The front panel is flasing when i press play
Have you found a solution for this yet? We have the exact same problem with our machine.
I had a similar problem, had to drain it out...I.e there is a small compartment towards the bottom right side of the machine u can prize it open with a 20 cent coin.. You will find a darkish tube .. Gently free so all the water and muck drains out. Once done Put it back the way u found it and try running the washing machine again. This helped me
HI mate , if your model is an LG 8013F , The machine first check the load by doin some cycle . If it doesnt then either the motor brush need replacing or the CPU and it cannot be repaired . Try to change the brush first bcoz its cheap then if the same problem i advise u to replace the control board .
I have one unit extra if u are interested let me knw , i can sell it for $60 + PP
THanks
Hans
You need to open the filter in front of your machine - on the bottom left , make sure you have but it by the back door- cos water will come gushing out! It just needs to rinse it out - then try again
I ahve the same problem. Whats the solution-Anil
I have the same problem. The washing machine started let in some water and stopped with all lights flashing. Tried again this time only the lights keep flashing.
yer we have the same trouble with our machine ,it takes about 4 or 5 go;s before it will do a load ,which can take hours.can anyone help
LEDS FLASHING
