you have had the headphone for seceral years then I bet you are right, the battery is going. You might try using them till the battery dies and then recharge. This is called deep cycle and may time it will extend the life of rechargables.
If the headphones are new, then just check and make sure that they going all the way into the charge slot.
I will say it is not common for me to see the light off, but I use the headphones all the time.
Good luck.
Apr 30, 2010 | Sony MDR-RF970RK Headphones
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
RCA headphones - nicad or alkaline batteries WHP141
BATTERY INSTALLATION AND INFORMATION
Your wireless headphone unit requires two rechargeable AAA batteries.
Rechargeable batteries are uncharged when you purchase them. Before
you can use the wireless headphones, the batteries must be charged for
16 hours. Follow these steps to install and charge the batteries.
Installing the Rechargeable Batteries
Take care to follow these steps to correctly install the batteries.
1. On the right headphone, locate the battery compartment (1).
Use the finger depression on the compartment to turn the battery
compartment cover counterclockwise to remove the cover.
2. Insert two AAA rechargeable batteries, carefully following the
markings inside to ensure the batteries are inserted properly, with
the + and - ends in the correct positions.
3. Replace the battery compartment cover.
Charging the Rechargeable Batteries
To recharge the headset unit, follow the directions below. Note: The
cradle/transmitter on the WHP141 is not a recharging cradle, although
you may place the headset in the cradle during recharging.
Follow these steps to recharge the NiMH rechargeable batteries.
1. Make sure the ON/OFF switch (2), located on the right headphone,
is in the OFF position.
2. Connect the AC/DC main power adapter to the DC IN power
supply socket (11), located on the back of the cradle/transmitter.
3. Plug the adapter into an electrical outlet.
4. Connect the charging cable (10), located on the back of the
cradle/transmitter to the recharging input (3), located on the right
headphone. The headphones can either be placed in the
cradle/transmitter or placed next to the unit. If the headphones are
connected correctly, the charging LED indicator light on the
cradle/transmitter (8) illuminate.
Mar 27, 2009 | RCA WHP141 Consumer Headphones
Batery hang problem
batteries have a charge memory in the, when you purchase a new battery the best thing to do is to fully drain the battery before charging it up, this will tell the battery that it needs full charge, if you charge the battery before this it will only charge the battery to a certain percentage.
what you need to do now is find a way to fully discharge the batteries
kind regards
Dec 23, 2008 | HP Compaq Business NX9110 Notebook
Sidekick3
The sidekick 3 has an issue with thte charging port. If you have a friend with a sidekick 3 or sidekick ID, try one of their batteries. If your unit powers on, the charging port has gone bad.
the repair for a charginf port runs about 80-100 dollars. A cheaper work around is to get a charging cradle that has a spare battery charger slot. They run about 30 dollars on ebay and it will allow you to charge the bettery seperate from the phone.
Check out the following link for cradles.
http://repairmysidekick.org/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Mar 29, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Garmin Ique 3600 - Won't charge at all
There are larger capacity baterys avalable.
I saw several different size baterys reported to fit the 3600 on the web.
I am currently looking for a parts doner 3600. If you want to part with yours.
Thx.
Alex
AlexRands@hotmail.com
Jan 01, 2008 | Garmin iQue 3600 GPS Receiver
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
Garmin Forerunner 305 GPS Receiver Logo
2,185 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
