Aiwa z-1800, cassette deck problems, clicking and clonking, not playing and no auto reverse, has any one fixed one of these or is a replacement deck available/worth it, as I see from this site that all aiwa systems suffer from cassette deck problems. I've got the doors to open correctly and got it working on one drive but one way only. I could attach a seperate unit I suppose. Any suggestions ?
  • 4,234 Answers
The auto reverse is a two part system, the heads are moved and the motors change direction. Slipping belts, broken gears, dirt in the gears can all cause this type of symptom. These are decent units and I would invest in a general overhaul to bring it back to factory spec. I have done a number of these in the past and would recommend the overhaul. Expect $10-$20 in rubber parts plus the local labor rate.
Dan
Posted on Apr 03, 2008
SOURCE:
Cassette deck stops immediately after pressing play
It is likely that the rubber drive belts have deteriorated and will have to be replaced to restore operation.
Apr 21, 2013 | Audio Players & Recorders
Sony dual deck, deck B works fine, deck A won' run the tape but just keeps clicking as it auto-reverses.
Hi amitchell47,
The rubber belts that turns the gears is already worn out. Usually, there are two rubber belts in a cassette deck. You have to replace both belts. I hope everything works out. Good luck.
Jul 25, 2011 | Sony CASSETTE DECK Single Dual Cassette...
I have a nsx-9000 cassette deck will not play.
Make a note of how the belt fits, then remove it and measure the diameter. Then buy a replacement, belts do go bad from time to time, so a new one might cure the problem. Put the diameter size (to the nearest mm result, IE: 50 or 55mm, not 52mm! Into google and "cassette belt" and you should find one for the job.
Feb 26, 2010 | Aiwa Audio Players & Recorders
Older Teac cassette decks
I had an Aiwa dual deck and by the way your describing it, when you select Cont. Play press play on one deck then play on the other. I am not sure if there's a difference as to which you start with. When the first deck is done playing both sides, the unit will goto the second deck and play both sides, then back to deck 1.
Jul 01, 2008 | Audio Players & Recorders
Fixing aiwa stereo
i have an aiwa stereo system model no: cx- za20k ,the twin cassette deck works fine,but there is no playback from the c d player,the stereo takes 3 cd s and the player just says reading and changes to the next cd endlessly any one help please
Dec 25, 2007 | Aiwa Audio Players & Recorders
Dual Cassette Deck won't stop or auto-reverse
There is a tape tension sensor which, it appears, isn't working. Check to see if the linkage to this sensor may have been misaligned while you were replacing the belts. Also check to see that the sensor isn't binding or sticking.
Nov 27, 2007 | Audio Players & Recorders
519 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
