Question about Canon Pixma MP500 All-In-One InkJet Printer
My scan doesn't work
I scaned two pages, when I try to scan the third one... it crops the document and doesn't do it any more... I turned it off. Start it on and nothing change... it doesn't scan
    Scholar:
  • 85 Answers
If the power led not glows then check the power line and adapter.
If glows, open the scanner lid, press the scan button see the scan light (the lengthy tube) is on and the scanning part is moving.
The high resolution selection may some time hang the system.
Look in the task manager whether the scanner is working.
Reinstall the scanner.
Posted on Apr 03, 2008
How do I scane on my mx310
You will need to plug the printer andcomputer together with a USB cable in order to use the printer's scanningcapabilities. The scanning unit on theMX310 features an automatic document feeder on top of the printer, which willscan multiple pages itself. You can also choose to load documents on thescanning glass, which is covered by the scanner's lid. This is how to do it. 1. Turn on the printer by pressingthe "Power" button until it illuminates and turn on the attachedcomputer. Wait for the printer to finish its initialization process beforecontinuing. 2. Place the document face up inthe automatic document feeder if the document's papers are uniform in andfit in the feed tray. Adjust the paper-width guide to the of thedocument's papers. 3. Place the first page of thedocument face down on the scanning glass after you have lifted the scanningunit's cover, if you choose to not use the automatic document feeder. Close thecover again slowly so the document does not shift on the glass. 4. Press the "Scan"button on the printer's control panel, then press either "Black" or"Color," depending on the type of scan you would like to perform. 5. Retrieve the scanned documentfrom the automatic document feeder's output tray once the scan job is over.Otherwise, click on the "Yes" button on the computer's screen,indicating you would like to scan another page. 6. Lift the scanning unit's cover,remove the document from the scanning glass and place the next page of thedocument face down on the glass. Close the scanner's cover and click on the"OK" button on the screen to scan the next page. Repeat this processuntil all of the document's pages have been scanned.
Jan 13, 2011 | Canon PIXMA MX310 All-In-One Printer
My hp 1401 wont scan ..it keeps printing out the test page so I was trying to get it to scan the page but it wont scan help
Make sure that the unit is not connected to the computer while scaning the alignment page.
Please perform the steps provided in the following HP web link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00473766&cc=uk&lc=en&dlc=en&product=1103491
:) Dr Tony
May 13, 2010 | HP PSC 1401 All-In-One Printer
Lexmarkx125 will scan larger pictures but smaller ones.
Here are some instructions from the Lexmark X63 which was similar to the X125.
The Lexmark X63 uses a sheet fed scanner, intended to scan 8 1/2 x11 inch paper.
  • To scan a document between 5 1/2 inches and 8 3/4 inches wide, center the document between the paper feed guides leading into the scanner and make sure the document is held straight,. Do not bend the document as it is fed into the scanner.
  • To scan photos or pictures that are 5 1/2 inches wide or smaller, you will need to use a flatbed scanner, or "mat" the image into a regular letter-size paper and scan the entire page. When the scan process is complete, crop out the picture using the AUTO CROP option in the Scan and Copy Control program or the photo-editing software.
Feb 27, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
Acrobat 8.1
Upgrade to Acobat 9.0 Pro. It seems to work in that can scan pages for a document, HOWEVER, adding/appending to already scaned pages for a document seems to crash 9.0. For example, say I scan in pages 1 - 4. I cannot then scan pages 5 -6 as part of the same document--crashes Acrobat.
I think this finally proves the problem is Acrobat 8.0 and NOT the i40 drivers.
Apr 28, 2008 | Kodak i40 Path-Through Scanner
Scanning with Canon Pixma MP450
I just did it then! With help from solution posted Feb 08 leave the acual scanner alone can be done from the computer. Steps:
1. Go to - start - control panel - printers & hardware - scanners.
2. Once inside the scanners folder just click once on the scanner icon (mine is called WIA Canon) so it is highlighted.
3. Then click on the toolbar 'File' > 'scan', then select the correct program from the list (mine was MP Navigator 2).
4. Use the MP Navigator program to select "scan photo/document", follow the instructions. At the bottom if the window that is open you can change the document type to PHOTO or DOCUMENT!
This is where the problem lies it is scanning the document as a photo which is why it is coming out as multiple documents.
Feb 06, 2008 | Office Equipment & Supplies
Scanning Problem
Scanned image is unsatisfactorily cropped
You can turn auto-cropping off or adjust how the image is cropped.
To turn auto-cropping off:
From your desktop, double-click the Lexmark X6100 Series
All-In-One Center
icon.
The All-In-One Main Page appears.
2 Click See More Scan Settings.
3 Click Display Advanced Scan Settings.
4 Select the Scan tab.
5 Click Select area to be scanned, and then select a size from the
drop-down menu.
6 Click OK.
To adjust how the image is cropped:
All-In-One Center
icon.
4 Click the Scan tab.
5 Select Auto-crop the scanned item.
6 Slide the Tolerance bar to the left to crop less or to the right to crop
more.
7 Click OK.
Dec 06, 2007 | Lexmark X6170 All-In-One InkJet Printer
Automatic Cropping...
Before turning off the autocrop feature, reset the software to the default setting. Then turn off the autocrop feature. Some scanning software need to be reset to the original default condition and accept software switches only then!
S. Mohan
Dec 05, 2007 | HP ScanJet 8270 Flatbed Scanner
Scanner
There is glass platen and on its sides you can see the markings to place various paper sizes. Just follow them as per your paper size.
Oct 05, 2007 | Epson Perfection 1240U Flatbed Scanner
Canon Pixma MP500 All-In-One InkJet Printer Logo
126 people viewed this question
old marine
old marine
