Question about O2 Xda IIs Pocket PC
Xda iis Just got a new battery for my xda iis and instead of the customary orange led indicating charging all i get is a red led and a dead pda. Should I patiently wait or is this a dead battery?
    Problem Solver:
  • 19 Answers
Yes that rite.. maybe that battery is not compatible with your PDA... or not the original...
Posted on Apr 26, 2008
It is indeed a dead battery - the red LED means NO BATTERY PRESENT.
Posted on Apr 04, 2008
I am trying to charge my phone right now but it is just a constant red light where it would usually be orange and it is saying 0% charged
did you run the battery completely flat?
my phone if it has gone dead, when plugged in to charge, has a red LED for about 5 minutes where you cannot even turn it on it is that dead. after those minutes pass the phone can then be turned on, and the LED changes color to orange to indicate it is charging and is also powered on.
Jul 12, 2010 | HTC G1
TOSHIBA PORTEGE G910 POWER MANAGEMENT problems
try xdadevelopers for this solution,best site for xda pda problems
Mar 23, 2010 | Computers & Internet
Hi i plug unit with battery for charging no display lcd and no light indicator colored orange . I take out battery pack and charge then it produce light orange-red indicator of unit. I noticed charging...
Hi I solved the problem by taking off the battery for around 1 hour.
I attached the battery again.
And press hold switch around 10 seconds.
The unit booted and it proceeded to auto configure and auto installed program soft wares.
I realized that the unit is self shutting off.
Solution is go to setting.go to system.go to back light menu.
on backlight on external power .Be sure to uncheck turn off backlight if devise is not used for 1 minute.
Be sure to check turn on the back light when button is pressed or the screen is tapped.
press ok to activate the setting.
For maximized battery power and optimized power usage .go also to back light and go to brightness level.
Slide the battery and power to almost the 2ndlevel .
Hope this also will be applicable to other o2 xda iis configuration.
Best regards
Jan 17, 2010 | O2 Xda IIs Pocket PC
My xda II pocket is dead, i tried charging it but there is no sign of charging.
Hi , the best bet is to go to your local dealer. Ask them to try a new battery, then check your charger against a shop model.
I presume your under warranty, i would ask for a replacement.
Hope it helps
Dec 16, 2009 | O2 Xda IIs Pocket PC
I cant get past the align screen on my o2
When you don't charge your PDA's battery for a while, and let both normal and backup batteries to finish completely, all your data in your PDA is lost, and it will go back to factory default state. As the operating system is stored in the ROM of your PDA, it will be reinstalled when you charge it again, and becuase there's no data left from the past state, you have to do all the settings again from the start, beginning with the screen alignment (You can tap carefully on the plus sign each time it moves). If you had a backup syncronized with your PC, you can then recover your data to your PDA.
Apr 09, 2009 | O2 Xda II mini
PDA displays only a white Screen
don't worry just change yur display ic ......
Aug 08, 2008 | O2 Xda IIs Pocket PC
My pda help plz
just go to the repairer n replace the socket with new 1 but mak sure that d ciruit is not damaged,,
Aug 01, 2008 | O2 Xda IIs Pocket PC
Digimax i5 problem charging battery
■ Charging LED
Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
 Green LED is on = Charging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
If the charging LED doesn't turn to green could mean a signal that the battery is bad or can't charge 100% anymore = too old, needs a new battery. Hope this helps.
Jul 06, 2008 | Samsung Digimax i5 Digital Camera
O2 - XDA II
Hi Marky T, have a peruse on the site http://wiki.xda-developers.com/ there is a lot of discussion on Bluetooth headset issues and solutions.
Apr 19, 2007 | O2 Xda II Smartphone
Red Light on nothing else works
recharge the battery by connecting the HP iPAQ to AC power using the cradle or the AC adapter to atleast 6 hrs continuously
Dec 01, 2006 | O2 Xda IIs Pocket PC
O2 Xda IIs Pocket PC Logo
262 people viewed this question
Top O2 Computers & Internet Experts
Computer Repairing
Computer Repairing
zurysk8
Level 1 Expert
Martin Murray
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
