Question about Dishwashers
Indesit DE43UK dishwasher. Water only gets lukewarm, intermittently gives Fault code A03 - "thermistor short circuit". Indesit says no such part as thermistor listed for this model. Indesit will not put me through to an engineer to explain this. What now?
  • 1 more comment
  • msmith661 Apr 03, 2008
    Thanks for the advice - but I neglected to mention that this is a "cold water" only machine. The instruction book recommends connecting it to the cold water supply. If connected to the hotwater supply, the instruction book says the machine lose more than 15% efficiency. It has been wotrking fine in the current installation for 3 years. It apparently heats the water itself, and does indeed have a 1.8 Kw tube type heater unit which measures fine. (28 ohms - exactly the same as the new one I have just bought)! I therefore strongly suspect that the machine does indeed have some sort of temperature sensor - quite possibly a thermistor - and that the fault code A03 - "thermistor short-circuit" could be accurate. Problem is that Indesit does not have any such part listed for my model machine! Are there other methods of temperature control used in dishwashers?
  • msmith661 Apr 04, 2008
    Thanks so much for the replies, your time is genuinely appreciated. Unfortunately my query is with regard to the specific make and model of my machine. It is European, and I am in London U.K., so I doubt whether you USA guy's will have come across it. Basically, the machine is telling me a thermistor fault, the symptoms seem to agree with that - but the manufacurer says there is no thermistor in my model!! There does seem to be a "one shot" over temp thermostat as protection, but the manufacturer refuses to tell me how the water temp. is obtained. I suspect that it may well be a simple timing procedure - X amount of water, therefore turn the heater on for Y time and the water should be at Z temperature. If this is the case, then perhaps the heating element goes high resistance when it starts heating up, or some such, and replacement will solve the problem. This does not solve the problem of the A03 fault code - thermistor short circuit. If they have indeed removed the thermistor and resorted to just a timed thing, where would the processor be getting the fault signal from? The other problem of course is that all the damned gubbins are in the bottom of the machine. To be able to take measurements while the thing is running would require me to put it up on some sort of satnd, so I could get at the underside with it in an upright position. Currently I just chuck it on it's back and mess with the gubbins that way. I don't expect a reply to this message - was just fo keep you updated. Many thanks for trying, all the best, Mitch Smith.
    Just for everyones information - I have the problem solved. The thermistor for my dishwasher is hard-wired to the P.C.B., thats why it is not listed as a spare part - you have to buy the whole P.C.B. The thermistor itself is an NTC and is available at your local electronics shop for a few cents. In my case, a repair qoute for my dishwasher of over £300.00, has in effect been repaired by yours truly for 68 pence - and that includes the VAT!!!
    Novelist:
  • 184 Answers
INCREASE THE WATER TEMP AT THE HOUSE WATER HEATER SO YOU WILL HAVE 120 DEGREE WATER COMING INTO THE DISHWASHER. IF THE DISHWASHER IS NEXT TO THE SINK, PURGE THE HOT WATER LINE AT THE SINK UNTIL YOU ACTUALLY GET HOT WATER. THEN, START YOUR DISHWASHER.
Posted on Apr 03, 2008
  • DAVID LOGAN Apr 03, 2008
    I'M NOT FAMILIAR WITH YOUR BRAND OF DISHWASHER, BUT IN GENERAL, ALL DISHWASHERS WITH A HEATER HAVE A THERMOSTAT OF SOME KIND TO REGULATE THE TEMPERATURE OF THE WATER. MOST AMERICAN MADE HAVE A HIGH LIMIT THERMOSTAT AND A THERMAL FUSE FOR SAFETY. IF I HAD A PROBLEM WITH WATER TEMP, I
    WOULD SET THE DISHWASHER INTO A HEATED CYCLE,
    CHECK THE HEATER CIRCUIT FOR OPERATION, AND SEE WHAT ITEM TURNS IT OFF. IF IT IS NOT UP TO TEMP, THAT ITEM WOULD BE DEFECTIVE.
My dishwasher shows error cod A03
A03 - Short circuit on thermistor or Time-out drain- Check filter for blockages then book a dishwasher repair if the problem persists.
Also check that the nothing has managed to get through teh filters into teh drain pump and block it or that drain hose is not crushed and or blocked,
Oct 15, 2014 | Indesit Dishwashers
Tip
List of codes for Hotpoint, Creda, Ariston, Indesit, Cannon
Appliance tagged Hotpoint, Creda, Ariston, Indesit, Cannon are all distributed by the Indesit appliances group.
All this brands share parts, they share the same error code list, and the service is provided by same centres.
I will publish a list of error codes for Hotpoint, Creda, Ariston, Indesit, Cannon.
Washing Machines and Washer Dryers
  • F10 - No cold fill. Check that the taps are on or if the drain hoses are kinked.
  • F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
  • F12 - No mixed fill. It is likely that the water is not turned on at the taps.
  • F13 - Check the water supply, inlet valve and hot and cold hose connections.
  • F14 - A fault with the water heating has occurred
  • F15 - Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked
  • F16 - Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more.
  • F17 - Door not closed properly. Close door firmly at 3 o'clock position
  • F20/1 - The thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing
  • F30/31 - A motor drive problem has occurred. Try running the programme again. If the problem persists book service
  • F40 - Water below protection level during a heat step
  • F41 - Water level detect sequence incorrect
  • F50/51 - Customer language and wash programme have not been saved. The system will run with default conditions (1000rpm max and English language).
Fault codes for LCD EVO1 Washers
  • F01 - Short circuit motor triac
  • F02 - Motor jammed tacho detached
  • F03 - Wash thermistor open/short circuit
  • F04 - Pressure switch jammed on empty
  • F05 - Pressure switch jammed on full
  • F06 - Program selector error
  • F07 - Heater relay stuck
  • F08 - Heater relay cannot be activated
  • F09 - Incompatible eeprom
  • F10 - Pressure switch not sensing correctly
  • F11 - Pump cannot be activated
  • F12 - Communication error
  • F13 - Dryer fan or dryer thermisotor fault
  • F14 - Dryer element fault
  • F15 - Dryer element relay fault
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock
Fault codes for LCD EVO2 and V4 Washers
  • F01 - Motor traic short circuit
  • F02 - Motor jammed or tacho detached
  • F05 - Pressure switch jammed on full - Check pump for blackages.
  • F08 - Heater relay stuck
  • F09 - Setup error
  • F12 - No communication between cards
  • F13 - Drying thermistor open/short circuit
  • F14 - Drying element faulty
  • F17 - Interlock error
  • F18 - Communication error
  • H20 - Not filling. Check tap, hose and inlet valves
Fridges and Freezers
  • F1 - Freezer thermistor open circuit
  • F2 - Freezer thermistor short circuit
  • F3 - Fridge thermistor open circuit
  • F4 - Fridge thermistor short circuit
  • F7 - Evaporator thermistor open circuit
  • F8 - Evaporator thermistor short circuit
  • F9 - Temperature set switch open circuit
  • FA - No feedback from Baffle
  • FB - Fridge Baffle motor operating continuously
  • FE - Defrost time out
Dishwashers
  • F10 - Fill or empty time out. Check that the hoses are not kinked, that the taps are on or whether the drain pump or hose is blocked.
  • F11 - Heater timed out. The heater has not reached the required level.
  • F20 - Temperature under range
  • F21 - Temperature over range
LCD Dishwasher Models
  • A01 - Float switch
  • A02 - Open/Short circuit heater relay
  • A03 - Short circuit on thermistor or Time-out drain- Check filter for blockages then book a repairif the problem persists.
  • A04 - Unable to reach or sense temperature within 70 minutes
  • A05 - Pressure switch has not been reset
  • A07 - Open/Short circuit wash motor triac
  • A08 - Open/Short circuit auxiliary wash motor triac
  • A09 - Open/Short circuit with main wash traic
  • A10 - Open/Short circuit fill valve traic
  • A11 - Half load valve traic or alternating motor action
  • A12 - Open circuit heater rely
  • A13 - Open/Short circuit dispenser traic
  • A14 - Drain hose too low causing syphoning. Check drain hose.
  • H20 - Check tap and pressure of incoming water.
Hotpoint Tumble Dryers
  • F1 - The level of required dryness has not been reached within the time period. Check that the correct programme has been selected
  • F2 - Thermistor or sensing circuit failure
  • F3 - Heater plate over temperature. Check the filter and vent hose for a possible blockage
...Follows--->
on Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
How to reset e001
An error E001 should have a detail code with it.
Detail Code 0001:
Cause
The fixing temperature has increased abnormally
  • The main thermistor (TH1) has a short circuit.
  • The fixing heater drive circuit has a fault.
  • The DC controller PCB has a fault
  • The image processor PCB has a fault.
Description
The output of the main thermistor has exceeded 220 C.
Detail Code 0002:
Cause
The sub thermistor has detected overheating.
Description
The output of the sub thermistor has exceeded 235 C.
Detail Code 0003:
Cause
The sub thermistor has an open circuit
  • The sub thermistor has an open circuit.
  • The SSR has a fault.
  • The DC controller PCB has a fault.
Description
I would suggest calling the copier repair personal.
Feb 21, 2014 | Canon imageRUNNER 400S Copier
HE error on LG dishwasher
HE is a HEATER ERROR
Possible causes
¥ The Circuit of Heater is troubled.
¥ The Thermistor is troubled.
¥ The Heater is shorted.
¥ The Relay Circuit is troubled.
Possible solutions
¥ Repair the Circuit of Heater.
¥ Replace the Thermistor.
¥ Replace the Heater.
¥ Repair the Relay Circuit..
Jul 12, 2009 | LG 24 in. LD-12BW5 Free-standing...
Indesit WIE167
Hi, and welcome to Fixya.
F03 is indicating that the wash thermistor is open or short circuit.
The thermistor is part of the water heating circuit,so the only thing you can do is to test the heating element for continuity or an earth fault..If faulty, replace.
If it is o/k then you will have to call an engineer.
Plz rate my solution.
Thanks, And a merry xmas.
Dec 20, 2008 | Indesit W 123 Front Load Washer
A05 code
Indesit Error Messages and Error Codes Indesit Dishwashers
  • F11 - Heater timed out. The heater has not reached the required level. Book a service engineer.
  • F20 - Temperature under range. Book a service engineer. .
  • F21 - Temperature over range. Book a service engineer.
Fault codes for Indesit LCD Dishwasher Models
  • A01 - Float switch operated - Book a service engineer.
  • A02 - Open/Short circuit heater relay - Book a service engineer.
  • A03 - Short circuit on thermistor - Book a service engineer.
  • A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
  • A05 - Pressure switch has not been reset - Book a service engineer.
  • A07 - Open/Short circuit wash motor triac - Book a service engineer.
  • A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
  • A09 - Open/Short circuit with main wash traic - Book a service engineer.
  • A10 - Open/Short circuit fill valve traic - Book a service engineer.
  • A11 - Half load valve traic or alternating motor action - Book a service engineer.
  • A12 - Open circuit heater rely - Book a service engineer.
  • A13 - Open/Short circuit dispenser traic - Book a service engineer.
  • A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
_uacct = "UA-1207243-4";urchinTracker();
Sep 14, 2008 | Indesit 24 in. DE73 Evolution...
Indesit IDL535 Dishwasher intermittent fault
Suggest you check the electrical lines from the panel on out. Something is wrong with connections and it could be dangerous. If you're not familiar with electricity, get someone who is.
Jun 17, 2008 | Indesit Dishwashers
60cm Ultima DWF70 Free Standing
Hotpoint code A03 is a short circuit on the temperature thermistor.
This will need replacing, or there is a fault with the supply wires leading to it.
This should be replaced.
Do you need instructions or the number of an engineer?
If you do, please contact again, otherwise please rate as Fixya! if this has resolved your problem.
Thank you.
Jun 15, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Indesit evolution de73 dishwasher
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
Apr 07, 2008 | Indesit 24 in. DE73 Evolution...
Hotpoint FDW80( A10 Appears ondisplay half way through cycle)
here are the fault codes for your machine...
Fault codes for LCD Dishwasher Models
  • Hope this helps?
    Jan 06, 2008 | Hotpoint 24 in. FDW60 Free-standing...
    Dishwashers Logo
    529 people viewed this question
    Top Dishwashers Experts
