Question about Hotpoint Aquarius WF210 Front Load Washer
Drum hi my hotpoint washer it comes on but the drum doesnt go round can u help?
  • lauratops Apr 03, 2008
    please can u help
  • Anonymous Mar 27, 2014
    it drawater goes in but on any cycle drum doesnt join in program times down normally
  • 4 Answers
Try changing the brushes if you cant do it contact a local elctric shop see if they could check it out for free
Posted on Apr 03, 2008
Replace belt on Hotpoint Aquarius WM31 washing
Remove top cover of washer.
Remove rear access panel.
Slacken off the motor fixing bolts, and pull motor towards drum top.
Fit belt round motor pulley first, and then feed it round the drum pulley from the rear of the washer.
Tighten motor bolts just enough to hold motor steady, and pull motor towardsa cabinet side to tension belt, it needs to be farly tight.
Then tighten motor bolts securely.
Fit back top and rear covers.
Apr 05, 2010 | Hotpoint Washing Machines
Drum not going round
Hi Friend,
welcome to fixya....
may be the drum belt is the fault, Here are some possible causes of a washing machine belt coming off :-
1.The drum pulley is loose
2.The drum bearings have gone (collapsed) causing the drum pulley to wobble
3.The drive belt was to slack
4.A motor fixing bolt or bracket securing the motor to the tub has broken or come loose
5.Water has got onto the belt causing slippage
6.An obstruction or item of clothing temporarily jammed the drum causing the belt to spin off ,,,,,,,,,,,,
first check whether it is hard to turn the drum if not then check the above situations,,,ok
if you think that i helped you please rate it\\\\\\\\
thank u...
Apr 03, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
How do i get the belt back on on a hotpoint FEW12
Remove lower rear panel of washer.
With the help of someone to hold it, tilt the washer forwards away from you at the rear.
Fit belt round motor pulley first, and slowly feed it round drum pulley, turning the pulley at the same time.
It will be very tight, so watch your fingers, just keep on going, until you get the belt on all the way round the pulley.
Mar 15, 2010 | Hotpoint First Edition FEW12 Front Load...
How to attache drive belt to drive drum .belt will not reach.loosening bolts that hold motor on did not help.forced on but belt twisted on drum.
Remove rear cover of washer, and top cover also, tilt washer towards you, get someone to hold washer steady, fit belt round motor pulley,and slowly feed belt round drum pulley, watch your fingers, keep feeding belt round oulley, turning drum at same time, it will be tight, but persist, and belt will go on.
Please rate my solution.
Sep 28, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint aquarius tumble dryer, drum not going round but still
If you can hear the motor going, then the belt probably needs replacing, if no motor action, then prob is more serious.
Jul 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Fitting a new drive belt to a hotpoint aquarius
Remove lower rear panel, tilt washer forward, getting someone to help, and fit belt round motor pulley, then fit belt round drum pulley, slowly turning the drum pulley round as you feed the belt on, it is very tight, and you might think the belt is to small, but this is normal, as the belt stretches, just persist, but be careful you do not trap your fingers. Good luck.
May 10, 2009 | Hotpoint Aquarius WF000 Front Load Washer
The belts come off, its a hotpoint aquarius wm63.
Remove the complete rear panel of m/c if it is a washer dryer, you will see the drum pulley in the center, and the motor pulley is at the top of the m/c
Put belt round motor pulley first, and feed belt round drum pulley.
If it is a washer on its own, remove the small center cover at rear of washer, and remove top cover also.
Put belt round motor pulley first and carefully feed belt round drum pulley, you will find this easier to do if you unhook the rear retaining spring.
Please leave a fixya rating for my solution.
Feb 12, 2009 | Hotpoint Aquarius WD63 Front Load...
Creda t601cw condenser dryer
hi sounds like your belt has snapped or drum has snapped from the shaft regards jason
Jun 12, 2008 | Hotpoint Aquarius WD640 Front Load...
No longer rinses or fast spins...although drum does go round slowly... My WMA 13 First Edition Hotpoint has stopped fast spin, so although the drum does go round, it does not speed up to a fast spin at...
LETS check the DRAIN MOTOR PUMP it could be clogged , open panel of washer to access inside , look for a small motor with 2 hoses connected to it , take it out , clean it , re install and try it again , hope this helps AJ
Apr 14, 2008 | Hotpoint WMA13 Front Load Washer
Hotpiont washing machine
first check if belt from motor to drum is on, then check to see if motor is running. If not, there maybe a fuse link or fuse that needs replacement. The last time you used did you smell burning, if so could be your motor is gone.
Apr 03, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WF210 Front Load Washer Logo
35 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
