Question about Nokia 6300 Cellular Phone
Can't unlock keypad
I cannot unlock my keypad to enter the pjone. The only button that works is the on/off button. I've tried turning off then back on however it boots up normally and the key pad then automatically locks.
Noen of the buttons work and you are not prompted to press menu then * to unlock.
  • johnlludlam Jan 30, 2009
    NOKIA 6300 THE ONLY BUTTON THAT WORKS IS THE ON/OFF BUTTON, WHEN I TURN IT ON IT ALL LIGHTS UP NORMALLY, BUT YOU CANNOT USE THE KEY PAD, NONE OF THE BUTTONS WORK,
    ANY HELP PLEASE
    JOHN
    President:
  • 1,017 Answers
The default security code for Nokia is 12345.
Try this:
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know. You need someone to press the ON button.
Posted on Apr 03, 2008
Security code unlock
my cell pjone 1209 IMEI no is 354195/06/047083/5 and i forgot my security code and please help me to openit
Dec 06, 2011 | Nokia 1209 Cell Phone
Tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
on Mar 04, 2011 | Samsung SCH-U450 Cell Phone
How do i unlock my lg 8600 flip
  • Flip open the phone so the keypad is exposed and press any button to wake the phone up from sleep mode.
  • 2 Enter the four digit unlock code using the phone's keypad. The default code is the last four digits of your cell phone number.
  • 3 Press the "OK" button to submit the code and unlock the phone.
Forgotten Code
  • 1 Turn the phone over and remove the battery cover and battery. Press down on the upper plastic edge of the cover and slide it in a downwards motion. The plastic cover will give way to the battery which can be pulled out of the phone.
  • 2 Locate the sticker on the phone hidden behind the battery. Write down the last four digits of the ESN DEC number.
  • 3 Replace the battery and battery cover and turn the phone on by pressing and holding down the "Power" button.
  • 4 Flip open the phone so the keypad is exposed.
  • 5 Enter the last four digits of the ESN DEC number. Press the "OK" button to submit the code and unlock the phone.
Power the phone on and select the "OK" button. This will trigger the phone to ask for the password.
  • 2 Press "OK." Sometimes this is simply all it requires. If not, move on.
  • 3 Enter the last four digits of the phone's number. If this doesn't work, continue to the next step.
  • 4 Enter "#4357" or "*4357." "4357" stands for "LOCK" on a traditional telephone's alphabetic keypad translation. This is the default unlock code for certain LG telephones.
  • Dec 06, 2011 | LG Cell Phones
    Tried to reprogram security code for outdoor key pad on 1/2hp craftsman garage door opener according to instructions online, pressed learn button- put in new 4 digit code-held enter. Lights did not flash...
    Seems you've done everything right. Press and immediately release the smart/learn button and then walk over and key in a 4 digit code and press enter. If you are sure the battery in the keypad is good then I think your keypad is on the fritz or the wrong one for that opener.
    Apr 19, 2011 | Sears Craftsman LiftMaster Chamberlain...
    Keypad door lock does not work..?
    it's in owner manual. But, first you have to enter your original code and it must work. then you press the 1 button and then enter a new 5 digit code, then press the 1 button again.
    Keyless Entry Keypad To unlock the driver front door (20124) , and disarm the anti-theft alarm control (19A366) , (if equipped):
    • Enter the permanent factory code.
    • Enter the owner's alternate code.
    To unlock the passenger door(s), press the 3/4 button within five seconds of unlocking the driver door or luggage compartment. To unlock the luggage compartment door (40110), press the 5/6 button within five seconds of unlocking driver or passenger door(s). To turn on the courtesy lamps and light all illuminated components, lift either front door handle (22404) or press any button on the keyless entry keypad (14A626) . To lock all doors, press the 7/8 and 9/0 buttons at the same time with all doors closed. (It is not necessary to enter the key code first.) This will turn off courtesy lamps and arm anti-theft alarm control (if equipped). To program an alternate code:
    1. Enter the five digit permanent entry code into keyless entry keypad .
    1. Within five seconds of pressing last button of permanent code, press the 1/2 button within five seconds of pressing the last button of the permanent code.
    1. Enter any alternate five digit code within five seconds of pressing 1/2 button.
      • Enter a sixth digit as follows to indicate operator's memory seat setting to be set by alternate code:
        • 9/0 — no memory recall
        • 1/2 — memory seat position 1
        • 3/4 — memory seat position 2
        • 5/6 — memory seat position 3
      • After successful programming, the doors will signal by locking and then unlocking.
    • Keyless Entry Keypad Does Not Work Properly
    • Circuit.
    • Keyless entry keypad.
    • Electronic door lock control processor.
  • Open Fuses:
    • Town Car and Crown Victoria/Grand Marquis
    • Power Distribution Box (under hood)- K, 40A (Maxi)
    • Instrument Panel Fuse Panel - 17 (10A), 10 (20A), 8 (15A), 5 (15A) and 4 (10A)
  • Loose Connectors
  • Corroded Connectors
  • Oct 04, 2009 | 1995 Lincoln Town Car
    1999 lincoln con
    SECTION 501-14B: Keyless Entry/Computer Operated Locks 1999 Town Car Workshop Manual GENERAL PROCEDURES Programming —Keyless Entry Keypad Code
    1. Enter the permanent factory keyless entry keypad code.
    1. Press the 1/2 button within five seconds to activate the programming mode. Holding the 1/2 button for more than two seconds will erase all stored customer codes. The existing codes do not need to be erased to program new codes.
    1. Enter the new five-digit keyless entry keypad code.
    1. To associate the new code with personality positions 1, 2 or 3, press the 1/2 button within 5 seconds of entering the 5th digit of the new code for position 1 or 3/4 button for position 2 or 5/6 for position 3. The door locks will lock and unlock confirming the new code is programmed.
    1. If another code is to be programmed, begin entering the code within 5 seconds of the last button pressed.
    1. After all new keyless entry codes are programmed:
      • Press keyless entry keypad buttons 7/8 and 9/0 at the same time to exit the program mode.
      • Wait for 5 seconds; the driver door module (DDM) will exit the program mode automatically.
    Programming —Transmitter
    1. Cycle the ignition from OFF to RUN four times within three seconds. The locks will then lock and unlock, confirming program mode has been entered.
    1. NOTE: When the first keyless entry remote transmitter is programmed, all other keyless entry remote transmitters are erased.
      Press any button on the transmitter to be programmed.
    1. If additional keyless entry remote transmitters are to be programmed, repeat step 2 within 7.5 seconds.
    1. To exit program mode, turn the ignition to START or wait 7.5 seconds.
    Programming —Remote Memory Activation NOTE: This procedure must be completed within 5 seconds.
    1. Press the SET button on the driver door panel.
    1. Press any button on the keyless entry remote transmitter to be associated with a memory setting.
    1. Press the 1 or 2 memory button on the driver door panel.
    Programming —Autolock and Horn Chirp
    1. NOTE: This procedure must be completed within 30 seconds.
      Turn the ignition switch to RUN.
    1. Press the UNLOCK button three times.
    1. Turn the ignition switch to OFF.
    1. Turn the ignition switch to RUN. The doors will lock and unlock to confirm entry into program mode.
    1. Press the UNLOCK button once to toggle the Autolock feature on or off, or twice to toggle the Horn Chirp function on or off. The horn will chirp to confirm toggling of the Autolock feature.
    1. Exit program mode by turning the ignition to OFF, START, or wait 7.5 seconds.
    Apr 07, 2009 | 1999 Lincoln Town Car
    Door key pad, won't unlock door
    1. Enter the permanent factory remote keyless entry (RKE) keypad code.
    1. Press the 1/2 button within 5 seconds to activate the programming mode associated with the memory position 1 settings. Holding the 1/2 button for more than 2 seconds after activation erases the stored personal code.
    1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 1 settings. Entering any new personal code automatically erases the old personal code.
    1. Press the 3/4 button within 5 seconds to activate the programming mode associated with the memory position 2 settings. Holding the 3/4 button for more than 2 seconds after activation erases the stored personal code.
    1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 2 settings. Entering any new personal code automatically erases the old personal code.
    1. Press the 5/6, 7/8, 9/0, 7/8 and 9/0 button within 5 seconds to activate the programming mode or allow the system to timeout.
    1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed. Entering any new personal code automatically erases the old personal code.
    Jan 23, 2009 | 2005 Ford Freestyle
    Garage door opener
    it works but it is annoying: you will have to hold down the button on wired wall unit. hold it until the door closes. also if you have the keypad outside it also works the same way, type code and hold the enter button
    Dec 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
    Locked cell phone keypad
    first, take out the battery and press the RED end call key for 15 seconds, then put the battery back in and turn on the phone.
    if that doesn't work then try this from the website.
    How do I lock/unlock the phone's keypad? To lock and unlock your phone's keypad, press and hold the left navigation key.
    Or, select Menu -> Settings -> Keyguard. Then highlight either of the options and press the OK button. You can set your phone to lock the keypad immediately, or automatically if no key is pressed after 30 seconds, 1 minute, or 5 minutes.
    To unlock the keypad: Press 1-2-3 in that order."
    good luck!
    Apr 15, 2008 | Kyocera K10 Royale Cellular Phone
    How to unlock LG VX4400
    Many people never program a password code to "Unlock" this phone, but can lock themselves out by pressing the # key for more than three seconds. I know, it happened to me when I was out of town and needed the phone to work! Anyway, press the button to the right of the large round button at the top of the keypad, you will get a prompt to enter the four digit "Unlock" code. The default from Verizon, and most likely the factory default from LG, is the last four digits of your cell number. Did this work for you too?
    Mr Dennis
    Nov 27, 2007 | LG VX4400
    Nokia 6300 Cellular Phone Logo
    164 people viewed this question
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
