Question about Palm Treo 600 Handheld
"not enough power to activate wireless mode" problem for treo 600
I got a treo 600 and I am having problem to on the wireless mode
Call to your wireless provider and they will help you turn it on
Posted on Apr 11, 2008
  • Dorie Sep 11, 2010
    It means your battery is low. Charge it.
Wireless mode of my treo 600 constantly off
have you tried to hard reset the unit - backup your personal data before you do
Sep 01, 2009 | Palm Treo 600 Handheld
My palm treo 600 has a serious issue.
Ok this problem is very common in 600`s i have good and bad news
first go to the phone application and phone info
see what hardware u have A B C
A&B are toast and nothing can correct the problem
if your in hardware C your in good luck
bad news my first treo had this same exact problem and i had to replace it:( BUT BUT BUT!! it was caused by a 3rd party program that messed would auto reset my treo everytime it came on unfourntely uninstalling it didnt work and the wireless mode never came on..
got my second treo and had the same problem but i did not hot sync and intsted beamed using infared all my data and the problem never occured but sometimes
Aug 10, 2008 | Palm Treo 600 Handheld
Palm treo 600
Sorry, but this is not my area of expertise. Please try consulting another expert. I do apologize.
And oh yes, please do not rate this solution, as I haven't really posted any!
Thanks.
May 11, 2008 | Palm Treo 600 Handheld
Hard reset
hold K, return key, and press reset. reconnect charger to turn back on.
Apr 01, 2008 | Palm Treo 600 Handheld
Treo 600
if your ESN is cleared for activation then you can just call customer service and and the they can do it while you are on the phone with them. If the ESN isn't clear take your phone into your service providers store/
Feb 12, 2008 | Palm Treo 600 Handheld
Palm treo 600, hangs while picking up calls and wireless mode goes off, deleting all data
Perform a hard reset, and clear the data off the treo.
Hold down backspace and the K key. While holding both of those down, hit the reset button on the back. Hold all for a few seconds. The screen will flash white and then turn off.
Then plug it into the charger cable. It'll turn back on and get you to put in all the settings again.
Then it will work correctly.
Feb 07, 2008 | Palm Treo 600 Handheld
Switching from AT&T to Rogers Wireless net work
Download
http://rapidshare.com/files/66601080/T6GSMUP305.ZIP
http://www.megaupload.com/?d=LB81QBIN
Turn Wireless off (you do not have to remove sim card ); Hostsync palm treo 600 to your pc; add all files of folder T6GSMUP305 by install from palm desktop.
palm treo 600 will automatically update & unlock.
Read readme file
Nov 18, 2007 | Palm Treo 600 Handheld
Esn is not on treo 600 w/ cam
My ESN was also missing from my treo until i switched on the wireless. try it.., let it load the network then look for the ESN. note my network did not have a sim card. you may need to put in a sim card if your treo network requires it then check. good luck.
Sep 01, 2007 | Palm Treo 600 Handheld
Treo 600 no service
Its a bad phone. Have Verizon replace it for you. Had the same problem with my Treo.
Jul 24, 2007 | Palm Treo 600 Handheld
My treo is doing hard reset automatically
try performing a battery reset..it will reset the internal radio and the charging circuitry..only problem here is that u need an AC charger to switch the phone back on. this will wipe out all data u may want to back it up before trying this option heres how to do it Battery Disconnect Reset Treo 600 only A battery disconnect reset is a last resort step you can take to cut battery power, wipe all data, and regress a Treo 600 to its factory-fresh state. It only works on a Treo 600 smartphone. Important: A battery disconnect reset will erase everything on your smartphone, and also reset the wireless radio and disconnect the internal battery. All your data will be removed, and your formats, preferences and other settings are restored to their factory default settings. Don't perform a battery disconnect reset unless you've backed up your data, or you're willing to lose everything. You won't be able to turn your Treo 600 back on until you connect it to a power adapter, so do not perform this type of reset without your Treo 600 charger and a power source. HotSync note: Some third-party applications change the way your handheld backs up data. Other third-party applications do not back up data. If you have third-party software on your device, please contact the developer to learn what components are backed up during a HotSync operation, and if HotSync conduits are altered. Any data not backed up will be lost. To perform a battery disconnect reset: 1. Disconnect your Treo 600 from the AC charger. 2. Hold down the K and Backspace keys simultaneously. (Note: for French AZERTY keyboard, press K and M; for other language overlays, please refer to the customer support for your region) 3. While continuing to hold down the K and Backspace keys, press the RESET button inside the hole on the back panel of your device (where's the reset hole?). 4. Finding it hard to do? Good. We made this type of reset very awkward to perform, so that it would not happen by accident when your Treo 600 is jostling around in a pocket or bag. Sorry for the inconvenience. You might want to ask a friend to lend a hand if you find it too difficult to do by yourself. 5. Continue holding down K and Backspace. The screen will flash white briefly, and then go black. Release K and Backspace after this happens. Your Treo will appear to be "dead" and the screen will not turn on. If you see any activity ? such as the screen turning back on ? the reset was performed incorrectly; try again 6. To revive your Treo 600, connect it to the AC charger and plug the charger into a socket. The screen will stay blank for several seconds (as long as half a minute), then it will turn on. The LED will glow solid red, indicating charging. 7. Finally, follow the steps for recovering after a hard reset (a battery disconnect reset is an extended type of hard reset).
Aug 06, 2006 | Palm Treo 600 Handheld
Palm Treo 600 Handheld Logo
114 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
