Question about Acer Aspire 5315 Notebook
Wireless router compatability
I have recently bought the above Acer notebook and a Phillips wireless router. I bought the Phillips because it is 811b/g. I can connect the router to my computer and laptop but I am having great difficulty trying to secure the connection. Are there other routers that will work with Aspire that might be simpler to install
    Scholar:
  • 26 Answers
I think yo should do this first before replacing:
To reset the router to factory defaults, connect the Ethernet cable to the router and check and set the settings.
This should allow you to get into the routers menu and see status and information to help you.
You also have to be sure whether or not you have 'allow windows to manage my wireless connection' checked or not
(In you Network setting)
Let me know what happens after that & I'll be glad to help
Posted on Apr 14, 2008
SOURCE:
Bought this netbook and can not get it to connect to wireless. It connects via hardwire just fine. Netgear is router. It says. Can not get certificate to log on. What to do???????????? ...
on http:// type in168.192.1.1 Welcome to the router wireless side type in:
This is for a cisco router there the same but different
router username: admin
router password: brown243bag
network name (SSID): DigitalDenizen1
network security type: Better compatibility with legacy devices (WEP-128)
network security key: F79397B4822B17D6EB4E169E8E
Nov 27, 2010 | Acer Aspire One Netbook 8.9" Notebook
Same problem, the wireless connection is set up but wont connect
the problem isn't the notebook it is the router.or wireless card.you probably have a wireless g card in the notebook and have a d-router.(not compatible wireless connectors)if it worked then stopped working then just unplug the wireless router for two min and plug it back in.it will reset and work if you had connection before.if that don't work post a comment and i will tell you another solution.
Aug 09, 2009 | Acer Aspire 5610-4648 Notebook
My acer cannont find my new Netgear G wireless router. Are they not compatible?
There are no compatibility issue between ur laptop n this router. Make sure that the router has been configured properly. Check for the wireless switch on the laptop and turn it on. Let me knw if u still face any issues.
Jul 28, 2009 | Acer Aspire 5610 Notebook
Cannot connect acer aspire one to my tp-link router
go start run type services.msc then go down to the bottom click zero wireless configuration then click start and you should be good to go
Jul 14, 2009 | Acer Aspire One A150-1672 Notebook
Acer Aspire won't Connect Wirelessly Even with Full Strength
do you have security on your wireless network, password etc. like WEP, WPA, WP2 and the likes. that would be the first thing you need to check, second is the type of wireless card and router you are using, on the laptop you might have a wireless N router and a wireless N card on your laptop which might require higher security. you'll need a WPA2 - personal for the key. that you can configure your wireless router manufacturer. hit me back.
Apr 27, 2009 | Acer Aspire One PC Notebook
Cannot connect 2nd laptop to wireless internet.
go to your acer and go to net work then net work again and in the tabs above choose add device to net work click on that and put a usb flash drive in and download to flash drive and put the drive in hp and it should automatically run the set up and start to work
Jan 22, 2009 | HP Pavilion dv6000z Notebook
Wireless never worked in Acer Aspire 3000 notebook ..help!
you have to install the wireless drivers, check it on cd
Oct 15, 2008 | Acer Aspire 3000 Notebook
Acer 5420 laptop on D Link DI524 Router
first of all, to check the wireless card on a friends network or a public hotspot, like starbucks. if that internet is slow, then most likely it is your wireless card that is on the fritz. otherwise, if it is fine on these networks there is a compatability issue with your router and your cards. make sure that if your router is very old, it is still compatible with a newer adapter.(e.g. n-wirelesscards maynot work with b-routers. and a-wireless cards will not work with b/g/n routers...or vise-versa.)
Jul 23, 2008 | Acer Extensa 4620 Notebook
Cannot connect to wireless router
sure..you'll need to select or add that wireless configuration to your list
Apr 26, 2008 | Acer Aspire 3610 Notebook
Acer Aspire 5315 Notebook Logo
141 people viewed this question
Ekse
Alun Cox
