Question about Sony KP-53V80 53" Rear Projection Television
Kp-53v80 thanks i think i need the service manual because i dont know which button to bring up the white grid.. any help you can give..
  • Sony Master
  • 8,617 Answers
Here is the link for your service manual. It's on page 3 of the sony catagory. They will email you and also provide you free tech support.
http://servicemanuals.vstore.ca/
Posted on Apr 03, 2008
Lines across screen & no sound
KP 53v80 is way too old to be fixing---recycle it as most landfills will not take that as it has toxic Glycol inside of it.
Apr 29, 2012 | Sony KP-53V80 53" Rear Projection...
Top, bottom, and sides of screen are blurry
Hello there,
Being a practical technician I would assist you technicaly.
Please find G-Board in your TV and replace IC1502 & IC1506 (STK392-150)
Before replacement of above said ICs, check follwoing Fuses (PS1501-1502-1503-1504-1505 & 1506) all are 2A rating. If you have VOM (Volt Meter) then confirm +15Volt & -15Volt supply on G board. If you need further help, I can provide with pictures of related circuit portion.
Jul 07, 2008 | Sony KP-53V80 53" Rear Projection...
Sony kp-53v80
Sounds like one of the tubes is shorting out causing the set to go into a shutdown status so it won't cause any major damage to the set or house.
Sep 06, 2008 | Sony KP-53V80 53" Rear Projection...
How do i clean my screen
You can clean the screen from the back - take off the access panel. I clean mine once a year whether it needs it or not.
Apr 23, 2008 | Sony KP-53V80 53" Rear Projection...
Sony kp-53v80
Check the 470UF Tank capacitor in the Switching Power Supply.Sometimes when heated,it gives trouble.
Apr 01, 2008 | Sony KP-53V80 53" Rear Projection...
Sony KP-53V80 53 in. Rear...
It's not a digital hi-def tv, so you either need a cable/sat box..or a converter once hi-def goes in and analog stops.
Mar 31, 2008 | Sony KP-53V80 53" Rear Projection...
Hitachi 53UWX10B
yes he used the service menu, however if you dont have the service manual I wouldnt recommend doing that as you can change the wrong item and your set can get messed up bad enough where you will need to have it serviced professionally. If youd like the service manuual go to this link they have one they will email you and they will provide free tech support with the service manual purchase
Mar 26, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Sony kp-53v80
Heres how you get into the service menu. BUT be very careful write down anything that you change as this can screw your set up and if you write down everything you will be able to change it back if it affects your set. You may want to consider getting the service manual which will explain all the details on the convergence adjustments. If so let me know and I will post a link where you can get one along with free tech support to help you out with it.
Put the TV in Standby Mode.
  • Then press the following buttons on the remote:
    {DISPLAY} {5} {VOL+} {POWER}
    or
    {DISPLAY} {5} {POWER}
    or
    {DISPLAY} {5} {PICTURE} {POWER}
    or
    {DISPLAY} {5} {VOL+} {PICTURE} {POWER}
  • The TV will turn on with the Service Menu displayed.
  • Use numbers {1} and {4} to select the item to adjust.
  • Use numbers {3} and {6} to adjust the value of the data.
  • Press {MUTE} then {ENTER} to save new settings.
  • The words "WRITE" in red will show up in the upper right corner if saved.
  • Turn the TV off to exit the service menu.
  • Mar 25, 2008 | Sony KP-53V80 53" Rear Projection...
    Sony 52"
    i have a sony kp-53v80 i have a double vision or red lines on the left side of the screen. a repair guy fix it once by using the remote and puting in a code that brought up a white grid and it showed the red was out of line and he moved it back in line and it only took a few seconds to fix ... how do i get to that grid using the remote
    Dec 28, 2007 | Sony KP-53V80 53" Rear Projection...
    Sony KP-53V80 53" Rear Projection Television Logo
    66 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
