Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Ws55513 blinking light
Hi, how do i get started to fixing this problem. where do i get the item and can i do it myself?? thanks
  • solhelm33 Aug 03, 2008
    I have a Mitsubishi WS55513 with blinking lights when i turn it own. I kept it unplug for 24 hours and still have the same problem. Tryed the reset button still donot work. please I need help. thanks solhelm33@aol.com
  • 121 Answers
If it's the lamp indicator, yellow means lamp near end of life, red means failed lamp. Status light (red) means major failure, yellow means filter cover loose. Parts can be found on ebay or internet.
Posted on Apr 22, 2008
Need instructions of 55"t.v model ws55513 d m board with capacitors
  • Try going To http;/www.techlore.com/24711/Mitsubishi-Blinking-green-light-repair-procedure.... It Suppose Load up about Nine Pages of Stuff on how to fix the (DM Module Board) If you Can't Fine The 1000 uf 35 wvdc Operating temperature 105 C: Electrolytic capacitor Try The Radio Shack one It Rated At 40 To+ 85 C It Will Work If You Can 'Fine The Other one !05 Deg. C Type -----Check Out This One Too 78 Pages (http://www.techlore.com/x/article/24711/Mitsubishi-Blinking -Green-Light-Repair-Procedures.(Ps) It Want Hurt To check The Ones In the power supply area,other Area .Too You might Have Change them All If You Have All The 1000 uf Check If they Showing Under Less Then The are Rated at Then It Want Hurt To Them All
May 27, 2014 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi ws55513. I replaced the 4 caps on DM board. Light still blinking. I found bulging caps on convergence board. 2200 by 16V. Going to replace them. Could convergence ICs give me same symptom? Cause...
First up we are gonna have to figure out if the blinking LED sequence is triggered by the convergence circuit. Did you try the error code operational check? If yes then please let me know whats the error code so that I can tell you whats the source of the problem.
Jul 06, 2011 | Televison & Video
Ws55513... blinking light
No...but you may not have replaced all of them (there are 8 total in a "repair kit")
Jul 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi ws55513
Hi and welcome to FixYa,
Appreciate the direct "Ask Me". My compliments on accomplishing the replacement of the 4 1000 uF/16V capacitors on the DM board.
To your concern, the blinking is still there even after having replaced the caps, a friendly reminder, the capacitors are polarized, there are specific +/-. Additionally, you may have to check the pico fuses. They would be on the backside of the DM board and would be very close near to the solder points of the 4 caps. They are marked FB900, FB901 and FB902. Rating would be 125V 4amp. Possible source maybe here.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 24, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi ws55513 Blinking light -capacitors changed
check the resistor chips on the bottom side of the circuit board solderd directly to the traces one or more may be open.
Mitsubishi ws55513 Blinking green light- replaced capactitors
Hi again,
It would seem that you posted twice. My compliments on accomplishing the replacement of the 4 1000 uF/16V capacitors on the DM board.
Toyour concern, the blinking is still there even after having replacedthe caps, a friendly reminder, the capacitors are polarized, there arespecific +/-. Additionally, you may have to check the pico fuses. Theywould be on the backside of the DM board and would be very close nearto the solder points of the 4 caps. They are marked FB900, FB901 andFB902. Rating would be 125V 4amp. Possible source maybe here.
Justa start, do postback how things turned up or should you need additionalinformation. Good luck and Thank you for using FixYa.
Mitsubishi WS55513 ---Flashing Green LEDs...and now NO POWER.. Hi...got the entire board / chassis out of the TV shell. Going to start checking individual components, starting with the mail power supply...
start by pulling the DM board (looking from the back it is standing upright on the left side in a metal chassis) and you'll probably find 4 bad capacitors (bulging on the tops is a good indication, If i remember correctly they are near the top right corner)
you can buy replacements here..
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=P13119-ND
Fixed mine this way several months ago..still working like new.
Good luck
Mar 17, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Sony KP46WT520 blinks three times
They are on the main power supply board. Yes if you can solder and are careful around the high voltage items such as T60s you should be able to do the repairs easily. I would recomend a service manual however. If you would like a link to get the service manual and parts let me know
Mar 16, 2008 | Televison & Video
Mitsubishi WS55513 tv
capacitor problem.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
Dec 14, 2007 | Televison & Video
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
61 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
