I have a HCN4226 DLP television and it is giving me 3 different color images
    Master:
  • 351 Answers
Dear Baskiasan,
it mean you have to tune up your TV's colour settings.There should be a couple manuals for your tv model listed here: http://www.usersmanualguide.com/samsung/tv__projection/hcn4226w
Cheerup and be happy always
Posted on Apr 03, 2008
  • 4,234 Answers
A few questions...
1) Is the picture in focus, but showing 3 colors?
2) Any other symptoms at all?
There are a number of causes of this type of symptom. Hopefully with the above answered, I can rpovide you with a more detailed response.
Dan
  • ABRsvcs Apr 04, 2008
    Ok. I looked into this a bit more. Based upon the initial description of the problem, it is best described as a convergence problem. This means that each of the 3 major colors is not aligned with the others. The end result is 3 individual pictures layered on each other. In the idela case, this results in a clear picture of various colors. In this case, the mis-alignment causes a 3-D look. With LCD projection sets, each color is controlled by a separate LCD plate. These plates are aligned to overlay each other on the screen. It sounds like this alignment is now off. There are both mechanical and electrical alignment adjustments available to provide proper convergence. The mechanical adjustments are not available to the servicer as this is done within the "light engine" part of the set. If the electrical adjustments do not resolve the problem, then the light engine must be replaced. In either case, this is not a repair that can be done without the service manual and some test equipment. If the reported set is not within the warranty period, an authorized Samsung service center should be contacted to provide the repair.
    Dan
    Genius:
  • 1,665 Answers
Is a samsung?
    Genius:
  • 2,785 Answers
Dear baskiasan
your problem is due to failure of hardware(picture conversion element) inside the television.
if it is in waranty then you can give them for repair.other wise you have to search for a good service person to solve the problem.thanks for contacting
6ya staff
SOURCE:
Need help fixing the picture on an older Samsung dlp tv
You need to replace your color wheel. Part# BP96-00674A. This has been a common problem with the samsung dlp's. I hope this helps.
Apr 23, 2016 | Samsung HLR4667W 46" DLP- DIGITAL LIGHT...
May i replace LCD Projector Dlp/Dmd chip with DLP projector Dlp/Dmd chip ?
LCD projector have only LCD panels in the Projector
DLP projector have only DMD chips in the projector
there is no DMD chips in the LCD projector
there is no LCD panels in the DLP projector
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,motherboard ,powersupply,ballast... with high quality and competitive price.
Hope to cooperate with you.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: [email protected]
Skype: lampdeng.com
YM: [email protected]
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 21, 2014 | Office Equipment & Supplies
I only think its the color wheel on my samsung dlp hls4666W because different colors keep resonating and put out a glare or glow.
It is not the color wheel problem, it may cause by digital board. Once the color wheel has problem, TV will turn on/off 3 times and then shutdown. Hope it useful for you.
Nov 12, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
This is more for information question. Dose Mitsubishi have a DLP TV that dose not use a color wheel and lamp where you can get 3D?
Yes, Mitsubishi did make a DLP that did not use a color wheel, but I am not sure if they still make it. It would be in the Diamond series and it uses 3 image units. I believe this was a professional set and was very expensive. You may have to ask around at you local electronics store to see if Mits still make this set.
I hope that this helps.
asnowman
Oct 06, 2009 | Televison & Video
Samsung PCL542R Manufactured in 2002 color is off
if you did not see the picture on the blue tube; that is your problem -- the drive signal is not getting to the video amp and the mixed color from the green tube and the red tube is giving you a different color wich is unnormal. a good picture is when the 3 crt are emitting the video
Oct 09, 2008 | Samsung HCL4715W 47" Rear Projection...
Samsung HL-R6167W DLP color problem/buzzing noise
My 3 yr old Samsung DLP has the same buzzing noise, had a tech out today and he said "color wheel". Thank goodness I purchased that expensive warranty, This is my 4th repair in 3 years.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Color problem with DLP TV
If pic. is distorted when warm :. Suspect the FMT PCB part # 930B924002
Sep 24, 2006 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
