Question about PfaFF Creative 7570
Hello, I have bought a PFAFF 213 sewing machine with a jammed shaft. I have oiled the machine, but the needle won't move up and down. The machine is very clean inside, indicating that it has been used only a little. I'd love the satisfaction of fixing it myself - albeit, with a bit of help. Cheers - Cathy
  • Debbykay Jan 19, 2009
    I am desperate! I have a Pfaff 1167 that the hand wheel is seized. I can wind the bobbin, but when hand wheel does not turn once the machine is engaged. The machine was my grandmother's, but it is nearly new and has not been used for a couple of years. It is in a cabinet, so I am not even sure how to get it out to take to a repair shop. I would rather try to fix it at home, but really need some help! Any help is graciously appreciated!!
    Kind regards,
    Debbykay
I did fix the jammed shaft - simply by applying some tenacious oil and letting it sit overnight. It is now a fully-functioning machine!
Thanks for your ear and your interest,
Cathy
Posted on Apr 06, 2008
6ya staff
SOURCE:
I have a Pfaff 230. The lever to move the needle to the left or right is not working? It is stuck in the Left position. Suggestions to release without taking it in as heavy to transport
I have a Pfaff 260 that was totally frozen when I bought it at a thrift store. The old oil had turned to glue and seized the moving parts. I followed the process described below and my Pfaff 260 now has a prominent working place in my sewing room.
Berninamatic 910 is frozen Where can find manuals so that can service it
Oct 14, 2016 | PfaFF Sewing Machines
My pfaff 1222e isn't working the motor runs but the needle doesn't move ~ the knob at the end of the machine won't turn at all
Check for thread jams... hopefully that's the problem and not a bent shaft in the thing.
Nov 28, 2012 | Sewing Machines
Pfaff 2024 bobbin case basket is jammed-even after clean & oil
the jam that happened may have caused the machine to jump time & it would have to be serviced
May 16, 2012 | Sewing Machines
Pfaff select 1540 bobbin thread jam
if there is a thread in the hook area try taking a pair of needle nose
pliers to try & get the thread out, if that doesn't work then you might
think about taking the machine to a sewing machine shop to have the
machine checked since the needle will not go up & down & handwheel
won't move
May 03, 2012 | PfaFF Sewing Machines
Old Pfaff 130 machine partially frozen
check carefully around the bobbin holder area as fluff and threads around here are known to jam the shaft
Jan 18, 2018 | Sewing Machines
I've just bought a Pfaff 1471 and it has "locked-up"... the needle won't go up and down and the hand-wheel won't move. Help please! :)
Do you have a bunch of material and thread stuck in the feed dog? Sounds like. This will sometimes happen. I'm afraid the only thing you can do is carefully work with a seam ripper or small scissors to get it all out. Be careful working. You will damage this part of your fabric, but you can take the seam allowance in a small bit. You will probably have to remove fabric & thread from underneath, through the bobbin area, too.
Once you have all of this cleared, the needle and wheel will turn. I suggest you try and take the needle out of the shaft and try pulling it out of the fabric before you start your work, too. That way, you won't risk breaking it and have a piece fly off at you.
It's frustrating and will probably make you curse at the machine-it's happened to everyone who sews at one time or another, and will happen again, I'm afraid.
May 10, 2011 | PfaFF Sewing Machines
My Pfaff 1211 was working and all of a sudden it
Your hook where your bobbin case goes in are most likele jammed with cotton. give it some oil and turn your handwheel backwards gently. Look if you see any cotton jammed and remove it
Jan 20, 2010 | Sewing Machines
Sewing Machines Logo
377 people viewed this question
Top PfaFF Sewing Machines Experts
Douglas Plant
Douglas Plant
MissFixIt828
Level 1 Expert
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
