Question about Samsung DLP HL-P5663W 56" TV
How to format the flash disk? - Samsung DLP HL-P5663W 56" TV
    Genius:
  • Samsung Master
  • 1,689 Answers
Get a flash reader that can read your flash card to a PC. Connect the reader and insert the flash card while the computer is running. This is safe because it is USB. Install the drivers for the flash card. Run the utillities that allow to format the card.
Some cards can be formated using the Windows format program that is for formatting drives.
Jerry G.
Posted on May 06, 2008
When i insert my USB flash drive called sanDisk cruzer 8GB in the laptop,am told that i need to format the disk in drive G before i can use it,when i try to format it, it says that windows was unable
If there is any Media Error not possible to format the drive otherwise use the following method on Windows 7
Open a Administrator command Prompt and type the command one by one
1.list disk
you can find the avilable disk and note your USB Drive Disk Number
2.select disk 1 (change the number)
3.clean
4.create partition primary
5.format fs=ntfs quick
6.assign
if no problem in usb it will format your USB Drive
Apr 03, 2014 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Convert usb raw drive to fat drive
The Fat32 (FAT) format is used to format disk drives on Windows-based computers and can also be recognized by the Mac's OS X operating system. You can format a flash drive with the FAT format so that it can be used on both PCs and Macs. The procedure is straightforward, if different depending upon the operating system being used to do the formatting. You do not need to purchase any additional software to format the Flash drive in the FAT format.
http://www.supermediastore.com/article/u/how-to-format-usb-flash-memory b> http://download.cnet.com/hp-usb-disk-storage/3000-2094_4-10974082.html Format USB flash drives with FAT, FAT32, or NTFS partition types. Plug the Flash drive into a USB port on the Mac. Double-click the "Applications" folder inside of the Mac's hard drive. Scroll down to the "Utilities" folder. Double-click the "Utilities" folder. Scroll down to the Disk Utility program. Double-click on the Disk Utility program to launch it. Click once on the icon of the Flash drive that is in the left column of the Disk Utility program's main screen. Click on the "Erase" tab at the top of the window of the Disk Utility program's main screen. Name the Flash drive in the "Name" column at the center of the Disk Utility program's main screen. Select "MSDOS (FAT) from the "Format" menu beneath "Name." Click the "Erase" button at the lower right corner of the Disk Utility program's main screen. Click the "Erase" button in the pop-up confirmation window that appears. Wait as a progress bar at the bottom of the Disk Utility program's main screen fills in from left to right. Click the "Eject" button at the top of the Disk Utility program's main screen once the progress bar is completely filled in. Quit the Disk Utility program. Remove the Flash drive from the USB port of the Mac. b> Format Flash Drive in FAT on a PC b> Plug the Flash drive into a USB port on the PC. Go to "start," "My Computer." Right-click on the icon of the Flash drive in the center column of the window that appears below "Devices with Removable Storage." Select "Format" from the pop-up menu. Select "FAT32" from the "File System" drop-down menu in the window that appears. Click the "Start" button at the bottom of the window. Click the "OK" button in the confirmation pop-up window that appears. Wait as a progress bar fills in from left to right at the bottom of the window where you had selected "Fat32." Click the "OK" button on the "Format Complete" pop-up window when it appears. Right-click on the icon of the Flash drive that is on the desktop. Select "Erase" from the pop-up menu. Remove the Flash drive from the USB port of the PC. Hope this helps.
b>
Dec 07, 2012 | Corsair Memory Computers & Internet
How can i fix my kingston dt101 2gb flash drive
The OS format tool will not format flash driveswhat you need is this one
http://en.kioskea.net/download/start/download-127-hp-usb-disk-storage-format-tool
Although it was produced by HP it works on any,
Jul 08, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My flash disk does not format what is the problem? i put the flash in the windows xp system port it becomes recognised by the system i try to open it ,it tells me the disk is not formated do you want to...
Your flash disk has been infected by virus that is why you are unable to open the flash drive. The best thing you can do is to download a good antivirus such as MacaFee or Avira or scan the flash drive for virus.
An alternative thing you can do is to insert your flash drive into a linux operated pc such as Fedora, Ubuntu, Open Susie or Redhat and then delete all the files in the Flash drive and format it
Apr 01, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I CANT FORMAT MY MEMORY CARD....I DONT KNOW HOW TO FIX IT.
  1. Open control panel.
  2. Open administrative tools.
  3. Open Computer management.
  4. In the left column click disk management.
  5. This populate all the disk present
  6. Locate your memory card
  7. Then you can delete the partition entire and build new one
  8. You can format with Fat Or FAT32 file system
  9. Do not perform quick format.
Another options are available to format via cmd
To do that
At the run Menu type:CMD
then a command promt window will open
Type format x: /fs:fat32
Note that x is volume label (memory card drive label may d, e or f)
ok
try this
Feb 25, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Flash drive lost some of its space
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Oct 22, 2009 | Computers & Internet
Cruzer micro 4gb will not format. Also, PC will not reveal contents.
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
Oct 12, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Windows was unable to format my flash disk
It seems that the card is bad. Try to format the card on a different machine to rule out your Windows formatter.
Aug 19, 2009 | Dell Inspiron 6400 Notebook
My Transcend pendrive isn't being formatted
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format pendrive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 13, 2009 | Transcend (589307) Media
Flash Disk
Insert new disk for drive F:
and press ENTER when ready...
The type of the file system is RAW.
Please use the /FS switch to specify the file system
you wish to use on this volume.
Apr 03, 2008 | Dell Inspiron 6400 Notebook
Samsung DLP HL-P5663W 56" TV Logo
42 people viewed this question
Henry  Thomas
Henry Thomas
