Mag Innovision LT776s 17" LCD Monitor Logo
Posted on Apr 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Monitor problem screen has a very yellow tint. How to fix?
Anonymous
Level 3:
Genius:
  • Master 1,913 Answers
  • Posted on Apr 03, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1913
Questions
5
Helped
687564
Points
5322
Hi
if u put any electro magnetic device nearly screen change its place.also degauss your screen.
  • Anonymous Apr 03, 2008
    in the monitor menu if u have degauss option clik it.
1helpful
How can I fix a synmaster b1630 monitor that has green tint on screen now?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Yellow screen
There are a variety of problems that can happen to the display monitor of an Acer laptop.
The most common problem is the screen fading or becoming too hard to see.
This can be corrected by adjusting the brightness levels.
Another common problem involves incorrect color, which can be resolved by adjusting the display color settings.
Yet another big problem is the display freezing or appearing jumpy, which can be resolved by updating the display driver.
Hold down the "Fn" key.
Tap the right-arrow key to brighten the display screen.
Tap the left-arrow key to darken the display screen.
Release the "Fn" key to save your display settings.
Color
Right-click on the desktop and click "Graphic Properties."
Adjust the screen resolution by clicking "Display Settings" and choosing a resolution setting from the drop-down menu.
Click "Apply" to check the resolution of the display.
Click "OK" to save the resolution settings.
Adjust the color of the screen by clicking "Color Correction" and moving the brightness or contrast slider to the right or left.
Click "Apply" to check the color resolution of the display.
Click "OK" to save the color settings.
Click "OK" to exit the Graphic Properties application.
Update the Display Driver
Right-click on the desktop. Click "Personalize," "Display Settings" and "Advanced Settings."
Click the "Intel Graphics" tab and choose "Monitor Properties."
Click "Driver."
Click "Update Driver" and choose "Search Automatically."
Click "Install" to install the updated monitor driver. After the driver has been installed, click "OK" to restart the laptop when prompted.
Yellow screen
Yellow tinting in monitors can be caused by either a software calibration issue, bad cables or a worn out display and backlight.
Before you assume that the issue is a hardware one, determine if there are software settings that affect the color or if the cables are working correctly.
After checking these items, and if the yellow tint only occurs on one monitor and you cannot eliminate it, the problem is a display hardware issue and it is less expensive to replace the monitor.
Unplug the power cord from the monitor and replace it with another one.
This is a standard power cord used in printers, monitors and desktop PCs so you can trade it for a cable from another device.
Turn on the PC and monitor to see if the yellow is still there.
Turn off the computer and monitor.
Replace the video cable with another VGA cable from another monitor.
Use one from another computer before going out to buy one.
Restart the computer to see if the yellow tint is gone.
Right click any area on the desktop and click "Properties" from the list of options that appears.
Choose "Display Settings," then "Advanced Settings."
Select "Monitor" and click the "Calibrate Color" button.
Wait to see if the yellow tint goes away.
Locate the temperature color settings on the monitor.
Adjust these to see if there is a change in the color.
A warm color setting will give the screen images more of a yellowish tint.
Click on the "Start" icon, then click "Control Panel" and "System and Security" and choose "Device Driver."
Locate the video driver and click "Update."
Select the option allowing Windows to connect to the Internet to find an updated driver.
Wait for the update to complete in a few minutes.
Expect the yellowing issue to disappear.
Connect the PC to another monitor to see if the same problem occurs.
If the yellow tint does not appear on the newly connected monitor, the problem is a bad backlight or display and the monitor should be replaced with a new one.
http://www.adobe.com/education/pdf/cib/ps7_cib/ps7_cib17.pdf
How to resolve yellow screen problem in intel d945 motherboard
This shouldn't be a problem with the motherboard unless you are using on-board graphics. But, even then, most issues with yellow-tinted screens, in my experience, were faulty video cables from the computer to the monitor.
Try changing out the video cable with a known good cable first and see it that fixes the issue.
My destop screen is tinted yellow, and is too bright.
you should update video drivers,then check vga cables, one or other guranteed.
3helpful
Mymonitor is an AOC 1770 CRT, it have a light
make sure you dont have a bent pin on the cable where it plugs in. a bent pin will make different things happen to your colors. if the whole thing is tinted, yellow, or purple it usually is an issue with the plug. also, if you have an old screen plug it in and eliminate the video card as the culprit.
3answers
ViewSonic VE710b 17 inch yellowed photograph look
Check and make sure that there is no speaker, power supply or UPS around your monitor.
1helpful
YELLOW SCREEN
hi there, check your video cable, most of it has a broken cable. ty
10helpful
2answers
Monitor displaying yellow tint
Try this. Worked for me immediately, including with PhotoShop
  1. Go to Color Management (in Vista, just click the Windows Orb / Start Search & type in Color Management)
  2. On Devices, select your display (repeat if you have multiple ones... at least I did). e.g., Syncmaster ....
  3. Check the box: Use my settings for this device
  4. Select any and all profiles you have and Remove them.
Check to see if that fixed it. You may need to restart. I didn't have to.
more info, and where I learned about it here:
http://www.mydigitallife.info/2007/07/11/windows-vista-photo-gallery-yellow-tint-background-problem/comment-page-2/
http://www.walkernews.net/2008/07/15/how-to-fix-windows-photo-gallery-yellow-tint-and-photoshop-monitor-profile-problem/
Top Mag Innovision Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
