What failed component causes protection error message to display right at power up.
  • 1 more comment
  • mvaia Jul 04, 2008
    I have the same problem with my Sony V444ES receiver. It will power on and functions well for a period but will often cut out after a loud "pop" followed by a flashing PROTECTION message. If I power it down for several seconds, sometimes it will come back on and play fine for another period. Usually, though, it "pops" again and I have to power down many times before it works again. Needless to say, this is extremely annoying and I would like to figure out why it is happening. Any suggestions? Thank you very much for your help.
  • JIAN2100 Aug 17, 2008
    I have a Sony STR-DG500 Receiver. The same problem !! Eror message"PROTECT" showed up when powers on. I had opened its case and discovered that there's a blown-fuse. Then I replaced it with a same type of fuse. When I powered it on again, self-detection goes about 10 seconds, an eror message "protect" came up. After that, the reciever shut down itself.
    Anybody with any idea what went wrong?
    Thks....
  • mgb1976 Oct 26, 2008
    I have a Sony STR-DG500 with exactly the same problem as JIAN2100.
    Does anyone have a fix for this?
Well, i just got this thing from a friend. its a Denon AVR-800. when powered up it displays the stops, just before finishing a -protect- shows up. There's a little red light standby light that blinks off and on also. i think that has to do with the internal problem. any suggestions?
Posted on Sep 22, 2008
Can anyone help. I have an older Denon AVR 800 receiver. I was experiencing a problem with it going into protection mode and finally it blew a fuse. I replaced the fuse, but as soon as I turn it on, it blows again. Can anyone tell me how I can fix it?
Posted on May 06, 2008
  • 4,234 Answers
The protection message indicates a problem was detected in the final stage of the amp section. It could be as simple as a voltage regulator problem or the output transistors have failed. If you can provide the make and model, I should be able to give you the most likely parts.
Dan
Posted on Apr 03, 2008
  • DeniseGreg Houghtaling
    DeniseGreg Houghtaling Nov 21, 2013
    Yeeaa; just wondering about "protect" mode on a Denon AVR-610 AV sorround reciever. It was on while I was working in the area and started sparking (top was wet from my sweat so that is the probable culprit) and smelling like burnt electronics. I have top off and cannot find burnt parts, two fuses seem intact... Thanks
Shows an error of E03
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
Precor Error Code 03 E03 EEPROM Test Error
Oct 03, 2015 | Exercise & Fitness
What does treadmill error code E1 mean?
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Here's a link to more error codes:
Error Code List for Precor Fitness Equipment
May 26, 2014 | Precor Exercise & Fitness
Precor error 3
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 03 E03 EEPROM Test Error
Feb 22, 2014 | Precor Exercise & Fitness
Precor treadmill code e3 is on
Oct 18, 2013 | Precor C954 Remanufactured Treadmill
Precor error code 1
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on Precor Error Code 01
Aug 18, 2013 | Precor 9.21 Treadmill
Cyclone SX9 0 MAXPRO Treadmill
God bless you
Jun 03, 2013 | Exercise & Fitness
Error code 1 and 3 on my Precor 9.21s treadmill?
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 01
Mar 27, 2013 | Precor 9.21s Treadmill Display Console...
Error 0 problem
see the error +causes +remedy:God bless you
Description
Errors 00 through Error 04 check upper PCA memory locations, RAM memory locations and
EEPROM checksum during the power up test sequence. If a fault is found during the power up
test sequence, the appropriate error code will be displayed.
Possible Causes
1. These errors messages almost always indicate an upper PCA problem when they are
consistently displayed. Failures causing these error messages to be displayed are rare.
Possible Remedies
1. If the error message is consistently displayed when the unit is powered up, the upper PCA
should be replaced. It is possible to see one of these messages displayed intermittently due
the test could fail resulting in one of these messages being displayed. Treadmills operating
on non-dedicated A.C. circuits may see these messages displayed on an intermittent basis.2_4_2013_5_52_44_pm.gif
Feb 04, 2013 | Proform Sport 1000 Folding Treadmill...
Precor m 9.5 error code 4
Precor Error 04, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 04
Mar 02, 2010 | Exercise & Fitness
Samsug HT-SK5 fails with 'Protection' on display
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
May 28, 2008 | Samsung HT-SK5 System
645 people viewed this question
 Grubhead
Grubhead
