Question about Ricoh Aficio CL3500N Laser Printer
Center of page is not printing black
The center of everything I print is not printing in black it is printing on the outside 2 in of each side and leaving the middle faded to the point it is not printed. All other colors are working just fine and will print.
  • Gotproblems Apr 11, 2008
    I have the same problem, but I am also getting the color registration error. Even though I have tried to change out the black cartridge and to follow the instructions for adjusting the color registration, the printing is not working.
  • 3 Answers
I changed out our black photoconductor unit #165 and it solved the problem. Even though the error message did not say that the photoconductor needed changed out, it had been eight months since the last replacement. I hope this helps!
Posted on Apr 14, 2008
Faded print on right side of page. When I copy/print in black, why is the black print faded on the right side of the paper?
Your toner cartridge may be the culprit.
Take the cartridge out and shake sideways and up/down. Reinstall it and try again.
If it's still printing faded side, replace the cartridge.
Jul 30, 2014 | Brother MFC-9840CDW Laser Printer
Hp laserjet black globs
Your problem is that your Teflon coating on the fuser is very worn.
You need a new fuser, as the failures here are not always visible, because the black spots are formed to get the paper and fading with every turn.
But re-form when it enters another sheet with toner to the fuser and we start the cycle again.
Apr 23, 2012 | HP Color LaserJet 2600n Printer
How to check the ink level onC4480 printer
To check the ink levels from the HP Photosmart Software
1. In the HP Solution Center, click Settings, point to Print Settings, and then click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Features tab, and then click the Printer Services button.
The Printer Toolbox appears.
2. Click the Estimated Ink Level tab.
The estimated ink levels for the print cartridges appear.
Or
Print a self-test report
1. Load A4 unused plain white paper into the input tray.
2. Press and hold the Cancel button and then press the Start Copy Color button.
The product prints a self-test report, which might indicate the source of the printing problem.
3. Make sure the test patterns show a complete grid and the thick color lines are complete.
• If more than a few lines in a pattern are broken, this might indicate a problem with the nozzles. You might need to clean the print cartridges.
• If the black line is missing, faded, streaked, or shows lines, this might indicate a problem with the black or photo print cartridge in the right slot.
• If any of the color lines are missing, faded, streaked, or show lines, this might indicate a problem with the tri-color print cartridge in the left slot.
Nov 30, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Light swath of printing down middle of page..
This is due to Black developer , Kindly approach authorised service center to get it changed.
Best Regards
Mar 01, 2010 | Samsung CLX 3160fn All-In-One Printer
While printing in black middle of page fades out both sides of the page print well. this is about a 1 inch fade out in middle of page.
Replace the drum of the particlular color cartridges. To know which color you have to print in single color one by one. If problem persist then replace transfer belt .
Jan 05, 2010 | Samsung CLP 300 Laser Printer
Uneven black ink printing
This is the problem of the black developer in the imaging unit. Please contact authorised service center they will change for you.
Best Regards
Nov 14, 2009 | Samsung CLX-2160N All-In-One Printer
Hi when printing black or grey outside edges
sounds like your black toner cartridge is getting low or not filled evenly. To fix this until it get a bit lower on toner just take the cartridge out and holding it up right give it a few shakes side to side. The will spread the toner power out inside and you should be printing normally again.
This can also happen if you moved or bumped the printer. Usually you only see this when the toner is low or after you print a lot of pages. Most text is in the mid of the paper so thats where the toner get s used the most.
Oct 23, 2009 | Samsung CLP-350N Laser Printer
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
Ricoh Aficio CL3500N Laser Printer Logo
236 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
