Question about HP Pavilion dv6000z Notebook
Amilo m7400 network adaptor
Wlan network adaptor has disappeared from device manager and windows does not find new hardware on reboot. Where do I start to look.
    Genius:
  • 1,913 Answers
I think u install rong driver.
go to add remove proggram and uninstall wlan driver and software.
Posted on Apr 03, 2008
Deleted some files from toshiba laptop and now I cannot connect to the internet
Try This:
Windows XP
Accessing Device Manager using Control Panel 1] Press the Start button. 2] Go to Settings, a new menu will pop out to the right. 3] Click on Control Panel. 4] When the control panel comes up, find the System icon and open it up. 5] When the System properties box opens, click on the Hardware tab. 6] You should see your 'Device Manager' button here. Click It.Expand your 'Network Adaptors' from this list, as shown below, using the [+] box.
Now locate your Wireless device, right-click it and select uninstall.
**If prompted, DO NOT uninstall your drivers also**
Now right-click your machine name at the top (I have blacked mine out in the above image for obvious reasons) and select the 'Scan For Hardware Changes' option from the menu.
Let it settle, reboot.
Windows Vista &Windows 7
Start>Right click Computer>Manage>Device Manager
Complete the steps from above to locate and uninstall Network Adaptor.
Jul 31, 2012 | Toshiba Satellite L305 Wireless Card...
Fujitsu Siemens Amilo M7400 FB21 WLAN Problem
you will have to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk
Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabledi
click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details
or type in your default gateway adress into your internet search should read something like 10.0.0.138 to get an inertnet connection
hope this helps you
Apr 19, 2012 | Intel PRO/Wireless 2100 MiniPCI 802.11b
Hi ,cant get my dell wireless 1370 wlan mini-pci card to work ,just has a cross over it and wont allow me to activate it ?
It may result from a driver issue. Go to Control Panel > Device Manager (Windows Vista / 7) or System > Material tab > Device Manager (Windows XP). From there you will see the list of installed hardware. You should also see your wireless network card under Network Adapters or Ethernet Controller.
There you should find a red cross on this hardware. Right click on it and select enable.
If this does not help, right click on the Network Adapter name and uninstall it. Then reboot your laptop. Once restarted, Windows should detect a new hardware and may install the driver automatically. If it is not installed automatically, you have to do a manual install.
Normally, you should have received a CD containing the drivers when you bought your laptop. You can install the driver from the CD.
Hope this helps !!
May 10, 2011 | Dell Inspiron 1300 Notebook
Fujitsu siemense amilo m7400 laptop drivers downloading
http://uk.ts.fujitsu.com/support/downloads.html
1. Click on Downloads on the left pane
2. Select Product: Notebook
3. Select the product group: AMILO
4. Select the product family: AMILO M
5. Select the product: AMILO M7400
And you'll have all the drivers needed.
Mar 06, 2011 | Computers & Internet
Wirless driver required
in device manager, you would click start, or the "My computer" icon and then click on device manager. Under the drop down list you see look for network adaptors and if you see you wireless card, which should be listed with your LAN network adapter, ...once you find the wireless adapter RIGHT click it and click on properties, once that open you should see and make sure it says device is working with no conflicts, then click the tab above that says driver, then click update driver and let windows search for it , which is the top choice. IF you do not see your wireless card anywhere in device manager you can try a few other things, like search for new hardware and if that fails contact the manufactuer to get the driver, and it is free and should be able to download from their site. I also would uninstall your wireless adapter so that when you intall the new wireless drivers/software you wont have to worry about old problem drivers and windows will then install a fresh copy via the internet automatic for you. Other Issue could involved and I can assit further if need be but those are general fixes however sometimes more measures need to be looked at. Thanks you.
Dec 22, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
My network adapter disappeared on mt desktop- do I
You might need to check the Device manager to see if the network card is there and installed properly.If the device manager says it is there and working then it will be a hardware issue.
Just in case your not sure how to get to Device manager, here is a shortcut. Right click on My Computer, click Manage. This will bring up the management console, have a look down the left and find Device Manager.
Oct 29, 2009 | 2wire (1000-100009-001) Network Adapter
Amilo 2727 wireless adapter hotkeys
Please uninstall the driver though Device Manager and get it install from the disc given by manufacture website or download the latest driver.
Path is :
My Computer(right click)->Properties ->Hardware->Network Adaptor
Jul 30, 2009 | Fujitsu Siemens AMILO Pro V7010 Notebook
Does my HP s7750 have wireless internet connection. if so how do i turn it on or if not do i need to buy a wireless usb adaptor
check the box that the machine was packed. if you find a antenna, then, your machine have wireless LAN.
to set up the Wireless
1 Click the Windows Start Button on the taskbar.
2 Type Device Manager into the Search box, and then click Device Manager to open
the Device Manager window.
3 Click Network adapters. Your WLAN device should be listed here. The WLAN
device may include the term wireless, wireless LAN, or 802.11.
4 Click the Windows Start Button on the taskbar.
5 Type Network and Sharing Center into the Search box, and then click Network
and Sharing Center
to open the Network and Sharing Center window.
6 Click Add a device to the network and follow any onscreen instructions.
For more information about setting up a wireless network:
 Click the Windows Start Button on the taskbar, click Help and Support, and
then type Setting up a wireless network into the Search Help box.
NOTE: If no WLAN device is listed, either your computer does not have an integrated
WLAN device, or the driver for the device is not properly installed.
Feb 26, 2009 | HP Computers & Internet
Wireless networking hardware not functioning properly.
Check on Device Manager if it is working properly
Right-click My Computer-Properties-Hardware-Device Manager
Click on the plus sign beside Network Adapter and double-click your wireless card.
Check on the device status if it says it's working properly.
Try to disable-enable the adapter by right-clicking on it under the device manager window.
If it has a question mark, it is most likely driver issues so contact your wireless card manufacturer or PC manufacturer if the wireless card is built in.
Jan 12, 2009 | Gateway MX8711 Notebook
Fujitsu Siemens amilo pro v2000d easy launch button wlan
Go to http://www.fujitsu-siemens.co.uk/support/downloads.html and go through entering your laptop model number etc. When all the downloads for your model are displayed, confusingly Launch Manager is hidden under the title "Panel". It works - I have just rebuilt the hard drive on my Amilo M7400 and could not find Launch Manager to enable the wireless function anywhere else. Good Luck
May 21, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
HP Pavilion dv6000z Notebook Logo
121 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
