Agfa DuoScan T1200 Flatbed Scanner
Problem for Agfa DuoScan T1200 Flatbed Scanner
Connector question
By JPalm56 on May 15, 2008
I've gone from a desktop to laptop computer (finally). I want to connect my T1200 with scsi-2 (50 pin) to my usb hub. What connector(s) can I use? I'm so confused with all the DB. . HD. . . etc. I find something that I think will work, then I see "not for scanners". I'm just totally in the dark!
Best Solution
posted on May 15, 2008
Very Helpful)
jonniewalker
Rank: Guru
Rating: 88%, 628 votes
you can buy or use FRISX connector, its is a fire wire to scsi-2 (50 pin) converter use the fire wire cable to connect to your usb hub then the other end to the FRISK connector attached to the scanner
Comments:
May 15, 2008
- you can check out this http://www.ratocsystems.com/english/support/pdffiles/fr1sx5.0.pdf to see how the FRISX connector is
Rating Locked! (?) JPalm56 has rated this solution as Very Helpful
Solution #2
Not Rated)
maklean
Rank: Guru
Rating: 86%, 651 votes
Have a look at tutorials here
http://www.tutorials.com/04/0431/0431.asp
Solution #3
Not Rated)
Benimur
Rank: Guru
Rating: 88%, 3834 votes
There is a SCSI to USB adapter on the market similar to this that should work for your requirement.
Perhaps your other concern should be OS compatibility. Pls post back what OS is your laptop.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Comments:
May 15, 2008
- Here is one from Amazon, another one from Lindy and a similar product from cwol.com. All are scanner compatible.
Cheers.
Solution #4
Not Rated)
Scorpionakku
Rank: Guru
Rating: 85%, 257 votes
dear,
well to rectify this problem you have 2 options:
1. either you can purchase a PCMCIA card with 50 pin Scsi connector.
2.or USB to SCSI convertor.
all this kind of connectors and convertor are available in IT shops
Regards
Popular Solutions for Agfa DuoScan T1200 Flatbed
Questions and Unsolved Problems for Agfa DuoScan T1200 Flatbed
Do you recommend Agfa DuoScan T1200 Flatbed Scanner?
Answer
Answer
The buttons on the front of my Canoscan Lide 30 do not work. I would like to use the scan button and... (More)
Answer
What is the cheapest way to connect a T1200 scanner to a modern laptop (running XP) which only has... (More)
Answer
How do I open the scanner or remove something from the bottom of the scanner?
Answer
I had not used my scanner for about 3 months. When I scanned a light page, or even better just a... (More)
Answer
We have Agfa Duoscan T1200 Flatbed professional scanner. when we connect it with computer it is not... (More)
Describe your Scanners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Scanner Experts
Top Printer Repairmen
in , IL
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
