Question about Lexmark X4270 All-In-One InkJet Printer
Black ink cartridge - won't print
I have just installed a new black ink cartridge (16) and now my Lexmark won't print "black" at all.
Help.
    President:
  • 2,072 Answers
It is not unusual to receive a bad cartridge. The ink or the fiber in those cartridges are subject to blocking ( drying) while not in use.
That would be the most likely problem.
Posted on Apr 03, 2008
3 Suggested Answers
map9966
  • 2351 Answers
SOURCE: I changed the black in
Wweluvgolf, sometimes after you remove the protective tap from the ink cartridge, it leaves behind tape residual. Suggest you clean the ink cartridge's copper contacts with alcohol & cotton swabs. (No dripping alcohol). Do not clean the bottom of the ink cartridge. Also clean the copper contacts in the carriage. Allow all to dry. Reassemble & try printing a test page.
In the future keep your recipts when buying ink. From time to time you will buy a bad cartridge. With the recipt you'll be able to exchange it for another (free). Always store ink in it's upright posistion.
If this did not help please let me know & post the model number of the printer.
Luck!
Mike
Posted on Apr 19, 2008
SOURCE: My Lexmark 1240 printer has a new Bkack ink in it
Check to make sure you have removed the plastic covering on the new ink cartridge contact.  Run a calibration/alignment test on your printer. (If you're not sure how to do this, Google "how to align cartridges on----- your modle printer).  Finally, you may want to do a "hard-reset" on the printer. Turn it off, unplug it for 30 seconds and try again. Good luck!
Posted on Jun 24, 2009
Installed new 28 and 29 cartridges in lexmark x2550 and it won't recognise the cartridge and won't print at all, very frustrating please help urgently
It could be that your cartridges need some cleaning. On your computer, launch the Lexmark Solution Center. Click Start menu > Programs or All Programs >Lexmark 2500 Series > Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them. Try to print again.
Jun 29, 2011 | Lexmark X2550 All-In-One Printer
Black ink not printing even tho a new black ink cartridge was installed recently and working properly until I opened the unit to install a new color cartridge and now the black ink is not printing and the...
Try to reseat your cartridges. Unplug and replug your printer into the power source to reset itself. If that doesn't help, try to clean your cartridges and check if print quality improves. If you're using Windows, go to Start -> Programs -> Lexmark X74-X75 -> Lexmark X74-X75 Solution Center -> Maintenance -> Clean print nozzles to fix horizontal streaks.
Feb 17, 2011 | Lexmark X75 All-In-One InkJet Printer
My documents will not print the colored part. just Black and white
I would first check to see how low the color cartridge is. If it is out of ink, you will need to replace it.
Your Lexmark has two cartridges, one for colors and one for black.
To check the level of the ink cartridges, go to the Lexmark Solution Center. This is the software that was installed to run you Lexmark printer.
Check the cartridge ink level images that appear on each tab. If a cartridge is low, or if you have received an Ink Low message on the computer screen, install a new cartridge. An empty or low cartridge is marked with an exclamation point ( ! ).
To order print cartridges:
1 }}--> }}-->Open the }}--> }}-->Lexmark Solution Center .
2 }}--> }}-->Click the Contact Information tab.
3 }}--> }}-->Click Ordering Ink and Supplies.
For help installing a cartridge, go to How to install the print cartridge.
Dec 30, 2010 | Lexmark X6150 All-In-One InkJet Printer
Lexmark printer always want a new cartridge
What you need is to reset the ink level:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Hope this help.
YBC (/\)
May 28, 2009 | Lexmark X2500 All-In-One Printer
I have a Lexmark X1150 printer that is printing purple only.
Try the "better" or "best" print options - They give more ink - might do the trick - (beware it also prints a lot more slowly....)
I have not had that type of problem as such as both my ink slots work, but I did have purple/bluish print instead of black once - It worked for me -
Hope that helps -
I have also found that despite cartridges being new somethimes they are not as full as they should....
May 03, 2009 | Lexmark X1150 All-In-One InkJet Printer
Lexmark 2500 printer won't print after replacing black cartridge
Unfortunately the printer wont print unless there is ink in both cartridges
Jan 01, 2009 | Lexmark All-in-One Printer with PictBridge
I changed the black in cartridge in my Lexmark printer with a lexmark #16 black ink cartridge(which I have done many times. It didn't print black Colors do print). I figured the cartridge was defective so...
Luck!
Mike
Apr 19, 2008 | Office Equipment & Supplies
Lexmark printer
Lexmark technical support should be able to help resolve this problem, assuming the cartridges were Lexmark branded. Contact information is on www.lexmark.com.
Feb 13, 2008 | Lexmark International Z611 Printer
Colored Ink problem
Make sure you are using the correct cartridges for the Z35. They should be #26 (color) and #16 (black).
Make sure the contacts are clean where the cartridge connects to the printer electrically. A little alcohol wipe is good for this. Clean contacts on both the cartridge and the carrier in the printer.
Nov 19, 2007 | Lexmark Color Z35 InkJet
Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Jun 08, 2007 | Lexmark Color Z35 InkJet
Lexmark X4270 All-In-One InkJet Printer Logo
102 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
