Changing the direction of the paper
I need to change protrait to landscape.
    Genius:
  • 2,785 Answers
When you gave print command the print dialog box there you get properties tab click on that then you will get properties dialog box there you click on layout you will see protrait and landscap.click accordingly.
Posted on Apr 03, 2008
I want to change papar orientation from landscape to portrait. I changed it in paper tray but paper orientation in printing does not changed. plz guide.
Dude, changing paper orientation on paper tray is just one step, while you must change paper setting on printer driver too. In some machines, you should change paper switch position too :)
Sep 30, 2013 | Toshiba EStudio 223 Copiers
Ricoh Aficio MP C3300
Go into the print driver and the machine settings and make sure the paper size and direction are all in agreement with each out and the paper in the tray itself. If screen icons do not agree with the size and direction of the paper in the tray you will have a lot of weird problems.
Jul 22, 2017 | Ricoh Office Equipment & Supplies
Need to know how to switch screen from protrait to landscape on a200 tablet
Go to Menu -> Settings -> Device (Display) -> Auto-Rotate screen.
This will allow you to rotate the screen depending on how you hold the tablet.
Hope this helps.
Nov 10, 2012 | Acer Iconia TAB A200-10G08U 10.1 inch...
My document is in portrait. I've used this same file for over 15 months. Now it is printing in landscape. I am loading the paper the same way I always have.
In your print driver, (start menu, printers and faxes, right click on your printer, select printing prefrences, and select protrait.)
This will set you back to your original portrait print prefrence.
Jan 07, 2011 | Xerox Phaser 7400/DXF Laser Printer
Somehow I change the screen from landscape to protrait and don't know how to get it back
try control panel,display,desktop you should find something there remember to click apply before exiting
good luck
Aug 30, 2010 | Computers & Internet
Zebra TLP 2844 printing landscape instead of portrait.
To change from "page mode" (protrait) to "line mode" (landscape) you need to complete the following steps.
1. turn the power off
2. hold the feed button down
3. turn power on, the feed button should blink, release the button.
4. when the feed button blinks green, press and hold until it turns red or amber. release the button.
5. turn the power off.
6. hold down the feed button and turn power on, the button should blink and release. it will now print a calibration page. 4 blanks followerd by 2 text pages, the last saying "Now in DUMP" press feed to exit. on the first print, the 4th line down will say either page mode or line mode.
Nov 04, 2009 | Zebra TLP 2844 Label Printer
C0910 code im3520 imagistics copier
Your lift motor, for second paper tray draw, or third draw, are you storing extra paper in the second or third draw, beside the paper properly placed in the draw. Is there paper behind the draw? Do not store extra paper in a paper draw. Just because the draw has space not setup for 11x17 paper and is being used for 81/2x11 dont store extra paper. If this is a large capacity tray for over 500 sheets paper can only be set up for 81/2x11 protrait not landscape.
Aug 06, 2009 | Office Equipment & Supplies
A blue line , 2mm, appearing at bottom of page.
Hi Info39684,
It sounds like your Cyan imaging unit has gone down.
Have you thought of changing the orientation of your paper from A4 protrait to A4 landscape. If the blue line is at the bottom, changing the orientation should hide the problem. It's not going to fix it, and if you use A3 then you will see the line again. It's just an idea and you could save yourself £250 on a new unit.
Regards
Taminol
May 18, 2009 | Konica Minolta bizhub C250 All-In-One...
93 people viewed this question
jasbo
jasbo
