Question about Dishwashers
I will be closing our house for the next 6 months. do i need to do anything special to seals? i understand the line draing,but have heard you nee to use mineral oil for seals. this does not make sense unit is in flordia
    Novelist:
  • 184 Answers
NO, YOU DON'T NEED TO PUT ANYTHING ON THE DOOR SEALS, HOWEVER, IF YOU KEEP THEM CLEAN OF SOAP AND FOOD FILM, THEY WILL LAST LONGER AND BE LESS LIKELY TO LEAK. IF YOU ARE GOING TO BE GONE FOR A LONG PERIOD OF TIME, YOU COULD PUT A QUART OF WATER IN THE BOTTOM TO KEEP THE PUMP SEALS WET.
WITH SOME MODELS OF DISHWASHER, IF THE PUMP SEALS DRY OUT, THEY CAN STICK TOGETHER LOCKING UP THE MOTOR SO IT WON'T RUN WHEN YOU GET BACK.
FIRST, RUN A RINSE ONLY CYCLE WITH NOTHING IN IT TO PURGE OUT ANY DIRTY WATER THAT MAY CAUSE ODOR.
THEN, PUT IN ABOUT A QUART OF FRESH WATER AND CLOSE THE DOOR TO KEEP THE WATER FROM EVAPORATING. IF YOU WANT, YOU COULD ADD SOME BAKING SODA TO KEEP THE ODOR FRESH.
Posted on Apr 03, 2008
    President:
  • 2,072 Answers
It is a good idea. Mineral oil or a non petrolium product.
Anytime you leave an appliance unused for some time, preventative measures are always a smart idea.
The seals are pretty expensive to replace.
A few pennys of mineral oil versus probably a $150 service call seems pretty wise.
SOURCE:
The alert notification is from a u-line refrigerator and beeps even when door fully closed
Since you did not mention what make it is .
Its usually dirt in your door seal causing your refridgirator to understand its not closed since its not sealing properly . clean the door seals and try .
Or there is a technical glitch in electrical system and you need a repairman .
Also there is usually a way to disable the alarm and you need to check your user manual for that to disable it ill its fixed
Jun 01, 2018 | U-Line Refrigerators
How to replace crimped fuel lines
this could be a seal and not too bad to replace.
there is a special tool for removing the fitting. make sure you understand how it works to avoid problems.
the fuel line has to be bled down so that you don't get sprayed
when separating the lines.
check the lines for bent flanges and for seals.
replace as necessary.
install the new seal with the special tool it looks like a spring.
then get out the racing tires and have some quality time.
Feb 26, 2013 | 2003 Chevrolet Express
I heard from someone that you don't need to change the water in a waterbed. If so, how does the water stay fresh?
You heard right! Every 6 months you should treat the water in your waterbed with a special conditioner. This conditioner may come with the kit you get when you buy your bed; if not you can purchase some separately.
Jul 24, 2012 | Furniture
Can anyone help i have a 98 range rover 4ltr leaking oil from the oil filter seal or houseing it's hard to tell but have tryed 2 new filters and have looked at the houseing it looks fine but stil
Either the oil leak isn't from the filter seal and is somewhere nearby or the oil pressure is unnaturally high, perhaps because the oil pressure relief valve is stuck closed.
May 25, 2017 | Land Rover Range Rover Cars & Trucks
I cranked the motor over a few times to get to the ignition module, I then pulled the distributer out without marking anything. Now I have motor at TDC, line on crank pulley lined up with notch on motor...
If you have it at #1 on the crank marks, you need to install the distributor so that #1 on the cap lines up with the rotor. I think you have a 350, so #1 is at about 12 o'clock if you view it from the front of the car-see diagram:mikemt_1.jpg
Dec 25, 2010 | Chevrolet S 10 Cars & Trucks
There was a lighting storm the other day and when the house next door was struck my wireless router stoped connecting to the internet. It had been working fine the past 6 months is there anything I can do?
1. the lighting could have rendered your router functionless. or the cable/dsl line has been fried at the drop.
2. call you ISP and have the line checked.
3. If the router has a "red" light at the power light you have a bad power adapter or the power supply circuit in the router has been fried by the lighting. The only remedy here is to get a new router and a surge protection strip that is above 10,000 joules and guaranteed.
Jul 01, 2010 | D-Link DIR-615 Wireless Router
Firing order for Spark Plug wires
Here is the diagram you ask for. While it says it is for the 3.0L V6, it is the same for the 4.0L V6 if that's what you have...
Feb 15, 2010 | 2004 Ford Ranger
How to replace the thermostat
  1. Remove the necessary coolant from the radiator.
  2. Remove the alternator, as outlined in the Engine Electrical Section.
  3. Loosen the outlet hose clamp at the thermostat housing. Remove the outlet hose from the thermostat housing.
  4. Remove the thermostat housing bolts.
  5. Remove the thermostat housing from the engine block.
  6. Clean all of the surfaces of the thermostat housing.
  7. Clean the sealing surface of the engine block.
To install:
Thermostat mounting—4.2L engine
  1. Install the thermostat housing to the engine block.
  2. Install the thermostat housing bolts and tighten to 89 inch lbs. (10 Nm).
  3. Lubricate the inner diameter of the radiator hose with engine coolant.
  4. Install the outlet hose to the thermostat housing. Secure the hose with the clamp.
  5. Install the alternator.
  6. Fill the cooling system with specified coolant and concentration.
  7. Inspect all sealing surfaces for leaks after starting the engine.
Oct 11, 2009 | 2003 GMC Envoy
Left back floor was soaked after driving in heavy rain.
IS THIS CAR FOUR DOOR OR TWO NEE D TO NO SO I CAN TELL YOU WITCH WAY TO GO ANY WAY I WOULD GET A HOUSE OUT BUT SOME ONE IN CAR IN BACK AREA AND SEE IF THEY CAN FIND LEAK IT MAY BE AROUND WINDOW SEAL HOPE THIS HELPS SEEN THE SEEM IN WHEEL WELL DO THIS BUT MAY BE BACK WINDOW SEAL IS TRUNCK WET TOO .
Aug 12, 2009 | 2002 Toyota Camry
Dishwashers Logo
65 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
