Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpiont washing machine
Hi ive got a hotpoint washing machine the thing is it comes on but the drum doesnt go round at all it dont spin or anything can you help me
    Problem Solver:
  • 8 Answers
First check if belt from motor to drum is on, then check to see if motor is running. If not, there maybe a fuse link or fuse that needs replacement. The last time you used did you smell burning, if so could be your motor is gone.
Posted on Apr 03, 2008
Drum doesnt turn
hi is the belt on if so 1st thing to check are the motor brushes good chance thats the proplem
Dec 27, 2013 | Hotpoint Aquarius WMA42 Front Load Washer
I have a hotpoint aquarius washing machine, with the belt off and you lift the inner drum there is a lot of play the pulley wheel that the belt goes round has been cutting into the back of the plastic...
Hi.
It could be a combinatrion of both things, as bearings often fail, and the drum supportt is prone to corrosion and metal fatigue, which would give the exact symptoms you describe.
Either way it involves a complete stip down of washer to determine the exact problem
Feb 05, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
SPARKS ARE COMING FROM UNDERNEATH MY HOTPOINT WASHING MACHINE WHEN DRUM IS IN ACTION
hi dont worry the carbon brushes in the motor need replacing soon it will stop spinning if you remove them you will notice that the carbon brush is very short should be an inch long they are easy to change thankyou good luck
Jan 18, 2011 | Hotpoint Washing Machines
Drum not going round
Hi Friend,
welcome to fixya....
may be the drum belt is the fault, Here are some possible causes of a washing machine belt coming off :-
1.The drum pulley is loose
2.The drum bearings have gone (collapsed) causing the drum pulley to wobble
3.The drive belt was to slack
4.A motor fixing bolt or bracket securing the motor to the tub has broken or come loose
5.Water has got onto the belt causing slippage
6.An obstruction or item of clothing temporarily jammed the drum causing the belt to spin off ,,,,,,,,,,,,
first check whether it is hard to turn the drum if not then check the above situations,,,ok
if you think that i helped you please rate it\\\\\\\\
thank u...
Apr 03, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Wd865 spinning problems
PUMP IS BLOCKED OR PIPE LEADING TO IT ROMOVE FRONT BOTTOM PANEL AND YOU SHOULD SEE A ROUND THING WITH A SCREW IN IT REMOVE SCREW TWIST AND PULL OUT REMOVE DEBRIS AND TRY AGAIN IF THIS DONT WORK LAY MACHINE ON ITS BACK REMOVE PIPE FROM PUMP AND CHECK IT NOT BLOCKED WITH ANYTHING ITS QUITE AN EASY JOB TO DO
Mar 04, 2009 | Hotpoint Ultima WF865 Front Load Washer
Washing machine won't spin
Do you hear the motor spinning loud whirring noise,when drum is not,if so drum belt has come off or snapped,if no noise possible brushes on motor need replacing
Jan 18, 2009 | Hotpoint Ultima WD72 Front Load...
HOTPIONT AQUARIUS WF320
interlock may be stuck try changing that
May 26, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Drum
try changing the brushes if you cant do it contact a local elctric shop see if they could check it out for free
Apr 03, 2008 | Hotpoint Aquarius WF210 Front Load Washer
My Hotpoint Aquarius WF210 washing machine drum is not rotating
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
Sin é
Jan 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
67 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
